Old 27th June 2011, 15:23   #2011
dot
dot's Avatar
Thanked: 714 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by laluks View Post
But I had loved the few days I drove with out it, she sang and danced quite well.
Would it be possible for you to elaborate that experience. I can understand that it is probably qualitative, but still, I am keenly interested to know. Did the low end torque improve, that is, pick up from 1st and 2nd was better by any means?
The reason I am asking this is because the dyno chart in the link seems to suggest that maximum gains are in the low end and high end of the RPM range.
dot is offline   Reply With Quote
Old 27th June 2011, 16:00   #2012
laluks's Avatar
Thanked: 9,669 Times
@dot - the sound definitely was louder than the stock setup, and the grunt was good (subjective scenario). The performance seemed to improve, and a felt her a bit agressive (subjective), but not too much. The feel could also be inside me due to the sound effect.
I guess you can try this out without much worries. One pipe goes from the air filter box to resonator. Another pipe goes from resonator to little above the wheel well behind the rubber cover.
You can try and remove the pipe from the air filter box and test around. Its easy to remove that. If you find it complicated, I suggest you remove the bumper and then it is as easy at it seems in front
laluks is offline   (1) Thanks Reply With Quote
Old 27th June 2011, 16:10   #2013
dot
dot's Avatar
Thanked: 714 Times
Thanks for the information. I will certainly try this out sometime. But let the rains go off.
It is better to open the end near the resonator box as it will draw in cold air from the fog lamp dam. If we open the pipe near the air filter box, it will surely recreate the change of engine note, but will also suck in hot air from engine bay.
Old 28th June 2011, 11:54   #2014
sushrutha's Avatar
Thanked: 325 Times
An urgent help.
I recently brought an Autogauge 2 in 1 digital Voltmeter+RPM meter.
Need to install this in my CIVIC. When connected, Voltmeter works fine.
Though I already have a stock RPM meter in a CIVIC, but I want this Autoguage unit to be installed seperately which looks cool too (Digital RPM ;-) with Led's )
Has anybody installed an addon tachometer in CIVIC ?
Now from the gauge where do I have to clip the RPM wire into ? Where in distributor ? Or does the RPM singal come from ECU ? How easy is it to install an RPM meter in a civic?
Can be done in this way, BUTTTT.........
I don't want to open my dashboard and tap the wire which is for RPM meter in the dashboard.
This is how the Gauge looks
Honda Civic : Maintenance, Service Costs and Must dos-rpm.jpg
I have asked the same Question in the TACHOMETER thread too
Old 28th June 2011, 13:44   #2015
sushrutha's Avatar
Thanked: 325 Times
Bump
Does anybody have the wiring & harness diagram of the Civic's ECU ?
Old 28th June 2011, 13:53   #2016
dot
dot's Avatar
Thanked: 714 Times
Originally Posted by sushrutha View Post
Bump
Trying to find one.
I need the harness diagram to find the vtec connectors.
Old 28th June 2011, 15:11   #2017
laluks's Avatar
@ sushruta - are you trying to tap the line out from the ecu and give to your tacho? Since it also acts like a volt meter I guess it takes in the analog voltage and converts to rpm.
Now even if you tap the wire, how can we calibrate the tacho if need be? Any possibilities?
Tapping from the dash is easy. Removing the tacho meter is a simple job
laluks is offline   Reply With Quote
Old 28th June 2011, 15:33   #2018
sushrutha's Avatar
Thanked: 325 Times
Originally Posted by dot View Post
Trying to find one.
Would appreciate if you find any.
Is it pin # 28 or 26 with Blue wires ?
That's what 8th civic forum says, but that's for Si version of civic.
Any help for R18 ?
I'm planning to tap the wires from ECU.
The Tacho which I have now can be used for 2,4,6,8 etc cylinders.
Seems like I have to switch to use the 2 cylinder mode instead of 4 cylinder one ,which will do the conversion properly.
This is the Tacho which I'm talking abt
Autogauge RPM Tachometer | Autogauge 52mm Digital Blue LED RPM Tachometer
Would sppreciate if you tell me the steps ... seems like I have to open the dash....
My only concern is the airbag part ....
Will airbag open incase if anything goes short circuit or anything like that ?
Old 28th June 2011, 15:38   #2019
madbullram's Avatar
Thanked: 76 Times
Hi all,
Did anyone install reverse Camera in Civic? I found this interesting CCD (not CMOS) camera which seems to be a direct fit on Civics, any views?
CCD Car Rear view Reverse Camera for HONDA CIVIC 08- 09 (eBay item 160596476466 end time 01-Jul-11 13:39:29 AEST) : Cars, Bikes, Boats
madbullram is offline   Reply With Quote
Old 28th June 2011, 15:40   #2020
jatinpatel's Avatar
Thanked: 191 Times
@sush
try asking honda A.S.S to fix it for you. they will help you out if you cunningly request them as one of my friend got a FFE installed in his Civic at linkway honda.
jatinpatel is offline   Reply With Quote
Old 28th June 2011, 15:43   #2021
sushrutha's Avatar
Thanked: 325 Times
Originally Posted by jatinpatel View Post
@sush
Here in Bangalore, they won't even allow you to put E-oil if you get it from outside, I don't know as how the'll allow me to get my ECU Tapped.
Edit - Can somebody help me on this soon,
Else i'll just give back the LED RPM/Voltmeter from whome I purchased. It's kind of urgent ;-)
Old 28th June 2011, 16:50   #2022
sgiitk's Avatar
Thanked: 3,867 Times
I got Mobil1 from outside and had no problems. They wanted me to note that I have provided teh oil, so I wrote something like Mobil1 0W40 API-SM Full Synth provided by me. No issues after that.
Old 28th June 2011, 16:58   #2023
dot
dot's Avatar
Thanked: 714 Times
There are some links on the net about the harness pin diagram. However they are getting blocked by the office firewall. Will try to check them from home and post at night.
I am thinking of installing a vtec indicator.
OT: Linkway Honda seems to be very customer friendly. The Saint installed his Konis there, Jatinpatel also has friends inside..wow.
Old 28th June 2011, 17:35   #2024
laluks's Avatar
To reach the tacho meter we need to concentrate on the centre console with the Music system and the piece of dash behind the stering. So the Driver and passenger airbag units are not touched. They are left as it is assembled.
To remove the centre music system console you'll have to remove two screws/bolts from below. You will need the right tool for this.
The red arrow shows the small storage space in the dash. Look there and you'll see a small piece of removable rectangular plastic under the music system. Using a cloth around a flat screw driver remove that. You'll see the two screws/bolts that have to be removed.
Name:  619243DIY teardown pic 1.jpg
The above schematic shows exactly the same. Once the two screws/bolts are removed, pull the console out slowly. Voila - you have your music system in hand But don't pull it harder, the wiring harness is still connected.
Now to remove the panel behind the Steering to reach your tachometer.
Step1.
Remove the panel below the steering. Just rotate the rotary knob and slowly pull it out. Its just some clips.
Step2
Step 3
Remove the panel behind the steering
Step4
Slowly pull it out.
Now you see your Tachometer!!
NOTE : All pictures are sourced from the internet. Copyrights belong to those respective owners. Used here to explain the topic.
laluks is offline   (3) Thanks Reply With Quote
Old 28th June 2011, 18:52   #2025
dot
dot's Avatar
Thanked: 714 Times
Bump
Found something, not sure if this can extract the RPM signals. Seems to have the vtec point though.
ECU/ECM pinout please - Page 2 - 8th Generation Honda Civic Forum
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1482 24th June 2018 09:58
