Old 14th July 2011, 11:27   #2086
hiren.mistry's Avatar
Thanked: 202 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by spadix View Post
This used to be the case with my car too whenever I visited my parents' place. Now we've put a shed on top of that open parking area but BQ saw a lot of this in its infancy. This coupled with the fact that it gets a waster wash at least twice a week means I need to be careful about this issue too.
Aah! How I wish something like this can be done in my building.
I personally wash the car once a week but due to rains I had asked someone else to wash it every alternate day.
But yes, I would be a good idea to keep an eye out for this. And the only way you can see this is by taking off the wiper shroud.
Originally Posted by gaurav_chopra04 View Post
ECU should be behind the glove box somewhere..
Ya, thats the opening for AC evaporator coil (Heater core), as we call it. Its a small radiator kinds a thing in the dash, coolant from engine passes through it and when you turn your hearter on, basically heat from this exchanger is transfered to you through blower. It can also be thought of as a heater core filled with cold gas. The AC cools the incoming air and the heater core reheats it to a desired temperature..thats how your Cimate control works.
Now that you are getting the dash opened its a good idea to get this evaporator coil and ac blower cleaned. All the dust/small tree leaves are blocked here. Blocked heater core may result in what is called an iceing problem. The thermostat cant work as its tip freezes, and you get fumes from your AC vents as you get from your freezer at Home. A pathetic tree outside our house which sheds tiny leaves makes sure that the evaporator coil in all our cars is cleaned every 2-3 years. The civic at home needed cleaning this year (2 year old car) and the cedia may need it next year. Swift too needs it every 2-3 years.. Honda charged 4k for complete AC service including fresh gas, and ripping dash and cleaning evaporator coil and blower.
Wow, that's an excellent bit of explanation there Gaurav, muchos gracias!
But I spelt it wrong, its called a "Cowl Top" and not coil top.
What you are saying makes perfect sense, I will ensure the entire cooling system checked.
Many thanks.
hiren.mistry is offline   Reply With Quote
Old 14th July 2011, 21:46   #2087
dot
dot's Avatar
Thanked: 714 Times
The ECU is behind the battery. Here is a link which shows where it is.
http://www.team-bhp.com/forum/techni...ml#post2424689
Originally Posted by hiren.mistry View Post
They will be taking the dashboard as well the windscreen out to completely cure the rusting.
Honda didnt disappoint us, they behaved exactly as we expected, isnt it?
Do keep us updated on how rust portion is restored. This repair could be pretty unique. All the best.
dot is offline   (2) Thanks Reply With Quote
Old 15th July 2011, 11:23   #2088
Thanked: 202 Times
Aah! Thanks for this. So looks like the ECU might not be touched.
Oh yeah! They are true to their form. Unique or not I am still baffled by the whole thing. My almost 10 year Pulsar that get abused royally in the rain has hardly a spec of rust on it. And here my car that gets pampered has rusted.
Old 15th July 2011, 11:36   #2089
sgiitk's Avatar
Thanked: 3,793 Times
Infractions: 0/1 (5)
Any sources for the Indicator bulb (front/rear). Amber 21W, push fit. Never seen the shape before. I want to avoid going to the HASS which is 12km away with a hopeless road to take.
Old 15th July 2011, 11:51   #2090
gaurav_chopra04's Avatar
Thanked: 534 Times
Ahh, I didnt know civic's ECU was under the hood, the way its washed normal as other cars. Must be sealed properly. Thanks Dot..
gaurav_chopra04 is offline   Reply With Quote
Old 15th July 2011, 12:16   #2091
Thanked: 202 Times
Any spare parts outlet should have the necessary bulbs. Have your bulbs fused? I've seen many opting for LED's on 8th Civic, wonder if these are available here.
Check this link for complete listing of bulbs and their ratings.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old 15th July 2011, 13:20   #2092
laluks's Avatar
Thanked: 7,932 Times
In the dash, there is no ECU. But the Airbags ECU is right behind your gear lever.
You can see how my car looked like without the dash from the post 737 http://www.team-bhp.com/forum/long-t...ml#post1922708
laluks is offline   (4) Thanks Reply With Quote
Old 15th July 2011, 13:39   #2093
Thanked: 202 Times
Attachment 577236
I wanted to have a look at these pics but was having a hard time finding them.
Wow, the car looks barren after the dash has been taken off.
Any particular precautions to be taken while removing the dash?
thanks
Old 15th July 2011, 14:31   #2094
laluks's Avatar
I guess removing the dash is a routine job for them.
What I found interesting was, they just removed the entire dash as a single piece by removing some bolts from both the fender sides. It was nice to see the entire dash assembly sitting outside the car
Yes the car looks very empty without the dash!
laluks is offline   Reply With Quote
Old 15th July 2011, 14:51   #2095
Thanked: 534 Times
One thing I found stange is that they took 4 days for such a job. Ring Road Honda did it in 4 hours.. My cousin's driver was present at the ASC and I had given him explicit instructions to see that the ASC cleans heater core and blower properly..He has previously got it cleaned for our swift, indica and alto. So, he knew what was to be done..
But I know its very difficult to see your car in such state..but until the rattles dont turn up and the problem is sorted its fine..
Old 15th July 2011, 14:58   #2096
Thanked: 202 Times
@Laluks: If its one single piece and quite easy to remove, thats very heartening to know.
@Gaurav: Looks like I will be doing that same tomorrow at Carnation.
After having 3 sleepless nights I am beginning to get a good feeling again.
Thanks fellas.
Old 16th July 2011, 09:57   #2097
mdsaab's Avatar
Thanked: 446 Times
Thanks fellas.
sorry hiren, as i had no clue as how to solve this issue i was shying away from any inputs or comments. But what is heartening to hear is that after 3 sleepless nights, the worst seems to be over. and things will be on track soon. Wishing you luck in solving this issue ASAP and getting back to the motoring bliss.
mdsaab is offline   Reply With Quote
Old 16th July 2011, 13:38   #2098
sumeethaldankar's Avatar
Thanked: 1,049 Times
Security for the Civic.
Friends i have a bought used 2007 Honda civic.I am sure you guys know that the civic as a built-in immobilizer bit i want some more security.I wanted to know what devices/locks etc you guys have placed on your Civic's for that extra peace of mind.
thanks
sumeethaldankar is offline   Reply With Quote
Old 16th July 2011, 16:50   #2099
jatinpatel's Avatar
Thanked: 191 Times
If your civic is manual you can use a gear lock.
Also add on security systems are available for stock security systems by companies like autocop and so. You can contact them, some time back had sent them an enquiry for the same to which they replied they have add on module for the stock security system and in which the stock remote is still used and impact and interior motion sensors are placed.
jatinpatel is offline   Reply With Quote
Old 16th July 2011, 23:56   #2100
dot
dot's Avatar
Thanked: 714 Times
While I have no other measures of extra security, I do have a question. Can the engine immobilizer be circumvented by hot wiring the Civic? In other words, can the current gen Civic be started without using the key?
dot is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1403 11th January 2018 14:44
