Old 12th September 2011, 12:03   #2386
smartcat's Avatar
Thanked: 12,560 Times
Default Re: Reason to worry?
Originally Posted by spadix View Post
So this could just as possibly have been caused by a stone or pebble that landed from somewhere, although there's a tree right above this general area in that open parking slot outside our house.
Doesn't look like it was caused by a stone. Culprit seems to be some kind of acidic chemical. Do the cleaning chaps use chemicals to clean the interiors?
smartcat is offline   (1) Thanks Reply With Quote
Old 12th September 2011, 12:10   #2387
sushrutha's Avatar
Thanked: 324 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by dot View Post
AC on or off hardly has any bearing on FE. I had the .
On the Civic you feel nothing, so should have a negligible (<0.2kpl) drop at worst.
Here is my scangauge reading.
Idle - 0.74 LPH (Liters per hour)
Idle with AC - 1.07 LPH with AC set to 23d
I'm yet to test the figures when coasting in gear @ same speed(with & W/o AC)
Originally Posted by kumargandharva View Post
Shall I get this work done at honda, or some other place. My location is Gurgaon.
- Power window panels (LHS RHS) (Plastic housing containing power window buttons).
- Gear Knob
- Handbrake plastic
- All pedals
- Wiper blades
- Clutch assembly (clutch is a bit hard - what could be the reason)
Congratulations on your new buy.
Originally Posted by jatinpatel View Post
get them painted in the same original color by a good painter should cost you max of 1k for both the panels same applies for gear knob too.
Rightly said Jatin, I got all the four power window panels painted with metallic silver+lacquer (clear coat), costed me 750Rs at a reputed paint workshop. Fantastic paint work.
2.Wiper blades from honda should cost you around 500rs just for the rubber stripes which require replacing go with honda only as in open market this is not easily available and secondly fakes ruin the glass.
Yep each is around 500Rs, but ~950Rs for both the wiper blade rubber(Passenger side is small)
3.If pedals are excessively worn out then you have to go to honda only for that or you can go to your local accssories shop and ask around for pedals stock or aftermarket.
For around 2000Rs (Here in BLR @ JC Road) you'll get some nice Aluminium pedals, they look like some racing pedals & Looks good too
sushrutha is offline   (2) Thanks Reply With Quote
Old 12th September 2011, 15:32   #2388
spadix's Avatar
Thanked: 185 Times
My immediate reaction will be an immediate touch up. Only with metallic paint you are looking at the panel at about 4k. Being is Gurgaon you can easily leave it for a few months.
Thanks, Professor!
I'll see if I can get a touch-up done for cheap. With black, colour matching isn't an issue, thankfully.
And like you, I think an immediate touch-up is required. Gurgaon (and the Northern plains in general) gets pretty humid at this time of the year, what with the absolutely still air and no wind whatsoever. RH was 94-95% when I checked the other day.
Thanks, smartcat, but the chemical angle doesn't explain the dent. Perhaps it was a mix of chemical damage and some frantic rubbing which possibly caused the dent. I need to ask the guy.
spadix
spadix is offline   Reply With Quote
Old 12th September 2011, 21:09   #2389
dot
dot's Avatar
Thanked: 714 Times
These are great observations. Also corroborates with my estimates.
I lost about 3 L of petrol due to idle with AC on in three hours (ICE tuning ). How did I know? Usually I get 350-340-330 Kms for 34 L; totally city driving. 34L corresponds to tankful from 3 dots in FE gauge. This time I got 305Kms (FE=9) . Hence I lost about three liters.
Looking forward to see more info from your scangauge. BTW, I bought a ELM 327 bluetooth device. The OBDscope subscription needs to be activated..
dot is offline   (1) Thanks Reply With Quote
Old 13th September 2011, 11:36   #2390
sushrutha's Avatar
Thanked: 324 Times
Sure, will do that.
The advantage of buying of the scanguage is, one can improve on driving habits which will marginally increase in FE. Like throttle position, optimal gear change, etc based on the feedback(output) from the SGII .
Heck the moment my ICE is on (Sub + amp ) there is very slight increase in Fuel consumption, samething when the liights are on (I have 35W hid kit with projectors, but not much of difference in Fuel consumption when these are ON). The moment highbeam & foglights are ON, one can note the difference in Fuel consumption(to a small extent).
Some negatives of SGII
* FE is not displayed in KMPL, it's rather LHK (liters per 100 KM ). New SGe has KMPL display.
* Slightly over priced. ~160$
I was expecting this ;-). Sometime back you were discussing abt the same in OBD thread / someother thread.
sushrutha is offline   (1) Thanks Reply With Quote
Old 13th September 2011, 12:52   #2391
sgiitk's Avatar
Thanked: 3,814 Times
Infractions: 0/1 (5)
Thanks, Professor!
The pics give an impression of a blue. Also, even getting perfect match on black, though easier is not trivial.
What I could see in the pics was that the underlayer (whitish) seems to have survived, so there is protection. Also, what matters is salt spray in coastal regions. A high RH is dodgy, but not fatal.
sgiitk is offline   (1) Thanks Reply With Quote
Old 13th September 2011, 17:07   #2392
dot
dot's Avatar
Thanked: 714 Times
This is expected, as energy to run the amp has to come from somewhere. How much does it change? Does it also depend on volume? I have tried digging the net to get some information on this topic, no luck yet.
dot is offline   Reply With Quote
Old 13th September 2011, 19:49   #2393
spadix's Avatar
Thanked: 185 Times
Yeah, I must blame the camera phone. It messes up the colours pretty badly.
I haven't managed to take better quality pictures, but there is a very small area where I feel the metal is visible. I could be wrong, though.
And yes, thankfully there's no (need for) salt spray around here. And the high RH days should hopefully be over soon.
By the way, I figured out how this was caused. There's an electrical fuse box right next to the car's dedicated parking slot. The roof of this metallic box juts out. After parking the car today evening I just opened the door and the damaged spot aligns perfectly with corner of the metallic roof of this box.
This Sunday was the first time the cleaning chaps cleaned the interior of the car. I'm pretty sure the door banged into the box (and kept banging into it as the boys moved in and out of the car while cleaning it). I don't know if it was an honest mistake on their part or carelessness despite knowing what will happen.
The car can't be moved far enough away because the neighbours' car park slot is right next to ours. And I can't really expect the cleaning guys to be as careful with the car as owners are, especially when they have to attend to 20+ cars a day. Such is life.
I think I'll just ask them to stop cleaning the interiors from now on (and hopefully renegotiate the monthly charge down by some amount).
spadix
Old 13th September 2011, 21:56   #2394
dot
dot's Avatar
Thanked: 714 Times
If this is the reason, maybe for future's sake, you can stick a rubber/soft material strip on the fuse box, at the position where it can make contact with the door. Hopefully that will be acceptable to your apartment's management!
Also suggest to apply some clear nail polish to the chipped area, so it can protect the spot till it is repaired.
Old 13th September 2011, 22:39   #2395
Thanked: 56 Times
Have a question - does the hazard light switch light up when hazard lights are switched on? It doesnt seem to do that in mine.
alto99 is offline   Reply With Quote
Old 14th September 2011, 09:39   #2396
Ace F355's Avatar
Thanked: 1,605 Times
I do not think it is supposed to glow when hazard lights are switched on. It glows only when we turn on the lights (parking/low/high beam)!
Ace F355 is offline   (2) Thanks Reply With Quote
Old 16th September 2011, 10:31   #2397
Need a price estimate about the following:
- Complete suspension bush kit.
- Clutch
- Brake Discs
- Brake pads
kumargandharva is offline   Reply With Quote
Old 16th September 2011, 11:07   #2398
manim's Avatar
Thanked: 386 Times
Post re: Honda Civic : Maintenance, Service Costs and Must dos
- Brake Discs
- Brake pads
Here are the amounts I paid way back in 14.04.2009:
Brake-Pads-Front - Rs.4,330
Brake-Disc-Front - Rs.4,480
(includes taxes, but w/o labour)
manim is offline   Reply With Quote
Old 16th September 2011, 15:03   #2399
smartcat's Avatar
- Clutch
- Brake Discs
- Brake pads
Clutch would cost you around Rs. 11,000.
smartcat is offline   Reply With Quote
Old 16th September 2011, 15:06   #2400
laluks's Avatar
Thanked: 8,106 Times
From HASS? Inclusive of Clutch Release bearing, Clutch and Pressure plate? Inclusive of Service cost?
laluks is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1406 3rd February 2018 09:55
