Old 9th August 2009, 19:25   #241
lalitk25's Avatar
If one buys a 12-14 lakh car, I dont see any reason why he/she cant afford to pay Rs 1000 every 24 mths to change wiper blades and save his windshield (atleast 8x more expensive) and more importantly maintain safety standards. Unless of course the owner is a real cheap skate and penny wise pound foolish.
Rgds,
Hi R2D2
I Also dont understand why people try to preach when they are really uncalled for. Without knowing all details your comments were really not welcome.
lalitk25 is offline   Reply With Quote
Old 9th August 2009, 20:01   #242
ImmortalZ's Avatar
Thanked: 164 Times
There is no reason to be offended. You aren't a cheap skate or you would've bought an Altis
Come on guys, lighten up. Why so serious?
ImmortalZ is offline   (1) Thanks Reply With Quote
Old 9th August 2009, 20:02   #243
R2D2's Avatar
Thanked: 1,823 Times
Originally Posted by lalitk25 View Post
Hi R2D2
Sorry lalit. Not sure why you took it personally as it wasnt aimed at you or anyone in particular. Just seen it happening too frequently with many folks including my friends and relatives. But then they arent half as enthusiastic or knowledgeable about cars as most TBHP members are. Hence if one were to step back and think, they'd probably realise what I said is true. If an owner likes to compromise on safety and risk scoring their windscreens it's their choice.
Rgds,
May be I am and that's why I bought one. But no compromises on safety, ever. I've change my 8 month old 9G Corolla's alloy rim + tyre after the rim got a 1.5" long and 1 mm deep score along the edge/lip and tubeless tyre sidewall slashed when it hit a grate whilst doing a U turn.
The tyre walla assured me the rim was ok but I simply dont take risks and replaced it. And the tyre was mounted by the Toyota dealer on the new rim. Total cost Rs 11,500. Just for my peace of mind. But then to each his own.
And contrary to what some may think, I certainly practice what I preach. Both wiper rubber blades replaced with a refill pack when the car turned 2 years old.
Rgds,
Last edited by Jaggu : 10th August 2009 at 16:05. Reason: back to back posts, use multi quote please.
Old 10th August 2009, 10:27   #244
lalitk25's Avatar
I reacted because I also never compromize on safty and never mind about cost which are worth for.
But then my wipers are not in the state of replacement which I got confirmed from the service guy.
Any way leave it.
lets enjoy driving our beauties and hare our experiences.
Old 10th August 2009, 15:58   #245
R2D2's Avatar
Any way leave it.
Thanks Lalit. Agreed.
Just a point I need to make; we folks on TBHP speak our minds and the truth with a view to help and guide fellow members and even casual readers (non members) who may stop by when surfing the 'net. For it is only when our diverse experiences and knowledge are pooled together that we begin to make a difference. It is this very active participation, enthusiasm and knowledge that has helped TBHP win new members, me included.
Cheers!
Old 25th August 2009, 01:36   #246
navpreet318's Avatar
Thanked: 894 Times
Well a very weird thing has happened.My civic has done 16k kms and now it requires a front brake change.I can see that the pads are worn off but these guys are saying that the discs have gone to the min thickness as well.
this is totally unacceptable IMO.
How can a car's brake discs conk off in 16k kms.I'm not racing the car or using it in rallies.
I've put up the issue with these guys but they're just saying that this is a wear and tear part and cannot be replaced under warranty.
Any heads up as to what i should do now?
Any of you had this kind of experience?
navpreet318 is offline   Reply With Quote
Old 25th August 2009, 07:07   #247
laluks's Avatar
Thanked: 9,669 Times
The same info was told to me at 30k to change both pads and discs for the front. But I decided to check out on my own, and came to a conclusion that the pads will last another 10k of sedate driving. Discs - no way, needs a skimming probably when I change the pads.
Hopefully your case is not of a bad part that worn out fast. Discs + pads for the front is around 11K.
Take it to a friendly M.A.S.S and ask a visual check. Honda A.S.S. in your area might have a service target for the month
As a matter of fact, my friends sparky had to change pads at 16k. When we went to collect the car in the evening, we were shocked to see more than 3/4th of the pad still good. A grin was the only answer on asking the service advisor, damages were 1k, hence did not bother.
laluks is offline   Reply With Quote
Old 25th August 2009, 13:08   #248
Thanked: 894 Times
Ok.thanks for the tip.i'll get it checked by a MASS.i visually checked the brake pads and about 5mm of the stuff is still on.
Old 25th August 2009, 14:03   #249
ImmortalZ's Avatar
Thanked: 164 Times
When your brake pads hit the minimum limit, you'll start hearing a squealing from the brakes as you apply them. This is a metal tab in the pad that warns you that it is time to change the pads.
16K KMs seems too early for a brake pad change, let alone a rotor change.
Old 25th August 2009, 16:00   #250
3. Ac auto start creates more sound than earlier.
This happens for me too. On idle, I have noticed that engine vibrates when auto A/C kicks in.. I am sure that this was not happening when car was new
4. Some rattles in center arm rest and height adjustable seat belt
Check the cup holder in side the center box. It gives some rattle for me. I inserted a small paper in between, and solved
swageo is offline   Reply With Quote
Old 25th August 2009, 22:54   #251
ImmortalZ's Avatar
Thanked: 164 Times
You may know that I've been struggling with a brake issue since my accident repair. The repair was completely cosmetic and minor. The issue with my brakes is that I don't have any response for the first 10% of pedal travel and a big lack of feel.
Yesterday, I noticed that my rear brake pads are worn unevenly. They are flush with the rotors only at the edge (the wheel hub). It looks progressively worn outwards. It's tough to put into words and tougher to photograph - the series of pictures I've taken are here : Index of /brakepads
The weird thing is that the pads look worn like this on both sides. The front, as the one pic in the collection shows, looks perfectly flush with the disc as it should.
Do your brake pads look like this? If they are perfectly flat with the disc, please help me build a case by taking pictures that show this. If not and this is normal with all Civics, I'll keep searching for the reason my brakes have gone all mushy.
Old 25th August 2009, 23:21   #252
laluks's Avatar
I'll get some pictures by tomorrow.
Is it that all your discs have scoring marks due to the pads. I have similar marks in the front ones
Old 25th August 2009, 23:39   #253
ImmortalZ's Avatar
Thanked: 164 Times
Yeah, all my discs are scored. I'm not surprised really considering the forces, speeds and temperatures involved. Besides, they aren't deep. If I run my fingernail across the disc, it feels uneven, not pitted.
Thanks a lot for looking, laluks.
Old 26th August 2009, 06:54   #254
laluks's Avatar
Its wearing out evenly for me, atleast from what I can see. The scoring is heavy in the front but lower at the rear.
I guess something to be probed in your case.
Check these pictures.
Front
Honda Civic : Maintenance, Service Costs and Must dos-front.jpg
Rear
Honda Civic : Maintenance, Service Costs and Must dos-rear.jpg
Old 26th August 2009, 12:31   #255
ImmortalZ's Avatar
Thanked: 164 Times
Oh man, that is what I feared. Anyone else care to chime in with pics?
I'll have to think about my options now.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1481 2nd June 2018 12:26
