Old 1st April 2012, 19:39   #3121
Thanked: 229 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by smartcat View Post
Odd! I have a 2007 Civic and I have an Aux-In port.
Anyway, for about Rs. 1,000, you can buy a USB FM transmitter from any car accessories shop. Your USB stick containing MP3 songs goes into the FM transmitter which in turn plugs into the 12V socket. The device then acts like a mini-FM station - just tune in you radio to the frequency of the transmitter and you are good to go.
Yes, for the day the CD player laser/carousel conks. Till then I just use CDRs, take a few minutes to burn/re-use.
sandeep108 is offline   Reply With Quote
Old 1st April 2012, 20:35   #3122
sumeethaldankar's Avatar
Thanked: 1,072 Times
Infractions: 0/1 (7)
Default Re: 1,00,000 kms Milestone
Originally Posted by manim View Post
Reached a Milestone with 1,00,000 kms, in 4 years and 8 months.
Hello,
Did you ever have to replace the engine mounts which have been reported by many people ? Also did you face any major repiars related to suspension and steering components.I would certainly love to know if you have any particular driving style as i would like to my car last as long with min trouble.I was suprised to read that GTO's Civic had to need a mount replacment in just 30K hence i want to know is there any special way you drive the car.
thanks
sumeethaldankar is offline   Reply With Quote
Old 1st April 2012, 20:52   #3123
manim's Avatar
Thanked: 386 Times
Post Re: 1,00,000 kms Milestone
Originally Posted by sumeethaldankar View Post
Did you ever have to replace the engine mounts which have been reported by many people ? Also did you face any major repairs related to suspension and steering components.
None whatsoever!
Maybe I am lucky, but I had none of the problems many have reported here, so far.
I will be finishing 1,05,000 kms by the end of April.
I am planning a long drive to Goa in May (via Bangalore) and will be doing 2,600+ kms within a week. I will be travelling with my family and hope the car will be 100% reliable.
But I do have my worries as to the reliability, as the car gets older. It will be 5 years old in May 2012 (after all even the Space-shuttle had failed killing Kalpana-chawla).
I will reply to this later.
manim is offline   (1) Thanks Reply With Quote
Old 1st April 2012, 23:24   #3124
spadix's Avatar
Thanked: 185 Times
Originally Posted by razor4077
A question around the Civc's rear suspension issues. What's the technical difference between the pre and post facelift models' rear suspensions? Stiffness of the springs, or something more? Since the newer civics don't have the problem of scraping every bump, was wondering if switching to the newer, stiffer OE springs would solve the problem for the older breed.
I've never driven the older Civic (except for a couple of short TDs), but the facelift doesn't solve the under-body scraping problems as much as good technique does. At the end of the day, it is about the combination of wheelbase and GC and unscientifically designed humps (geometry). At best, the new suspension probably allows you to carry 2-3 kmph more speed over a hump.
Originally Posted by swarooppatil
Today while driving back home in the afternoon, I noticed that the engine revs suddenly shot up by around 800-1000 rpm for a moment and then settled back again. This was moments after an up-shift, and lasted only for a fraction before settling down.
It has happened multiple times to me especially when I'm shifting up in a hurry or at very high revs (usually highway driving). I can't reproduce it at will, though. It just happens every once in a while, randomly. I've seen this behaviour from almost all the non-carb petrols I've driven so I didn't really give it more than a passing thought.
spadix
spadix is offline   Reply With Quote
Old 1st April 2012, 23:39   #3125
smartcat's Avatar
Thanked: 12,612 Times
The problem is not really scraping of bumps, but actually the soft suspension running out of play when the boot is loaded & there are 2 or 3 passengers in the backseat. When the suspension squats down, ride quality is slightly better than that of a bullock cart (because the rear tyres have no room to move up and down).
Do you face this problem in the newer Civic?
smartcat is online now   Reply With Quote
Old 2nd April 2012, 08:51   #3126
spadix's Avatar
Thanked: 185 Times
Exactly. Or, put in another way, that suspension upgrade was never intended to solve *this* problem, but the other one you pointed out.
What I've seen with my car is that when there is a full payload of 4/5 passengers and/or luggage, the rear springs hit their bump-stops more often (as is to be expected), but the overall ride is decent. People are always happy with the ride, and these are people who are used to the rear ride quality of cars like the Amby and Indigo which in my opinion offer amongst the best rides on bad roads. That said, bumps filter through.
However, handling is a completely different story. On 2-lane undivided highways, especially on non-ideal road surfaces where the rear end tends to skip and skate, quick overtaking (move out, accelerate, move back in while still accelerating) makes me feel the rear is completely disconnected, lethargic and having a mind of its own. It's really like the car wants to be split at the B-pillar.
I don't experience this behaviour when it's only me or only two of us in the car, but at this lighter load, the rear (while keeping its line intact generally) wallows like crazy over undulations, and skips and skates over sharp bumps/ruts/ridges anyway.
I don't know if a tyre upgrade alone will alleviate these things. I could, for all I know.
spadix
spadix is offline   (1) Thanks Reply With Quote
Old 2nd April 2012, 11:00   #3127
civic-sense's Avatar
Thanked: 763 Times
None whatsoever!
My worry too. One reason why I bought the Honda was for its reliability. And I wanted to keep it for alt least 5 years more when I bought it used when it was aged 3. Last 2 years were fairly uneventful sans an engine mount change but I am starting to look for upgrades/downgrades already. I do not want to let it go, but can't afford two cars too. Am pretty much happy with the car except for the steering at high speeds. Okay on a straight line, but on twisties it feels a tad too light.
Never felt the rear misbehaving in my car, except for some pitching when loaded. I rarely have a passenger or luggage at the rear, maybe that is why I do not get to experience this.
civic-sense is online now   Reply With Quote
Old 2nd April 2012, 11:02   #3128
Thanked: 229 Times
Engine mounts, suspension, steering and belt tensioner were chronic problems for the older Civics. From 2007-08 onwards, they made quite a few improvements all around.
@spadix: I feel your problems may stem from badly aligned tires as generally the car holds the road very well. I have seen huge improvements in all areas (ride quality, GC, braking, grip, etc.) simply by upgrading my tires to 205/65/15.
sandeep108 is offline   (1) Thanks Reply With Quote
Old 2nd April 2012, 11:30   #3129
Thanked: 56 Times
This exists in new Civic with full load.
alto99 is offline   (1) Thanks Reply With Quote
Old 2nd April 2012, 17:31   #3130
spadix's Avatar
Thanked: 185 Times
Yeah, at low loads all I have experienced is the same pitching/wallowing. Do try when fully loaded.
It is possible like @sandeep108 has said that there's something wrong with the alignment of my car's rear wheels, though.
I'll be the happiest if the issues sort themselves out with just WA/WB + tyre upgrade. I have to get the former done soon now. It's due. The latter won't be due for quite some time as the car has done only 24767 kms to-date on the stock tyres, and its running has come down drastically after shifting here (in March it saw < 400 kms :().
spadix
Old 2nd April 2012, 17:48   #3131
Thanked: 229 Times
If the alignment if off or done badly, or a shunt has not been repaired (aligned) properly, it can create huge issues in modern cars. I remember when the alignment was badly done on my OHC, the car behaved almost like you describe.
Old 3rd April 2012, 15:02   #3132
spadix's Avatar
Thanked: 185 Times
Originally Posted by sushrutha View Post
No growl as one would expect from a CAI filter.
But a NICE mild hissing sound when accelerating, but noticeable only in silent/calm conditions, and also a lil bit sound when the revvs is above 4K RPM.
I hear a supercharger-like whistle/hiss whenever I accelerate hard. I haven't observed the revs but I am sure I have heard this even in the 3k to 4.5k rpm range.
This sound is audible only if windows are rolled up, AC blower is operating almost silently, audio is turned off and there is silence everywhere. So I've usually heard this only at night or out on the highway (incidentally, the situations where hard acceleration is possible often).
So if we're talking of the same sound, I think it comes stock.
I would suggest to all AT owners to replace the AT fluid/oil every 2-3 years or every 40k km (whichever is earlier) as under our conditions, it deteriorates much faster. I got a slight clutch type burning smell in my AT after a little spirited driving on a hot day. I found this very odd, since I had never got this smell.
I then read up a bit (How often should the automatic transmission fluid... Yahoo! Autos being one of the links) and asked the SA to change it, even though he said as per KM reading it was not necessary. Our stop/go traffic and heat create tough environment for the ATF. Now the smell is gone after the change. I intend to change it every 2-3 years from now on (if I keep the car that long).
Surprisingly, in the situation I described just above, I can sense a similar kind of smell - of something metallic overheating - especially when ambient temperature is a bit high or if the car's been driven hard for a long while. Mine is an M/T. So it's possible that what you say extends for the M/T fluid too (assuming it's the same smell).
What is surprising to me though is that this started happening when the car was just 4-5 months old. I first experienced this in December 2010 (< 5 months old, odo reading < 9k kms) when going up the Tirumala ghat. I distinctly remember both the driver's side and co-driver's side footwells getting really warm too. There were 6 people and luggage in the car so at the time I simply chalked it up to the stress of uphill driving with such load on what was still an engine that was just about finishing its run-in.
However, I've observed the symptoms multiple times later. The SAs as usual said it's nothing to worry about.
spadix
Old 3rd April 2012, 16:20   #3133
gaurav_chopra04's Avatar
Thanked: 534 Times
Gave cousin's civic for service on 28th March for 60k service at ring road Honda. The OD had 65k on the clock, 11k since last service. Although, we were to get the service done at 15k kms, due to some AC issues and other service needs, gave the car in early. The service Adviser was Rizwan, Asked for Tarun (who helped at the time of engine mount, nice guy) but he was on leave.
Problems reported:-
1. Compressor tripping frequently in bumper to bumper traffic, and on traffic lights. When the car is on move no issues with the cooling.
The engine temperature was noted to be fine and it wasnt increasing in bumper to bumper traffic. Radiator, condenser fans were working fine. Coolant was also in good nick.
In btw, on 3 previous trips to Ring Road Honda where our driver went to the ASC with the car, the problem was noted to be with leaked cooling coil, kaput compresser and low gas.
Gas was checked in front of me and it was fine, cooling coil cannot be leak as the gas was last filled in november would have leaked by now if there was an issue with cooling coil. Compressor works fine in moving car so it can probably be the clutch (when you hear the tuk tuk noise of compressor switching on and off, thats the clutch) of the compressor but not the entire compressor itself.
Before all this, codes were checked in ECU but no issues were found.
Last but not the least it could be the dirty condenser but then I got it cleaned a day before going to ASC, but it still didnt sort the issue.
2. issue: car pulling left despite tire change, the problem is there since day one but there is no uneven tire wear. Answer from Adviser while he was sitting inside the car making job card.
Adviser: Sir, you have for aftermarket alloys (its stock civic sports, with stock alloys painted white by Honda itself).
Me: whats wrong with the aftermarket alloys?
Adviser: they always have issues and the alignment /balancing is never put right.
me: oh I see, and whats with Honda alloys.
Adviser: they are checked for quality and cannot have issues.
me: thats great then, please come out of the car and check the alloys.
Adviser (comes out of the car and see the alloys): Oh they are stock, but you painted them white.
me: Are you new here
Adviser: no
me: if not then you seriously need some training lessons, I want to meet the person who recruited you to this job. These alloys are completely stock, they came in white from factory itself. Why do you guys always give illogical answers without even checking the problem.
Adviser: Sir, i will get this issue checked, any other issue?
3. Replace wiper blades rubber
Work carried out
1. Engine oil change
2. oil filter change
3. Air filter change
4. transmission oil change
5. brake/clutch oil change
6. front bumper removed and condenser cleaned thoroughly. Electrician took a TD of about 5-7kms in bumper to bumper traffic and big traffic lights. Issue resolved to an extent but the results are still not satisfactory. Will get the car checked again in a week or so.
Work not carried out
1. Wiper blades rubber. Why?
Adviser: these are aftermarket wiper blades, cannot replace the rubber
Me: they are stock blades, its not possible
Adviser: no they are not
Me: compare them with any other civic, they are stock, cant you see
Adviser: no sir, I checked.
Me: ok, forget it (I cannot argue with an idiot like you, they are stock wipers)
Paid About Rs. 6,700 for the work carried out and left.
On 30, my cousin was in M2K market in rohini and the car's ignition lock went kaput, the steering was not centered and was locked. He called me at 6 and I went to the market with the second key but all the efforts to start the car went in vain, the key would just not move. Finally called the Honda helpline and they asked us to call Mondial helpline. Gave explicit instructions to Honda and to Mondial that the car cannot be towed until the lock is broken. So, they need to get a technician who can take care of the lock. Mondial towtruck came 2 and a half hours later at about 8:30 and that too without a technician. Result: car cannot be towed
Called the helpline again and they said that it will take another hour for the technician to come and I said please arrange it for tomorrow morning as it was already 9:30 and the car was parked at safe place. Gave Rs 100 to a vodafone store guard to keep an eye on the car and also gave him my number incase there is an emergency.
Left the place at about 9:30 and a denter called us 5 mins later that he is at the spot. Thanks to a service adviser at Wazirpur Honda who arranged for a denter to get to the spot. Went back and the denter was waiting. We opened the car and the denter took out the cover of the steering rod and broke the locks that doesnt allow the steering to move left right. He also separated the ignition lock with immobilizer from the other lock where the tip of the key goes and starts the car. He used first key to get the immobilizer working and 2nd to start the car. Bingo, the car started and we could go anywhere we want. He charged Rs.650 for the same.
Another reason to keep the second key with you on long trips, if the ignition lock goes kaput you will need the second key despite the fact that the lock is broken. Else, you will need to tow the vehicle.
Gave the car for ignition lock change at Ring Road Honda and had a word with Tarun. He checked for new lock set in store and told me that if its not available it will take about 15 days for the lock to be available as Honda is closed for 12 days for stocking (counting or something). He added that Honda is closed twice a year for 12 days for stocking, once in April and other in october. Luckily the lock set was available in stock and Tarun opened the job card. I asked him to check the wiper blades and replace them if possible. He said it can be done.
Next day got a call from Honda for feedback for service and I told them that the experience was pathetic and that the car is at ASC for lock change.
Lady: Sir, the report says that you refused to change the wiper rubber and I was shocked.
Described the lady the attitude if the adviser and how much I insisted on changing the wiper rubber. She apologised and said she will look into it.
Later Adviser Rizwan called and checked who was handling the car but the shameless fellow didnt even apologise.
Finally, Tarun called to say that the car was ready and I can pick it anytime. Went to the ASC and the new lock set including ignition, driver door and boot lock was changed along with new set of keys. The chip inside the keys were original chips but their code was changed from Honda. The wiper rubber blades were also replaced.
Total cost: Around 7k for lock and 1700 labour. Remaining 1300 for wiper blade change. Total damage was Rs.10,065. I would say its not bad because the lock set of Camry (old model) costs about 14k and that of cedia costs about 18k (no immobilizer).
The experience with Rizwan was pathetic but that with Tarun was v good. So, at the end your service experience completely depends on the adviser.
gaurav_chopra04 is offline   (2) Thanks Reply With Quote
Old 3rd April 2012, 17:08   #3134
By kaput what exactly went wrong with key ie was it stuck inside or was not going in the key slot or was not turning.What was the cause of the same happening ?
thanks
Old 3rd April 2012, 17:19   #3135
Thanked: 534 Times
The main key with remote was being used. My brother said that the key refused to go in. He pushed it a little (very little force) and it went in but then the key was not turning. When I got there with the second key, it refused to go it and we didnt apply any force, but the main key (worn in 3 years/65k kms) was able to go in with little force.
The denter said that its the gears of the lock that were damaged. It usually happens with rigid use of key while inserting and taking it out. He said one needs to be gentle while inserting and taking out the key. However, this is the first instance in any of our cars. Rest, dust and wear and tear also plays its part. Only thing we can do is be gentle with the keys.
The adviser at Ring Road Honda said that its not a common issue with civic but definitely with the new City.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1416 24th February 2018 00:17
