Old 12th March 2014, 13:23   #5326
laluks's Avatar
Thanked: 7,927 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by rugsrags View Post
Have got the car sent to the service center. Had asked them to send a technician home but they were like you can still drive the car. Asked my driver to drive it slowly to the workshop.
Haven't yet heard from them they are checking the car out and will get back to me with the diagnostic. The only thing as yet is that they have identified that the wheel is getting jammed (Einsteins that they are) lol
Lets just hope it isn't something major.
Let's wait for the Einsteins
Can you identify the sound you heard as Squealing/Metal scrapping metal/Humming?
Humming means wheel bearings are in trouble. This will also lead to heating
laluks is offline   Reply With Quote
Old 12th March 2014, 18:41   #5327
patron's Avatar
Thanked: 106 Times
I am getting a 'grrrr...' noise when the AC is engaged. A.S.S said it was the serpentine belt that is to be replaced but nothing about the compressor.
The noise seems to be coming only when the compressor kicks in. The cooling is perfect as usual but this noise is quite worrisome and irritating. My mechanic says the compressor is gone and needs to be replaced along with the condenser. I was not very sure so went for a second opinion with a professional AC mechanic. They confirmed the same and demonstrated it by disconnecting the compressor power and the noise was gone, so was the cooling (duh!).
I don't know the internals but if a compressor malfunctions won't the cooling get affected too?
One other thing is I see a noticeable drop in power when the AC is on and the fuel efficiency is also getting affected. I don't know if they are related or not.
Replacing the AC and condenser will put me back by almost 30k.
Is this a common problem? Please advise if I should try and get the compressor repaired rather than replace.
patron is offline   Reply With Quote
Old 12th March 2014, 19:20   #5328
rugsrags's Avatar
Thanked: 118 Times
Well the noise was coming on a stationery car and it was the noise of metal cooling. No guesses there since the heat was tremendous.
The ASS on the other hand are still clueless and are waiting for their senior technician who was on leave today so the car is still with them. Apparently they've never come across this issue till now. I didn't realise it could be so serious. They're also saying that the calipers are fine they've checked but there's some issue with the brake piston but they'll only comment on it tomorrow now since the wheel is pretty much jammed!! Also no sign of any damage or bump ( I should know since the car was parked and it was working fine before that) so even they've ruled out any accidental damage.
rugsrags is offline   Reply With Quote
Old 12th March 2014, 21:34   #5329
sumeethaldankar's Avatar
Thanked: 1,049 Times
Is this cost quoted by HASS or by the independant garage. Typically outside HASS you can get any job done at approx half the price of whatever HASS charges.
sumeethaldankar is offline   (1) Thanks Reply With Quote
Old 13th March 2014, 10:19   #5330
patron's Avatar
Thanked: 106 Times
This price is not from HASS. It is from an independent AC service center for an Civic OEM compressor.
Old 13th March 2014, 10:47   #5331
Just as Honda OEM brakes/ OEM engine mounts cost a bomb i guess the OEM compressor would be expensive too. People have used non OEM brakes and mounts in their civics and are still going strong. I may get brick bats for this but maybe try and see if you can get a after market "alternative" for same.
Also look up t-bhp directory for reputed garages and get a another opinion regarding same.
sumeethaldankar is offline   Reply With Quote
Old 13th March 2014, 15:26   #5332
rugsrags's Avatar
Thanked: 118 Times
Regarding the jammed rear tyre the workshop just got back to me. They say that the piston boot and calipers of the brake will be changed along with rear brake pads and brake oil. Along with this they are also talking of changing the front brake pistons and calipers. The quotation provided is a good 18.5k.
Old 13th March 2014, 15:32   #5333
I am again repeating my statement from the previous post "Typically outside HASS you can get any job done at approx half the price of whatever HASS charges" If this is being quoted at Hass you could probably done it at less from a trusted independant garage.
Old 13th March 2014, 15:46   #5334
rugsrags's Avatar
Thanked: 118 Times
Well after getting the quote i spoke to my garage. They were like the part is not available with them and since its a piston boot it would be better for a genuine part to be sourced from the company itself. My garage just said that the front Boot and calipers don't need to be touched but since the front piston and calipers are only around 3k i'm thinking might as well go ahead with it. The main cost are the rear brake pads which are around 7k.
But even the HASS has said it will take them 4-5 days to source the part!!
Old 13th March 2014, 20:57   #5335
Thanked: 192 Times
Do try with reputed private service stations as well. I have personally experienced good service at Bosch for my civic.
I'm sure teambhp directory can provide many such pointers.
harishpr is offline   Reply With Quote
Old 14th March 2014, 09:49   #5336
Thanked: 226 Times
My civic's remote key is giving me problems. Sometimes the car refuses to lock/unlock. 7 years hence, could it be the remote battery? Can anyone help me out with the remote cell make etc and steps for disassembly of the key?
coolkurt is offline   Reply With Quote
Old 14th March 2014, 11:19   #5337
sgiitk's Avatar
Thanked: 3,792 Times
Infractions: 0/1 (5)
It is in the users manual. You need to undo a small Philips screw, prise apart the two halves, and then replace the battery. I do not have my Civic with me today. I think the battery details were also posted here somewhere.
sgiitk is offline   (1) Thanks Reply With Quote
Old 14th March 2014, 11:44   #5338
laluks's Avatar
For the Cell change of the key fob please refer this post (Post No. 4968 of this thread)
http://www.team-bhp.com/forum/long-t...ml#post3276827
laluks is offline   (1) Thanks Reply With Quote
Old 16th March 2014, 11:49   #5339
vcx
vcx's Avatar
Thanked: 36 Times
I recollect seeing the honda keys silicon covers in various colours( ebay India) that would be an additional protection to also avoid any moisture/ wear & tear.
vcx is offline   Reply With Quote
Old 19th March 2014, 09:04   #5340
Thanked: 226 Times
My 2006 Civic did not come with an aux-input. The experts added support by connecting a mp3 aux cable which comes from the back of the HU. All I have to do is plug the cable into my device to play music. However, this arrangement is cumbersome as after a few months, the cable gets damaged and the only way out is to change it, by cutting and joining the wires.
Is there a solution wherein we can have a proper aux port fitted somewhere, thereby all we need is to keep.replacing the aux cables, eliminating the need to join wires etc?
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1403 11th January 2018 14:44
