Old 6th April 2014, 18:11   #5386
sgiitk's Avatar
Thanked: 3,866 Times
Infractions: 0/1 (4)
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by coolkurt View Post
Get the Amaron Pro Hi PR-0055B24LS
The only Amaron Battery for the Civic. I got the same last year.
Old 10th April 2014, 11:46   #5387
vcx
vcx's Avatar
Thanked: 36 Times
Hi all, I have install the AC filter( (in the compartment near the glove box) bought from US into 2012 Civic , could one advise the interval for cleaning /replacement? Also any suggestions if this AC filter is available in India?
Any suggestions on adding K&N Performance air filter to Civic and its benefits, does it void the warranty?
vcx is offline   Reply With Quote
Old 10th April 2014, 18:20   #5388
sgiitk's Avatar
@vcx; I bought one (FRAM) mail order on eBay. I hear the Accord has the same, as do many models of Toyota. If you look into the threads of Dust/Pollen Filters as well as mine on Alabaster Silver Civic you will find the details. As for filter life, they specify 20,000km on the City, so must be about the same. Inspect the filter and decide. A lt may depend on the percentage of time when you have 'outside' air open.
Old 11th April 2014, 17:30   #5389
Thanked: 243 Times
I'm still undecided whether to get my civic's clutch replaced or not. The mechanic says it's hard but no that hard. I've got a hard n squeaky clutch , reduced mileage, although slotting gears is okay for now.With 90k on the odo, I think it's time to go in for a replacement. Honda A.S.S are quoting 30k for the entire replacement, hence I'm looking at a FNG to do the job.
Now the question is, which OE clutch replacement brand should I trust? My mechanic says PHC Valeo, if I can get my hands on the original. There is another brand CEEKAY which is pretty well known too. Any help?
coolkurt is offline   Reply With Quote
Old 12th April 2014, 12:18   #5390
sgiitk's Avatar
See it you can find the OE, I guess it may be Nissin. Then go out of the ASS tamasha.
Old 13th April 2014, 00:01   #5391
Hi Guys,
Posting on this thread since the amount of knowledge about Civics on this thread is insane and the two threads (this (Tein Super-Street suspension with EDFC for the Honda Civic) and this (honda civic suspension)) that I found on Civic front suspension issues were quite old.
The issue is the combination of India's lack of standard speedbreakers and Civic's low GC.
Today, I went over a really bad speedbreak, this one was V shaped if that makes sense. I was at no speed at all and barely crawled my way over the bump.
However, the left suspension gave way and I could feel a noticable THUD. Upon further inspection later, I could see some leakage that was happening just below the front left suspension.
Can anyone shed light on what this may indicate and how much fixing it may cost ?
aarkay28 is offline   Reply With Quote
Old 13th April 2014, 11:57   #5392
drsingh's Avatar
Thanked: 483 Times
Thanks but I've tried using FM transmitters but the quality is just not the same as with a physical or a Bluetooth connection.
This is what you need.It will play from Micro SD,USB,AUX in,Bluetooth sources.Will also charge your phone from the USB port.
This is just a decoder and the output has been soldered into the AUX in of the installed ICE .
drsingh is offline   Reply With Quote
Old 13th April 2014, 12:30   #5393
Thanked: 243 Times
On their site, PHC claim to be OEM for Honda. And I've heard elsewhere DAIKIN exedy is the OEM brand. Hence the confusion. I thought somebody would have got their clutch replaced outside the A.S.S setup, hence I posted my query here.
@DrSingh
Thanks but I went it for a custom aux installation. Now I have an aux port so it's a lot more convenient.
Old 13th April 2014, 13:35   #5394
sgiitk's Avatar
Most manufacturers try to have alternate suppliers, so both may be right.
Old 13th April 2014, 14:59   #5395
Thanked: 243 Times
Yes that's true. But which one is better? PHC is softer, while DAIKIN is a bit hard and stiff or so I've heard. Longevity wise it's more or less the same, depends on the driver imo. My stock clutch is good after 90k kms, only now I'm having a drop in mileage.
What should I do with the flywheel? Any suggestions? Batra Auto at Ashram, Delhi is pretty reputed and he says no need to replace, one can get it resurfaced.
Old 14th April 2014, 09:11   #5396
Thanked: 243 Times
So I finally went and bought the DAIKIN Exedy clutch set. The folks at Batra auto said it's OEM for Honda. Here's the breakup for the same.
Clutch set - 4550
Bearing - 750
3 ltrs gear oil - 580
The flywheel doesn't warrant a replacement, that's what the experts say. Going in for the works today.
Old 14th April 2014, 10:17   #5397
sgiitk's Avatar
@coolkurt; at 90,000km when opening up I will go for a new disk just as a precaultion. Of course refacing should also work.
sgiitk is offline   (2) Thanks Reply With Quote
Old 14th April 2014, 12:07   #5398
Originally Posted by yogeshnagpal View Post
Guys, A friend has recently brought a Civic 1.8S MT, late 2006 model.
It seems that there is some oil leak from underneath the car. Attached the pic of the leak.
Can someone please provide any pointers as to what could be the cause of this leak?
In all possibility it appears to be the hydraulic power steering. I had the same problem with mine. It is either the pipe that returns the fluid or the o-rings.
If it is o-rings - it is about 9k. However, if it is the pipe, it is about 12k.
dphilip.iitk is offline   (1) Thanks Reply With Quote
Old 14th April 2014, 12:26   #5399
Jaggu's Avatar
Thanked: 8,585 Times
Best to lift the car and check, from the color seems like engine oil, is the filter fixed properly? Also check if the valve cover packing is intact. In our Crv valve cover was leaking and dropping oil like this.
So best is to go underneath or peak from above and find the origin.
Jaggu is offline   (1) Thanks Reply With Quote
Old 14th April 2014, 12:48   #5400
yogeshnagpal's Avatar
Thanked: 81 Times
Thanks guys. I'll point him to this thread and ask him to check for the things you mentioned.
Much helpful!
Cheers,
Yogesh
yogeshnagpal is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1481 2nd June 2018 12:26
