Old 8th September 2014, 11:21   #5776
rr_zen's Avatar
Thanked: 265 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by laluks View Post
On September 2008, while I was returning from Goa I had run over a flat stone at high speeds. One alloy got a crack, hairline, I went to Dakshin Honda and ordered a spare alloy.
They sourced it in a weeks time and I paid 7150, as simple as that. Now I read from your posts life is not so easy
Anyways here goes the picture of the new alloy I sourced
Now I have six wheels
Have you been able to install the new wheel successfully onto the car or face any issues ? From the pic, I see the price is about 7k and this is for the S variant alloy wheel. Mine is the V variant and has a slightly different design. Don't know if the price for it would vary much from what you have paid.
rr_zen is offline   Reply With Quote
Old 8th September 2014, 12:53   #5777
laluks's Avatar
Thanked: 9,668 Times
This was in 2008. Cost mentioned was in 2008.
I had no issues in anything, it is just like any of the other 5 alloys which came with the car.
I just went to HASS told them I needed an alloy since one developed a crack, only question asked to me was do you want to claim insurance, I said no. Then the service advisor checked for the part number, checked with spares, since it was not readily available, placed an order and I picked it up after a few days.
Just like any parts, this wheel fitted as it was built to.
I do not understand the confusion here, the alloy wheel has a part number, and placing an order for it should get you the part. Is it different these days?? If I can source one for S, you should be able to source one for V
laluks is offline   Reply With Quote
Old 8th September 2014, 13:15   #5778
rr_zen's Avatar
Thanked: 265 Times
No confusion. Just curious about any price difference between the two models, that's all.
Old 8th September 2014, 21:52   #5779
shuvc's Avatar
Thanked: 286 Times
I might need to change brake pads/discs.
There's quite a bit of vibration when braking from high speeds. Braking from 100 odd is not an issue.
Called up an auto parts store. These are the quotes:
'Honda OE' front pads - 2200 pair
'Honda OE' rear pads - 1700 pair
'Imported OE spec' front discs - 3500
'Imported OE spec' rear discs - 2800
How do these prices sound?
Any other alternatives? Any places I can buy online? Or order from some reliable shop to be shipped to Kolkata?
Any feedback on FBK brake pads? These are Thai make.
http://www.ebay.in/itm/like/fbk-fron...essories_parts
shuvc is offline   (1) Thanks Reply With Quote
Old 9th September 2014, 00:26   #5780
sumeethaldankar's Avatar
Thanked: 1,134 Times
Maybe you should try disk skimming first before going for a disk replacement.As per other bhpian's the prices seem right.
http://www.team-bhp.com/forum/long-t...ml#post3142084
sumeethaldankar is offline   Reply With Quote
Old 9th September 2014, 08:25   #5781
Guys i am facing a really really weird problem with the civic and i really really hate it when these things happen to me.
Today while driving from office to home i found the rear door locks were getting activated.The rear locks only would lock unlock lock unlock several times while driving.
A google search shows crv has a actuator which causes the same.Has anyone faced similar issue ?
Old 9th September 2014, 12:17   #5782
rr_zen's Avatar
Thanked: 265 Times
Just spoke to the guy at HASS and he has asked me for the chassis number of the car. Said he will let me know the availability and cost tomorrow.
Just heard from the guy at HASS. Looks like the alloy will cost 6.3k INR and will take around 15-20 days for delivery. Will be placing an order soon.
Old 9th September 2014, 14:25   #5783
laluks's Avatar
If at all you happen to visit this store, can you get more details as to make etc, a picture would help a zillion times.
I am on the look out for pads
Old 9th September 2014, 20:17   #5784
shuvc's Avatar
Thanked: 286 Times
Compared the discs with a fellow bhpians 5yr old Civic today. The discs on my car have some rusting around the edges. However, the disc smoothness was similar in both cars. We noticed that my front right disc seemed to have some gaps in between the 'shiny' portions. Possibly the pad is not fully in contact. I doubt if it's a warped rotor. Can't seem to recall major stresses on the rotors. Seems more and more like a pad replacement situation.
Doubt if I'll go there
I'd ideally like to explore reliable online options. Even Amazon.com is under consideration. But the Civic models there are US specific. EX, DX etc. Would you know which car model I should select so that the pads will be a direct fix on the Indian Civic?
Did you check the FBK brakes link I posted above?
Old 9th September 2014, 20:18   #5785
Originally Posted by sumeethaldankar View Post
As i had earlier reported the display was not coming for the fuel gauge, speedo and the temp.....
Bad luck the display is off again.To fix permanently i was told min 15k from one garage guy.My regular garage man is yet to come back to me with a quote for same.I shudder to even think what Honda will quote if i take the car to them.
Old 9th September 2014, 23:43   #5786
manim's Avatar
Thanked: 393 Times
Question re: Honda Civic : Maintenance, Service Costs and Must dos
Is it the cost to replace some internal electronics or will the visible display itself to be replaced?
manim is offline   Reply With Quote
Old 9th September 2014, 23:47   #5787
shuvc's Avatar
Thanked: 286 Times
Considering this set.
Any inputs on Wagner?
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Old 9th September 2014, 23:57   #5788
Its the quote of a second hand speedo meter unit.
Old 10th September 2014, 07:44   #5789
Thanked: 243 Times
I'm giving my car for service today..clocked 96k kms so it's going to be the 1,00,000 kms service. Is there something important that Ive to keep on mind, besides the things mentioned in the manual?
The spark plugs will be replaced this time I think, so that's going to be a major cost.
coolkurt is offline   Reply With Quote
Old 10th September 2014, 12:29   #5790
Thanked: 243 Times
Just got a call from the folks at Southend Honda, mathura road. Every things seems fine except that they say the Power steering pump and the hose has a leak. I have been quoted an alarming 12k for the hose and 16k for the pump plus labour. This is blasphemic. The 1,00,000 service only is costing me Rs 14000, including the cost of the spark plugs replacement.
The power steering leak doesn't seem to be too serious as the fluid level in the reservoir is quite stable. I don't trust the
Honda report as of now.
What should I do?
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1481 2nd June 2018 12:26
