Old 28th September 2014, 15:46   #5821
sgiitk's Avatar
Thanked: 3,814 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by sixthsense View Post
I want to change the back ones as well.
The rear last for at least four times the distance. Only point is at the five to six year mark they may de-laminate. This is based on my experience with drums, where the glue fails at this point.
sgiitk is offline   (1) Thanks Reply With Quote
Old 28th September 2014, 15:52   #5822
sixthsense's Avatar
Maybe they aged as you said above. Anyway as i'm taking her to the highway next week, i got the rear replaced by HASS and costed my 7k for the rear break pads. I manually inspected the old ones and they were less than half the thickness of the new ones, so i guess they were really worn out.
And from the day one i did not felt very confident about the braking. After the new pads, i certainly noticed the change and the braking i can say is optimum now.
sixthsense is offline   Reply With Quote
Old 28th September 2014, 17:19   #5823
laluks's Avatar
Thanked: 8,133 Times
Originally Posted by laluks View Post
Now that I have completed 3000KMs with the new pads, Initial 1000KMS in city driving and the rest 2000KM on highways, at some good speeds and related braking needs, with drives of 700+ KMs in a stretch, twice, the results can be shared. These conditions have taken the tests on the pads as required in almost all possible scenarios that the pads are supposed to work.
The results are positive, and I see no major differences between the OEM pads and the ones I experimented as on date.
But there are a few observations
1. During Installation, the pads locking edges had to be filed a little for easy sliding for the pads placement
2. The discs are slightly hotter than before, attribute that to the ceramic compound and more friction considering the OEM pads were metallic type.
3. The wear of the pads seems at this point similar to the OEM pads, but a lot of brake dust is generated pointing that the pads are wearing more in relation to the discs.
About the pads,
The pads were made by a company called TNG. Had read some reviews with mixed opinions before installation. So idea was to experiment in city before concluding that they could be used in high speed drives on the highways. The city experiments for 1000Kms over a span of 1 month gave me enough confidence to take it to highway drives.
The front pads MRP was Rs 1050, finally obtained for Rs 900.
Result - I am happy with the performance till now. The pad change was a complete DIY.
Note: Let us not get into debates on costs vs safety, as enough precautions and experiments/trials and experience were considered before this post
11000 KM update, the pads are holding up well. I removed them for cleaning today. It has no breakages / chipping as I feared. The discs are also smooth, so all in all does its job well.
I am happy with the performance the last 11000 Kms. Looks like it will do twice as much at this point - a 30K+ is the expectation at this stage.
I changed the rear too with TNG today. The rear pads were a direct fit. No filing was necessary. Let us see how it fares. I will update the results.
Completed 15K with TNG front pads.
There was a spirited run of 2500Kms thrown in which took a toll on my Yoko dbs.
Good for another 5K, just 15K done till date
It seems it took a toll on the TNG front pads as well. Earlier going by the wear was expecting something like 30K, but the spirited drive has shaven of almost all of what was remaining !!
Today took some time to open the brake setup and check the pads.
New ones normally have some 11 mm of braking material, after wearing of 8mm it should be replaced
ON measuring TNG pads which have done 15K on date,
Front Right pads shows 3mm remaining
Front Left pads shows 2mm remaining
Comparison of 15K done TNG with new pads
You can push these pads, on normal run may be another 1K, but decided to change them, why risk?
Observation:
1. No chipping of brake material
2. Wearing out seems to be very fast, more than expected on spirited runs.
3. If used only for regular city drives probably we can expect 20K
4. At a cost of 900 INR, TNG did its job pretty well, and a life of 15 to 20K is decent.
5. No surprise or panic situation in the entire duration of 15K.
laluks is offline   (2) Thanks Reply With Quote
Old 28th September 2014, 17:39   #5824
srsriharsha's Avatar
Thanked: 24 Times
@laluks what did you replace it with ? Did you change it with TNG again?
srsriharsha is offline   Reply With Quote
Old 28th September 2014, 18:54   #5825
laluks's Avatar
The fronts are replaced with WULF
WULF looks better than TNG, costs around 1100 INR
The rears are TNG, changed 4K Kms before
After 4000Kms its down by 1mm, 2500Km of spirited drive included
Old 28th September 2014, 20:38   #5826
laluks's Avatar
DIY guide for replacing Civic's brake pads.
Disclaimer : Its strictly for those who wants to get their hands dirty, those who like to know what is done and for those who like experimenting. A friendly neighborhood garage would replace both the front and rear pads and necessary cleaning and greasing for something like INR 400.
Today I had some free time and thought of checking Civvy's front brake pads, and change if needed. Replacing front pads took less than an hour.
Please ignore the muddy look of the under body, just yesterday waded through Bangalore rivers (read roads).
Tools you will need, Spanner, Ring Spanner, C Clamp and File
These guys are critical
Check the size, 19 and 14
Remove the wheel and expose the brake assembly
You'll have to open these, Use Ring Spanner outside while keeping Spanner inside to block them from rotating
First open the bottom one and pull the cover upwards exposing the pads. Normally only this is required if you want to just clean the pads and put back.
This is the guy which pushes the pads when you apply brakes! This guy comes out based on the wear of the pads to keep them nearer to the discs. In this case it has almost come out full.
Pull out the pads
Simple isn't it?
If you want to clean, remove the top nut too and get the cover free
continued...
laluks is offline   (3) Thanks Reply With Quote
Old 28th September 2014, 20:51   #5827
laluks's Avatar
DIY guide for replacing Civic's brake pads, continued.
If you have seen some item in your service bill mentioning caliper pin greasing, then this is what happened
Pull out the caliper pins
Pull out the rubber bush also to clean
This is what you opened with Ring Spanner outside and Spanner inside (Pic for easy understanding)
Don't lose this guy
Clean these caliper pin holes with cloth
Add rustolene and clean if there is rusting, else clothe is just fine
Clean the caliper pins with a cloth
Clean the rubber bushes also
You'll need grease
Caliper Pin greased
continued...
Old 28th September 2014, 21:56   #5828
laluks's Avatar
Put the clean rubber bushes back
Push in the greased caliper pin
Put the cover back
Place the new brake pads
New pads nicely seated
To close the cover, this guy has to be pushed in completely
, since the earlier pad was worn out this fellow came out. Now since we are putting in a new pad he must go in completely
How do you push this guy in?
Use C Clamp and old pad to push this guy inside
Before pushing in, open the Brake fluid tank cover
It's easy with the C Clamp
Completely pushed in
Close up
The brake fluid level will rise due to this, and opening the tank can let it flow out if required, also will not create back pressure making it hard to push in.
This was the situation after pushing in while changing the other side pads
It's now done for this side, tighten this nut. Pad change over
continued...
Old 28th September 2014, 22:07   #5829
laluks's Avatar
This is where the pads have to slide in
Sometimes these aftermarket pads wont fit in, Use the file to shave off a bit at the edges to get it in these
slots. Use a bit of molly grease for easy movement.
After filing the pads nicely slots in
I also took this time to measure the thickness of the discs, seems good to go for some more time. The front rotors were changed some 65K Kms before. My next change would be a brembo rotor which gives a visual indication of wear.
Old 29th September 2014, 00:21   #5830
Thanked: 24 Times
Thanks for the detailed instructions. Please post review of the wulf pads as you use them
Old 29th September 2014, 08:49   #5831
sixthsense's Avatar
Attached are the pics for the brake pads that I got changed with its box.
Honda Civic : Maintenance, Service Costs and Must dos-img_20140928_105156.jpg
Honda Civic : Maintenance, Service Costs and Must dos-img_20140928_105151.jpg
Old 29th September 2014, 10:31   #5832
laluks's Avatar
My experience with Civic Brake pads is as follows
Stock Front pads - 55K
Stock Rear Pads - 60K
First Change
Front OEM Pads - 45K (Costed 11k, both rotors (~5K) and pads(~6K) were changed)
Rear OEM Pads - 51K (Costed 6K for pads)
Second Change
Front TNG Pads - 15K (Costed 900 for the TNG pads , Replaced with WULF )
Rear TNG pads - yet to replace (Costed 1100 for the TNG pads)
Front Pads change Odo readings - 55K - 100K - 115K
Rear Pads Odo readings - 60K - 111K - continuing
On a funny note, Civic tires also seems to be of a similar pattern
Stock Good Year NCT 5 - 60K
First Change Good Year Excellence - 40K
Second Change Yoko dbs - Seems 20K is the last I can push it, currently at 15K
laluks is offline   (1) Thanks Reply With Quote
Old 29th September 2014, 10:32   #5833
Thanked: 106 Times
I don't think so. My front and rear pads for Civic needed to be changed at the same time. I saw the rear pads and they were worn past the wear indicator.
Rgds
VineetG is offline   (1) Thanks Reply With Quote
Old 30th September 2014, 18:14   #5834
rr_zen's Avatar
Thanked: 264 Times
I became a victim of an ignorant biker this morning on my way to work. This guy darted out of nowhere from the opposite side without caring to look out for any vehicles and hit my front bumper. Heard a loud scratching noise and knew the bumper was damaged but never expected it to be so much. Gave him a mouthful and proceeded to office. Only upon reaching office did I notice the damage was real bad. Took it to HASS who quoted 6.5 - 7k for repairing the existing one and 13.5 - 14k for a new one. Opted for a new one as the slot holding the screw was cut off and I was told a washer would be used instead and that it may not be 100% perfect. My first insurance claim on this car but had no choice.
rr_zen is offline   Reply With Quote
Old 1st October 2014, 10:05   #5835
sgiitk's Avatar
@rr-zen; Do you not have a NCB to guard? I have a full NCB and 7500 excess, so will get very little joy if I were to claim.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1416 24th February 2018 00:17
