Old 1st October 2014, 10:25   #5836
srsriharsha's Avatar
Thanked: 24 Times
Could have given PDR a try. It's broken on my car too and the washer is holding up.
srsriharsha is offline   Reply With Quote
Old 1st October 2014, 14:22   #5837
rr_zen's Avatar
Thanked: 262 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
@sgiitk:The total premium I paid this year for an IDV of 7.5L is 9.7K and I was told by the insurance agent that I might lose 1.5K on the NCB. Considering that the cost of repair was on the higher side, I chose to go with this option.
rr_zen is offline   Reply With Quote
Old 1st October 2014, 15:48   #5838
sgiitk's Avatar
Thanked: 3,814 Times
Infractions: 0/1 (5)
Obviously you are not on high NCB and exclusion. I am on 50% NCB and get 2k off for a 7.5k exclusion!
Old 1st October 2014, 20:33   #5839
Thanked: 42 Times
Hi all, I have a Gen 1 Civic AT. Perfect car for highway cruising, however the one thing I miss the most in this is cruise control. Honda started putting cruise control in Gen II Civics (post 2009 I think). Has anyone been successful in getting cruise control retrofitted in their Gen 1 cars? It would make this car a perfect mile-muncher.
joshiviv is offline   Reply With Quote
Old 2nd October 2014, 08:50   #5840
sumeethaldankar's Avatar
Thanked: 1,071 Times
Infractions: 0/1 (7)
Hi guys,
I am getting the smell of outside environment while driving with the a/c on recirculation mode. eg A auto was going full throttle yesterday bellowing out tons of smoke which i could smell from inside of the car with the a/c on and windows shut. What could be the cause and how to eradicate same ?
Thanks all.
sumeethaldankar is online now   Reply With Quote
Old 2nd October 2014, 09:22   #5841
Captain Slow's Avatar
Thanked: 659 Times
Originally Posted by laluks View Post
Completed 15K with TNG front pads.
Observation:
1. No chipping of brake material
2. Wearing out seems to be very fast, more than expected on spirited runs.
3. If used only for regular city drives probably we can expect 20K
4. At a cost of 900 INR, TNG did its job pretty well, and a life of 15 to 20K is decent.
5. No surprise or panic situation in the entire duration of 15K.
Thanks for your detailed feedback and instructions on the brakes.
I had very good experience with TNG, one thing I noticed is that the TNG pads do produce a bit more dust?
Where did you find the WULF Pads in Bangalore?
Secondly, I see that the Brake fluid is very back in your car, Have you changed this ? You will notice a huge improvement once you bleed, the brake lines and use new fluid.
Captain Slow is offline   Reply With Quote
Old 2nd October 2014, 20:19   #5842
black12rr's Avatar
Thanked: 273 Times
Is any one aware or faced ENGINE BLOCK RECALL for 2006 - 2008 Indian Civis ? Is this applicable only for American cars ?
black12rr is offline   Reply With Quote
Old 3rd October 2014, 11:19   #5843
salunkhe.vizz's Avatar
Thanked: 211 Times
Hi Sumeet,
This is normal for most cars where if there is an outpour of exhaust right in front of your bonnet (air intake), even with inner circulation setting there is some smell that gets in.
However, if this is happening even in most normal circumstances where for e.g. driving on the highway and you can smell each and every zone outside (drain / exchausts / smoke / etc), then you have a problem.
Ignore it if this was one off.
salunkhe.vizz is offline   (1) Thanks Reply With Quote
Old 3rd October 2014, 11:24   #5844
Thanked: 211 Times
So after reading rave reviews of WagenWerkz in Mumbai coupled with my more than bad experience with 2 HASS (Solitaire & Linkway) on availability of spares, I have decided to give my car over to Jatin for a list of niggles that have been pending since I bought my used Civic S AT (2006 model).
It will now be a long wait for over a week to get my beautiful workhorse back, cant wait to see it pepped up and niggle free.
I will update on the service quality / attention to detail / cost once I get my ride back !
PART I: MECHANICAL
  1. General service and check up
  2. oil & filter replacement
  3. Suspension work
  4. General Tune up
  5. Brakes service / disc pads check
  6. Battery replacement
  7. Carburetor cleanup
  8. Power steering oil leakage check and refill
  9. Engine Coolant leakage check and replacement
PART II: AESTHETIC
  1. Plastic cladding for front wheel wells
  2. Moisture/leakage in front left side under Mat
  3. Fix Broken Back seat panel
  4. Fix Boot left side plastic cover on the joints
  5. Fix full Honda monogram at back
  6. Fix new floor mats
  7. Fix new OEM style steering leather wrap
PART III: ICE
  1. New ICE wiring (fader + balance not in place). Also if possible, fix a bass controller in front for the woofers
  2. Put front tweeters inside stock tweeter space
salunkhe.vizz is offline   Reply With Quote
Old 4th October 2014, 08:54   #5845
Thanked: 232 Times
Are the OEM brake pads by Nissin? I need to get the rear brake pads replaced and I'm pretty happy with the stock ones, so don't feel the need to upgrade.
coolkurt is offline   Reply With Quote
Old 4th October 2014, 15:47   #5846
Thanked: 23 Times
I read about sprint booster in one of the polo tsi threads on team bhp. On Google search, I found that it is available in US for around USD 289 for Honda Civic. Look forward to inputs if any of the fellow Civic owners have used it.
civic-dk is online now   Reply With Quote
Old 4th October 2014, 22:39   #5847
Thanked: 192 Times
Hi Guys,
Some guy scratched my Civic in a parking lot, result, multiple linear scratches on left rear door and the panel behind.
I want to repaint both the parts, any clue what should be a reasonable job for a quality paint job for the two parts??
Any recommended painters in Ghatkopar, Vikhroli Areas?
2000rpm is offline   Reply With Quote
Old 5th October 2014, 09:54   #5848
sgiitk's Avatar
Nissin is a reputable brand. Also, every manufacturer has two or more suppliers. I will get them without any qualms.
sgiitk is offline   (1) Thanks Reply With Quote
Old 5th October 2014, 22:08   #5849
Thanked: 42 Times
coolkurt are you sourcing them for the dealer or from the market. The dealer has recommended pads and rotors, front and back for my car (56K done), so I was looking at the options I have. I am in the NCR area too.
Old 6th October 2014, 00:30   #5850
Thanked: 232 Times
From the market. The dealer gets to touch my car only during service
I buy spares from Ghai Motors, Malviya Nagar and Batra Auto spares, ashram. Both are old, reputed.
coolkurt is offline   (1) Thanks Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1406 3rd February 2018 09:55
