Old 27th March 2015, 11:21   #6406
laluks's Avatar
Thanked: 7,943 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by manim View Post
My experience is different, so far I never had any problems worth mentioning in eight years and 1,37,000+ kms. I only had to do the routine services (not even a fuse had blown so far).
But I do have my worries, I have some heavy driving coming up in the next two months far away from my hometown and I am worried if the car will still be reliable as usual (I will be travelling with my family in a hot summer).
I expect my trouble-free run to last for at least ten years (two more years).
It will continue to run
Given the current mileage - Clutch alone can be a worry, and if your mechanic had given a go ahead, then that's it
Suspension issues if any crops up during your long drive, you still can get it back home and repair. But I guess you have no issues on it. An alignment check before the big run will give you peace of mind.
laluks is offline   (1) Thanks Reply With Quote
Old 27th March 2015, 13:37   #6407
MARCUS_520i's Avatar
Thanked: 152 Times
Hey guys!
A new issue has cropped up. And, as luck may have it, at the worst time of the year. The AC has developed a moody mind of it's own.
It's been a few days now. Whenever, the car is crawling in traffic, the air conditioner stops cooling, and only the blower keeps throwing 'normal' air. Then, I have to rev the engine hard a few times, to get the cooling going on again. This repeats infinitely.
Had sent it to Honda a day back, and they reported the AC to be functioning normally.
But, the problem doesn't seem to go. I'm sure there's been no gas leakage, otherwise, it wouldn't have cooled at all.
Has anyone else faced such or a similar problem?
What could be the reason behind this?
40+ degree temperatures are such a buzzkill! Ugghhh!
MARCUS_520i is offline   Reply With Quote
Old 27th March 2015, 13:37   #6408
Thanked: 623 Times
Originally Posted by coolkurt View Post
The way I see it, you've been a bit unlucky.
May be yes, less than a month after replacing both the front wheel bearings, I am getting the bearing noise all over again.
Probably got more to do with the driving style, frequency, city vs highway driving etc.
I am generally very soft on all the vehicles that I drive. I agree though on your point.
Also,, forget what Honda says, switch to a 10,000-12,000 km once a year regime for service.
While the manual says 6 months or 10,000 km, the guys at the dealership insist that I give the car for service every 3 months.
You are right Manim. Hondas (especially, previous-generation models) are known for this trait globally. There are several examples in India too that stay true to this legacy. I might be wrong, but I think those of us who go the pre-owned route are probably the ones that face issues, however minor they might be.You never know, the first owner might not have taken proper care in the crucial 1-2 years of ownership.
arvi86 is offline   Reply With Quote
Old 27th March 2015, 13:52   #6409
rr_zen's Avatar
Thanked: 262 Times
The dealership is very prompt in their relentless pursuit of persuading me to give the car for service every 3 months. Earlier, I had some patience left to tell them that my car is low on running and hence an yearly service is what I prefer, whenever they called me. Nowadays, I have stopped answering their calls.
rr_zen is offline   Reply With Quote
Old 27th March 2015, 14:10   #6410
1lokesh's Avatar
Thanked: 354 Times
The way I see it, you've been a bit unlucky. I've just had to replace the engine mount at 95k and got a new clutch at 90k. Rest everything is stock, holding pretty well. Small niggles post 1,00,000 kms are certain.
Probably got more to do with the driving style, frequency, city vs highway driving etc. My friend has an Elantra and it's already raked up repair costs of over a lakh in less than two years of ownership.
+1 to that
Mine is now about to breach 90k and all I have invested in is the clutch set and shocks, that too just a couple of months back. Brake Pads have lasted +40k.
Although, the engine mount is now running out its life looking at the shudders it has started giving - everything else seems to be working fine. Touch-wood
1lokesh is offline   Reply With Quote
Old 27th March 2015, 14:31   #6411
sgiitk's Avatar
Thanked: 3,797 Times
Infractions: 0/1 (5)
Once you are outside warranty let them rant for all I care. Both my cars are on annual/10,000. Manual does not list but with Synth the change is 10,000 or once a year. My so with a year old City AVN is also switching to annual.
Same here. In fact once I asked the GM - are Honda cars made of cardboard? He said no, so I asked why this three month nonsense. Even during the warranty period of my Civic I skipped the three month show after the first free inspection.
In any case the 3 month show is officially called inspection and not service. Brio / Amaze do not have it!
Old 27th March 2015, 14:47   #6412
rr_zen's Avatar
Thanked: 262 Times
I wonder what they inspect every three months (maybe our wallets ). In my case, I would have barely covered 300 km during that time. The only fallout of all this is to have all possible settings including the seats, ORVMs, steering, AC etc changed and it takes a while to get them back to your preference. Of course, the car looks clean from outside.
Old 27th March 2015, 23:33   #6413
sumeethaldankar's Avatar
Thanked: 1,053 Times
I think Manim's Civic has a auto tranny so he need not worry about the clutch either.
Originally Posted by MARCUS_520i View Post
Hey guys!
I believe this is normal as the ac works better with speed of the car. I have noticed the same in my car. In bumper to bumper the a/c effect is not very cool. You most probably noticing this now because of the summer heat. What you can do is reduce the temperature lower instead of revving the engine.
That is the problem with getting non OE stuff, you don't know if it will last long. My Civic's after market engine mount busted in just 2-3 months.
If the car's running is not much then it's ok to give it once a year. But for people like me who are running 1.5k kms a month , a 3 months service just for a check up does not seem like a bad idea. This will make sure problems are corrected in time and the car gets proper care if it's used daily for long distances.
sumeethaldankar is offline   Reply With Quote
Old 28th March 2015, 09:42   #6414
sgiitk's Avatar
yes, inspect and lighten your wallet.
I bet the wash can be much cheaper than what they bill you. Get a decent wax (I prefer Collinite 845) , and pay the chap who washes your car to do a good job. This will be much better.
Old 28th March 2015, 10:57   #6415
vasoo's Avatar
Thanked: 207 Times
Exactly! I have in fact blocked all numbers from HASC using Truecaller app on my phone . I follow a yearly servicing and that too with my FNG from last year rather than at ASC. My running is also less (about 5000 kms per year) with two other cars in my family. Interestingly, even when I did servicing early last year at Dakshin Honda, they did not fix any of my specific complaints about some rattles. So I do not plan to go there, unless I need to replace some parts. I do my own detailing on the car once a year using Meguiars stuff and finishing with Collinite.
vasoo is offline   Reply With Quote
Old 28th March 2015, 12:45   #6416
Thanked: 152 Times
No, bro. The AC stops cooling, completely. The cooling stops.
Irrespective of even keeping it at "Lo", which is 18 degree C.
Old 28th March 2015, 12:56   #6417
laluks's Avatar
I remember reading in this thread somewhere, its about some ice formation somewhere making the logic trip thinking its cool enough. Forget recollecting the specifics. And there was some remedy suggested as well
If time permits I'll try to dig it out for you, please also search this thread in its entirety
laluks is offline   Reply With Quote
Old 30th March 2015, 07:50   #6418
aa_asif's Avatar
Thanked: 35 Times
More than a decade back, I was a part of one reputed Honda dealership looking after the state wide sales of Accord and CR-V. What you say is absolutely right. I have heard and seen myself and vouch that the H.A.S.S people just wash and return the car every alternate 5K service. The oil change and any routine check ups are normally done every 10K interval unless you have pointed out something specific.
aa_asif is offline   (1) Thanks Reply With Quote
Old 30th March 2015, 08:54   #6419
Hey Marcus! It is the ac clutch that is causing the problem. I faced the exact same problem in my Civic.. Took it to my FNG and was advised to have the ac clutch changed. 3.5k and the ac was fixed.
LovemyOHC is offline   Reply With Quote
Old 30th March 2015, 08:56   #6420
sgiitk's Avatar
Surprisingly one cause of icing is low refrigerant. If this is the case, you have freezing and hence icing at the expansion valve!
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1404 23rd January 2018 15:51
