Old 2nd July 2015, 22:47   #6721
sumeethaldankar's Avatar
Thanked: 1,072 Times
Infractions: 0/1 (7)
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by StallionAmit View Post
Thanks. Need further info. I was going through the latest service records and in it it was mentioned "SYNTHETIC ENGINE OIL (100 ML) SM 0W30.
Is it same or correct engine oil?
Yes it's the Idemitsu Engine Oil available with Honda A.S.S. If you need to only a oil change go to HASS and say you have a 'request' for a oil change. Also change oil filter as well. You need not give the car for service just to get the oil changed.
sumeethaldankar is offline   (2) Thanks Reply With Quote
Old 3rd July 2015, 21:46   #6722
swapitude's Avatar
Originally Posted by 1lokesh View Post
One question. Wanted to get Aux input done in my 2007 Civic.
Will this Aux input unit only support iPod/mp3 players etc?
Will it support USB drives? If not is there a way around to get to that?
Planning to get this done over the weekend at wagen werkz by bhpian jatinpatel.
Cheers!
Originally Posted by arun-t View Post
I have a 2006 Civic AT and have been hinting for a Aux and USB inout option to my car for a long time. A solution that doesn't involve usage of FM transmitters. Can you let me know how you got it done and from where? I am based out of Bangalore. Thanks.
Originally Posted by XtremeTorque View Post
some of these adapters connect to external cd changer input port on HU available on international variants. Since ours comes with in-dash changer, there may not be the required port to connect these. But I may be wrong as I still havent got the courage to remove and check the rear of my HU...
It is not that difficult to get Aux-In port in your civics. Finally decided to give it a try today and i was through at the first attempt. You can control all the features (Bass, Treble, Balance, Fader, SVC).
Difficulty Level : Low
Time Taken : 30 min
Cost : 60 INR. (40/- for Aux cable and 20/- for Jumper wires)
Tools needed as follows;
  • Star Screwdriver (1 screw), Ratchet Wrench (two 8 mm Hex Bolt)
Parts needed as follows;
Name:  3.5mm Aux cable.jpg
Name:  3.5mm Aux connection.png
  • 3.5 mm aux cable - Male to Male or Male to Female, doesn't matter as any ways we will cut one side but make sure not to cut male side.
Name:  Jumper cables.jpg
Name:  Jumper cable connector.jpg
  • 4 Breadboard Jumper Wires - female to male or female to female, doesn't matter as any ways we will cut one side but make sure not to cut female side.
Follow civic06auxguide.pdf with lot of patience. civic06auxguide.pdf
If anyone needs help can contact me and will be happy to help. I have few spare Jumper cables to make atleast 8 Aux-In cables.
swapitude is offline   (4) Thanks Reply With Quote
Old 4th July 2015, 14:12   #6723
Thanked: 623 Times
Originally Posted by sumeethaldankar View Post
Guys need advice.
Is your speedo problem sorted out now Sumeet? Now that the rainy days are gone, did you face the problem again? I've been facing something similar with my brake lights not turning off. I had to get it disconnected and running without brake lights now.
arvi86 is offline   Reply With Quote
Old 4th July 2015, 14:17   #6724
Since its dry and has not been raining for a while speedo issue has reduced. I had same issue with brake light. A switch under dashboard needs replacing and is a cheap fix nothing to worry.
sumeethaldankar is offline   (1) Thanks Reply With Quote
Old 4th July 2015, 14:31   #6725
Thanked: 623 Times
Yup, that's what I was told by the service advisor. Again, it would take atleast a week for them to procure it.
Old 7th July 2015, 10:12   #6726
Thanked: 104 Times
Does Civic has separate fuse for the 12v Socket? My mobile charger is not working in the given socket, rest all accessories are working perfectly. Tried testing the charger in other vehicle and it worked properly.
saurabhkum is offline   Reply With Quote
Old 7th July 2015, 16:07   #6727
XtremeTorque's Avatar
Thanked: 47 Times
not all chargers works with the socket. I have Nokia and Sony car chargers which works fine with it, but another generic (Targus brand) charger is not working. no idea why it is so
XtremeTorque is offline   Reply With Quote
Old 13th July 2015, 23:58   #6728
Thanked: 335 Times
Hi BHPians.
My Honda Civic 2007 AT rear bumper was badly damaged today, right now I am in Bangalore but moving to Kolkata during this weekend (due to work transfer) could you suggest me what shall be the costs if we completely replace the back bumper, and places in Bangalore and Kolkata to get the changes done.
I will be utmost grateful
StallionAmit is offline   Reply With Quote
Old 14th July 2015, 10:53   #6729
Thanked: 94 Times
Hi BHPians.
The unpainted bumpers will cost around 7000 and painting will set you back by another 6000. You can check with the nearest HASS. But availability and painting might be a problem.
varunanb is offline   (1) Thanks Reply With Quote
Old 14th July 2015, 13:11   #6730
Thanked: 335 Times
Hi Varun
Thanks for the input but what about if I get it done from outside garage? What will be the cost then? Any place you know in Kolkata?
Old 14th July 2015, 19:39   #6731
WasavaTyres's Avatar
Thanked: 241 Times
The bumper will invariably be have to be bought from a HASS unless you go hunting for a salvage dealer. The paint job of course can be done outside.
WasavaTyres is offline   (1) Thanks Reply With Quote
Old 14th July 2015, 20:04   #6732
laluks's Avatar
Thanked: 8,133 Times
I was told at a dealer at JC Road in Bangalore it is available around 4K, I never checked it in flesh.
laluks is offline   (2) Thanks Reply With Quote
Old 14th July 2015, 21:07   #6733
kingofmyworld's Avatar
Thanked: 248 Times
Hi BHPians.
After market bumpers cost anything between 3500-5500. Painting depends on where you get it done from. I got a quote for 3k and a guarantee that the paint wont fade/chipoff and in case it does, free repainting.
kingofmyworld is offline   (1) Thanks Reply With Quote
Old 15th July 2015, 01:54   #6734
Captain Slow's Avatar
Thanked: 659 Times
Dear Laluks,
Can you please give me more details? I need a rear bumper. I will try contacting this shop. Honda @SS Asked me for an insane amount for the rear bumper.
Captain Slow is offline   Reply With Quote
Old 15th July 2015, 10:06   #6735
sgiitk's Avatar
Thanked: 3,814 Times
Yes, F29 rated at 15A.
This is where the accessories draw their power from.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1416 24th February 2018 00:17
