Old 23rd July 2016, 13:56   #7666
Thanked: 104 Times
My driver has managed to lose the fuel tank cap of my civic. Any idea where I buy a cheap one? Service center quoted INR 2k.
reddevilgautam is offline   Reply With Quote
Old 23rd July 2016, 15:23   #7667
sgiitk's Avatar
Thanked: 3,866 Times
Infractions: 0/1 (4)
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
They are pretty ubiquitous. Any cap for the smaller filler (the filler was bigger before unleaded came in) should fit. Just check around.
Same for the pressure caps for the radiator.
Old 24th July 2016, 12:58   #7668
Thanked: 104 Times
Thanks will check it out
Old 24th July 2016, 15:21   #7669
Thanked: 13 Times
am facing gear shudder problem in my 2007 auto civic.genuinely run 46 k.it shudders only at low speeds at around 40-50 kmph.what could be the problem?
procircuit_234 is offline   Reply With Quote
Old 24th July 2016, 20:13   #7670
manim's Avatar
Thanked: 393 Times
Post Re: Honda Civic : Maintenance, Service Costs and Must dos
gear shudder problem? Can you give more details?
Anything to do with transmission-oil?
Was it changed according to schedule?
manim is offline   (1) Thanks Reply With Quote
Old 24th July 2016, 20:36   #7671
Thanked: 13 Times
yes oil has been changed according to schedule car shudders while accelerating at around 40-50 kmph
Old 24th July 2016, 20:51   #7672
manim's Avatar
Thanked: 393 Times
Since mine too is an 2007 model AT, am curious.
I had one previous incident where the 'D' light was blinking and the gear would not go above third. (The car had been sitting idle for many months). At HASS after the wires were checked and cleaned it became okay. Maybe it was dust on the sensors I suppose.
That was one year back and now everything is working fine!
manim is offline   Reply With Quote
Old 25th July 2016, 15:27   #7673
laluks's Avatar
Thanked: 9,668 Times
Originally Posted by 1lokesh View Post
Anyone else facing or has water leakage from this spot during the rains? This is on driver's side at the joint where the fabric meets the plastic.
Attachment 1529681
Took the car to HASS today and they said they'll need to keep the car for 4-5 days and then only will confirm the solution. SA also told me that it will be a minimum of 20k given that all rubber beadings etc will have to be replaced
Facing this issue only for last 4-5 days. It was all fine earlier.
Take it to a windshield shop and ask them to seal the right top corner of the windshield. That should sort it out.
laluks is offline   (1) Thanks Reply With Quote
Old 26th July 2016, 21:28   #7674
gaurav_diavolo's Avatar
Thanked: 54 Times
Hello, my fuel gauge went Kaput. Sometimes it shows bars from the reverse side and other times its completely black. The yellow fault light too has been on sice. Showed it at pinkcity honda in jaipur and to my horror they told me the sensor needs to be changed and it will cost 18k! What to do, please guide.
Honda Civic : Maintenance, Service Costs and Must dos-v4s6m9.jpg
Last edited by Aditya : 27th July 2016 at 06:30. Reason: Uploading image as attachment
gaurav_diavolo is offline   Reply With Quote
Old 26th July 2016, 23:00   #7675
sumeethaldankar's Avatar
Thanked: 1,134 Times
Well i had issue where the display would go completely blank. One of the mechanics resolved it by disconnecting the battery for 5 mins and reconnecting it again. This happened mostly in rainy season and on dry spells it would behave itself. You could try this and see. Alternatively you could get it repaired from a good shop which specializes in electric car repairs. If this option is also not there try looking for a used one from a scrap shop etc.
sumeethaldankar is offline   (1) Thanks Reply With Quote
Old 26th July 2016, 23:19   #7676
Thanked: 243 Times
Got back in town after 10 days and I've got mold in my car! It's on the floor, the seatbelts and somehow even on the plastic flap covering the cup holders. It also seems that I've got mold in the ac vents, as although I got the other bits cleaned up, the air-conditioning still smells of it. Any idea how I could get rid of all the mold? And disinfect the ac vents?
coolkurt is offline   Reply With Quote
Old 27th July 2016, 10:00   #7677
Thanked: 54 Times
Originally Posted by sumeethaldankar View Post
One of the mechanics resolved it by disconnecting the battery for 5 mins and reconnecting it again. You could try this and see. Alternatively you could get it repaired from a good shop which specializes in electric car repairs.
Didn't work with battery disconnected and reset. I am not comfortable with giving car to local mechanics, had a major issue once, they do not take responsibility when they mess up something. Is this really an issue with the censor as claimed by Honda or a minor electrical glitch?
Old 27th July 2016, 11:13   #7678
saket77's Avatar
Thanked: 4,873 Times
I got them twice but only on the steering wheel! Blame the season.
I guess running the heater on full at the highest temperature might help clear them.
Regards.
saket77 is offline   (1) Thanks Reply With Quote
Old 27th July 2016, 12:06   #7679
WasavaTyres's Avatar
Thanked: 255 Times
Try sprinkling baking soda liberally all over the carpets and in nooks and corners specially. They tend to grow back.
As for the foul odour, you could try AC cleaners from Abro / Cyclo / Armorall.
Also get hold of a small packet of activated carbon, you can buy it online for anywhere between 200-600 and leave it in the car. It'll absorb all those annoying smells.
WasavaTyres is offline   (2) Thanks Reply With Quote
Old 27th July 2016, 18:05   #7680
mpksuhas's Avatar
Thanked: 4,092 Times
Try parking the car in sun, turn on temprature knob to max (hottest position) and keep AC running for a while. My Alto has similar issue and after running the AC this way for around 20 minutes smell disappeared.
mpksuhas is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1481 2nd June 2018 12:26
