Old 9th September 2016, 20:07   #7756
sumeethaldankar's Avatar
Thanked: 1,134 Times
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by avisidhu View Post
Thanks for this info, though the mounts on my Civic are fine but I guess this is something everyone needs to keep at the back of their mind. How has your experience been with these new mounts?
The new mount is holding fine since it's been installed and has not shown any of the mount symptoms so far. Also the gap has remained consistent. I have covered approximate 23k kms on the mount and see no signs of wear and tear.
sumeethaldankar is offline   (2) Thanks Reply With Quote
Old 10th September 2016, 09:44   #7757
Thanked: 243 Times
How much is the new mount for at HASS?
I've got the mount replaced last month, second time. The first one lasted 50k kms. At 1900 bucks, I'd say it did it's job well.
coolkurt is offline   Reply With Quote
Old 11th September 2016, 21:17   #7758
It will cost 10k including tax labour etc.
sumeethaldankar is offline   Reply With Quote
Old 12th September 2016, 08:03   #7759
Thanked: 243 Times
That's pretty expensive. I'd suggest going for a good quality aftermarket mount. The mounts available in Delhi/NCR at ghai, batra etc last long.
Can anyone share the part number of the new mount design? It'll be interesting to see what Honda has changed.
Old 12th September 2016, 09:52   #7760
sgiitk's Avatar
Thanked: 3,866 Times
Infractions: 0/1 (4)
Originally Posted by ImmortalZ View Post
Just a question - my Civic will go for it's first service on the 30th. Should I force an engine oil+filter change?
I think it comes with Synth, and the first oil change is only at the six month point. no point in forcing the change.
Old 12th September 2016, 10:06   #7761
laluks's Avatar
Thanked: 9,668 Times
That was a post from 2008 Professor
laluks is offline   Reply With Quote
Old 12th September 2016, 15:56   #7762
sgiitk's Avatar
I was suspicious since the Civic has not been available for quite a few years. I should have checked more closely. However, the deed is done. Thanks for pointing it out.
Old 13th September 2016, 08:22   #7763
Thanked: 97 Times
Hi Guys,
A trucker rammed into my car last night. Damaged driver side door. What do you guys think is the best way to get it fixed. Shall I go through the Honda way or shall i get it done from outside. I do not have 0 Dep insurance on the car and the car is 5 years old.
Honda Civic : Maintenance, Service Costs and Must dos-1473735094872.jpg
nik0502 is online now   Reply With Quote
Old 13th September 2016, 11:20   #7764
pixantz's Avatar
Thanked: 715 Times
Originally Posted by nik0502 View Post
Hi Guys,
Oooh. Poor girl. Though I wouldn't call it "rammed" because if a truck rams a sedan in the true sense of the word, there's not much left to salvage in most cases. So in comparision, this is just a "pappi" maybe . Some low slung bumper part of the truck must have scraped it.
Going the Honda way would cost you about 4-5 times what it would outside with a great job mostly done at Honda. Outside you will have to be sure you have a really good denter and painter at your disposal because not all of those dudes know to get the Honda 'lines' or 'curves' properly. So it depends on what is your choice.
You're lucky that your mirror, door handle, glass and the A-pillar etc don't seem to be even touched in the event. That's great. So you just have the door sheet metal to be looked into. The side trim though seems to be hard to procure in most cases. This one may be possible to set straight....
pixantz is online now   Reply With Quote
Old 13th September 2016, 20:00   #7765
Thanked: 97 Times
Yes Pixantz,
You are right. But the truck had hit with a real force in the stationary car. I was inside the car and it it was dragged fir almost a feet before the truck stopped. About the repair, don't think this door can be repaired. The cut in the sheet is quite big for the repair. Now the question is weather i should get an old door from the scrap market and get it painted or replace with a new door.
Old 13th September 2016, 20:17   #7766
Thanked: 14,319 Times
No ways buddy, that door just can't be repaired at all.
If you get hold of a good condition door from the scrap yard then nothing like that but repainting it would make it evident that the door was replaced. See if the painting guy can match the right side colour condition post replacement.
a4anurag is online now   Reply With Quote
Old 13th September 2016, 23:57   #7767
pixantz's Avatar
Thanked: 715 Times
Yah. You got a point there. Technically it can definately be done. Any kind of tear can be fixed/patched with it being impossible to detect later. But in some scenarios you got to weigh the options of either doing that or getting a new part and repaint to match the car. It might be a better bet in this case. Then the only thing you will have to be careful about is getting a painter who really knows his shades good.
Old 14th September 2016, 11:21   #7768
Thanked: 121 Times
Hi Guys,
Try Heera Motors in Gurgaon. Hes a wizard. Denting, painting, mechanicals, orvm repair, everything.
Even HASS accepted that the quality of painting by him was better than what they did
Ive see him repair an almost totalled civic with airbags deployed, rolled over twice, A pillar collapse, windwhied etc gone.
i can give contact details
VineetG is offline   Reply With Quote
Old 14th September 2016, 19:00   #7769
saket77's Avatar
Thanked: 4,872 Times
Poor sight. Get an approximate quote from Honda. If 'bearable' then go with them, else it is best done outside, IFF colour is matched.
Another query, has anyone tried Liqui Moly engine oil on the Civic?
I know the stock oil by Idemitsu is great but just wanted to know if anyone has the experience.
Saket.
saket77 is offline   Reply With Quote
Old 26th September 2016, 17:39   #7770
MARCUS_520i's Avatar
Thanked: 153 Times
Quick question!
The child lock on my Civic's LHS rear door has accidentally been engaged.
How do I disable it?
MARCUS_520i is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1481 2nd June 2018 12:26
