Old 9th March 2017, 15:02   #8056
sgiitk's Avatar
Thanked: 3,797 Times
Infractions: 0/1 (5)
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
@Kunal; Remarkable, only how long will it last? Worth a try.
sgiitk is offline   (1) Thanks Reply With Quote
Old 9th March 2017, 16:22   #8057
petroguzzler's Avatar
Thanked: 150 Times
Originally Posted by WasavaTyres View Post
Good morning Gentlemen, the MID in my car shows the wrong temperature. It's usually off by 5 degrees. I checked the sensor located in front of the radiator / condensor and found no soot / dust or any other coating on it. What could be wrong ?
Even I have the same issue. I also feel that the outside temperature shown by the MID is off by 5-7 degrees. Any solutions?
petroguzzler is offline   Reply With Quote
Old 9th March 2017, 16:41   #8058
kunal_kaushal's Avatar
Thanked: 112 Times
Very true Professor, it is exactly one of the few concerns I have in my mind, others are whether I will be able to procure similar shade of paint like the one present on the car upholstery, lastly what if I make a total mess.
With all these doubts in mind, I think, I shall first talk to the 3M guys, in case if they have leather re-conditioning services and most importantly if it is reasonably priced, I might consider refraining from fiddling with the leather upholstery.
@petroguzzler you can re-calibrate the temperature using the following method
1. Turn the ignition switch ON (II).
2. Select the outside air temperature display.
3. Press and hold the SEL/RESET switch for 10 seconds. While you continue to hold the button, the display will scroll through temperature settings from +3 C to -3 C.
I tried it on my car and was able to change the temperature unfortunately it can only change/correct the temperature by 3 C, Hope this helps.
Kunal
kunal_kaushal is offline   (1) Thanks Reply With Quote
Old 10th March 2017, 09:42   #8059
Thanked: 112 Times
@petroguzzler, I can be such a jerk at times , one can repeat the process and can further correct the temperature.
Kunal
Old 12th March 2017, 20:11   #8060
Thanked: 112 Times
Hi all,
Can someone kindly confirm, if Civic has upholstery, has real leather or leathrite (art leather)?
Because supposed leather seats in civic are peeling and under the leather coating the some sort of cloth is visible.
Kunal
Honda Civic : Maintenance, Service Costs and Must dos-20170312_201056.jpg
kunal_kaushal is offline   Reply With Quote
Old 13th March 2017, 09:44   #8061
sgiitk's Avatar
@kunal_kaushal; I think the V has real leather, others I do not know. Leather has been on and off in the S at various times. The pic you have pasted does not look like real leather.
Old 13th March 2017, 10:23   #8062
R2D2's Avatar
Thanked: 1,246 Times
From my experience with the Corolla Altis GL the so called leather seats are made of a portions of leather and 'artificial leather'. This bit of info is concealed in the owners manual. It tells me the seats were never supposed to be 100% leather. A neat rip off.
I guess even Honda follows the same rule.
R2D2 is offline   (1) Thanks Reply With Quote
Old 13th March 2017, 10:39   #8063
Thanked: 112 Times
Hi Professor, mine is a V only, and it was supposed to have leather upholstery, unfortunately it seems it is leathrite :(
It very well seems like that only. :(
Old 14th March 2017, 12:05   #8064
WasavaTyres's Avatar
Thanked: 241 Times
I this these faux leather covers were put in by the previous owner. The colour and texture is quite different from what I've seen on mine and other civics. And below the leather covers would be foam and not fabric.
WasavaTyres is offline   (2) Thanks Reply With Quote
Old 14th March 2017, 12:10   #8065
Thanked: 112 Times
The covers have not been changed ever, and are the original company installed ones, in a nutshell I am really confused.
Kunal
Honda Civic : Maintenance, Service Costs and Must dos-interiors.jpg
Last edited by kunal_kaushal : 14th March 2017 at 12:30. Reason: forgot to add pictures
Old 14th March 2017, 13:17   #8066
techcoze's Avatar
Thanked: 170 Times
I am not sure about OEM seat covers quality, but I was lucky to get my pre-worshipped civic with aftermarket Stanley leather seats installed by previous owner. They don't show sign of age even after 10 years of usage. Looks like they will easily last for 10 more years
techcoze is online now   Reply With Quote
Old 14th March 2017, 17:02   #8067
Thanked: 112 Times
http://www.team-bhp.com/forum/modifi...ml#post4138465
I was just going through Nikhilb2008's thread, which I have included (I am apologising upfront, as I wasn't too sure if cross merging of threads is permissible or not.), and guess what, came across one post (#113) of the same thread, and looking at the pictures of the car's upholstery (Factory fitted) which had uncanny resemblance with my civic's worn out upholstery, I think that there is no doubt in my mind, that all civic's (V variants) seats are fabricated with Leather + art Leather, from factory itself and mine is no exception.
Kunal
Old 19th March 2017, 00:16   #8068
sumeethaldankar's Avatar
Thanked: 1,053 Times
Guys what should brake pads min thickness be ? Service guys have observed 4mm thickness for rear pads.
sumeethaldankar is offline   Reply With Quote
Old 19th March 2017, 09:26   #8069
Thanked: 112 Times
Hi Sumeet, IMHO 1.75 - 2mm thickness is the minimum safe level, post that one should get the brake pads changed.
Kunal
Old 19th March 2017, 09:36   #8070
sgiitk's Avatar
Rear pads see fat less wear than the front. Still 4mm seems to be cutting close to the limits. They may be 3mm or so.
sgiitk is offline   (2) Thanks Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1404 23rd January 2018 15:51
