Old 27th May 2017, 01:31   #8386
Thanked: 8,953 Times
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by kunal_kaushal View Post
While driving back from office I heard rattling (cut cut) noise while car encountered any uneven surface/potholes, I took the car to FNG, he examined and pointed that the right brake caliper has developed rattling noise due to play of caliper pin. He said it can be fixed after putting in new caliper pins at the machining guy.
l
As suggested by other members, replacing the pin is a straight forward job. However, I suggest you do make sure why the pin started to have play? Is something else worn. So you do need to make sure the caliper parts gets inspected properly for wear and tear as well. It doesn’t make sense to put a new pin in, if something else is wrong/worn.
Jeroen
Jeroen is offline   (1) Thanks Reply With Quote
Old 27th May 2017, 17:47   #8387
kunal_kaushal's Avatar
Thanked: 119 Times
Originally Posted by WasavaTyres View Post
Gentlemen, How is it on your cars ?
Hi Mate,
It is identical to yours, if you ignore the soiled condition in my case.
Kunal
Honda Civic : Maintenance, Service Costs and Must dos-20170527_174544.jpg
kunal_kaushal is online now   Reply With Quote
Old 27th May 2017, 20:12   #8388
WasavaTyres's Avatar
Thanked: 255 Times
I'll still wrap it up with steelgrip insulation tape tomorrow. Find it strange honda wouldn't provide full length sleeves for it in the first place.
WasavaTyres is offline   Reply With Quote
Old 27th May 2017, 20:38   #8389
R2D2's Avatar
Thanked: 2,038 Times
Please don't mind me saying this, but if the sensor wires and conduit have worked flawlessly without exhibiting any damage for so many years why try to fix something that isn't broken? Or, am I missing something here?
R2D2 is offline   (1) Thanks Reply With Quote
Old 27th May 2017, 20:44   #8390
laluks's Avatar
Thanked: 9,713 Times
I agree, why fix something that ain't broken?
laluks is offline   (2) Thanks Reply With Quote
Old 27th May 2017, 20:51   #8391
Thanked: 119 Times
Please don't mind me saying this, why try to fix something that isn't broken? Or, am I missing something here?
I too agree with R2D2 and Laluks, IMHO you should let it, as it is.
Kunal
kunal_kaushal is online now   (1) Thanks Reply With Quote
Old 29th May 2017, 10:27   #8392
Thanked: 255 Times
Old 29th May 2017, 10:42   #8393
Thanked: 98 Times
Hi Guys,
Do you think it is a good idea to put after market seat covers on the leather seats of Civic. The seats in my Civic are in horrible condition specially the front passenger seat & spoil the overall feel of the car at times.
nik0502 is offline   Reply With Quote
Old 29th May 2017, 13:59   #8394
Thanked: 255 Times
Kunal
Thanks guys, the repeat message happened as a mistake , Gah !! . There is a similar set of wires at the base too and in the same state. Have left both untouched based on your inputs.
Did install a new cabin air filter though. Had taken the Punto for a pipe replacement to Fiat and got the cabin filter replaced for it and bought one for the civic too from them. It's denso make and cost Rs.232. Was a snug fit in the civvy.
Originally Posted by nik0502 View Post
Hi Guys,
By all means go ahead. I'll be getting mine changed too. But will opt for PU / art 'leather' / 'leatherrite'or whatever it is that the accessories shop guys call it. Leather per se I feel is too warm and maintenance heavy for our weather conditons. Have had Autoform seat covers on the Punto for 5 years now and they've been very good. No slack / colour fade / peeling to date.
Old 30th May 2017, 13:55   #8395
Thanked: 65 Times
Guys, HASS advises me to go in for a suspension overhaul. Estimated to cost around 1 lakh!! The car is now 10 years old, and though odo has only 70k kms on it, it has had a pretty tough 2 years on seriously potholed Goa village roads.
No FNG for me here, but there is a Bosch service center in South Goa. Think its a good idea to get them to take a look?
I am not knowledgeable about suspensions or pretty much anything else. The Civic has been running like a perfect household appliance all this while. But guess those days are over.
Any advice would be great.
Other work coming up soon: Front bumper's clips to attach to the body are broken, and need to replace (and paint the bumper). A tail light broken. Scratches by stupid kids that have been there since 2008. A scratched up area outside the front right wheel well where a scooter banged into. Not a good year for me!
lawdgawd is offline   Reply With Quote
Old 30th May 2017, 17:55   #8396
Thanked: 255 Times
Originally Posted by lawdgawd View Post
Guys, HASS advises me to go in for a suspension overhaul. Estimated to cost around 1 lakh!! Any advice would be great
Drop a line to Coolkurt. He'll help you source spares from Ghai Auto Spares in Delhi, they'll ship it across and you can get the work done at a good local garage. You'll get the work done at less than half of what HASS has quoted.
Old 30th May 2017, 20:28   #8397
sumeethaldankar's Avatar
Thanked: 1,157 Times
I had done my Civic front suspension overhaul for 34K in 2014. Source parts from online sites.
A front suspension overhaul would need below
http://www.team-bhp.com/forum/long-t...ml#post3650144
Try and source branded products like TRW (spareshub.com eg) which will cost around 10-15k. The front 2 shocks will cost around 8 each.
Total you should not be spending more than 30-35k. Avoid unbranded components as these will not last long.
sumeethaldankar is online now   Reply With Quote
Old 30th May 2017, 21:45   #8398
Thanked: 65 Times
Thank you! I guess I should first take it to Bausch to confirm what HASS is telling me, then identify the parts to be replaced and then contact Coolkurt to source the parts.
That's a relief!
I'll go through that thread. Definitely no unbranded components for me. Peace of mind above all! Thank you.
Old 31st May 2017, 14:50   #8399
Thanked: 137 Times
That's a relief!
Hello,
You can also go through
skdking is offline   Reply With Quote
Old 2nd June 2017, 08:18   #8400
Thanked: 245 Times
Kindly do get it checked as 'suspension parts' In itself is a broad term and encompasses a whole lot of components. It'll save time and money if you know which specific parts to replace. The entire system rarely goes kaput in one go.
coolkurt is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1492 17th July 2018 15:48
