Old 26th October 2008, 06:13   #1
DarkEraser's Avatar
Default Overheating when AC on
My M800 overheats when I use AC. Without AC it runs perfect. No overheating at all.
Can anyone help me to find the solution?
Thanks in advance.
DarkEraser is offline   Reply With Quote
Old 26th October 2008, 11:01   #2
get the radiator cleaned
remove the radiator valve during summer
check the radiator fan whether it is running while ac is on
harry2223 is offline   Reply With Quote
Old 26th October 2008, 11:18   #3
humyum's Avatar
Thanked: 2,502 Times
Bhai, If u remove the radiator valve, the coolant will flow continiously without any concern for maintaining a constant working engine temperature.Will lower the efficiency of the engine if the working temperature is not maintained.
If the valve is faulty, get it replaced with a new one but dont remove the entire thing out.
Old 26th October 2008, 23:23   #4
Thanked: 103,332 Times
DarkEraser, is the air-con an after-market fitment? If so, you need to upgrade your cooling fan.
Old 27th October 2008, 00:12   #5
DarkEraser's Avatar
Tomorrow, I will check and update you all.
Thanks.
Old 27th October 2008, 14:17   #6
800 always have an issue with cooling, check the A/c Gas,Clean the radiator with air/ water,Thermostat, last option is the bearing for A/c compressor.
jayraj is offline   Reply With Quote
Old 27th October 2008, 14:28   #7
Thanked: 146 Times
Thanks in advance.
would like to know if you use coolant to top up when the radiator / reservoir is low. many people top up with water. Result is when car is driven without AC there is no temperature rise but when AC is switched on the temperature rises significantly.
Also as suggested see if the AC fan is switches when ac is on. and also as GTO has said.
Jr Godzilla is offline   Reply With Quote
Old 27th October 2008, 20:46   #8
DarkEraser's Avatar
Update:
Fan in front of Radiator is working fine. When AC starts, Fan starts rotating and vice versa.
There is coolant + water in radiator and reservoir. I always top up both. In past, I had used 100% water in radiator with AC on and never encounter such problem.
Recently I added coolent without flushing radiator. Because at that time I had no idea how to flush the radiator. But I removed all coolant+water from the reservoir using pipe and then added coolant + water. I guess, radiator flush may solve this problem.
If possible, tomorrow I will show my car to some local mechanic; as I am not a technical person to check radiator valve etc.
Thanks!
Indica V2 DLS - Engine overheating/AC issues ajaysurfs Technical Stuff 8 18th June 2012 20:54
Esteem - engine overheating - TECH2 gives normal reading ad75 Technical Stuff 22 10th March 2008 12:01
Overheating problem in corsa... gkrishn Technical Stuff 2 14th March 2007 10:52
Engine Overheating: Urgent Help Needed! Su-47 Technical Stuff 14 3rd March 2007 10:38
Overheating Zen VXi DueLLeR Technical Stuff 10 30th May 2005 13:46
