Old 16th July 2009, 14:06   #16
leadf00t's Avatar
Thanked: 12 Times
looks like it time to update , amey.
talks of bigger brother means we are now glued to this thread.
we heard enough about the swift and getz . now lets go back to the mitsubishi territory.
leadf00t is offline   Reply With Quote
Old 16th July 2009, 14:56   #17
prince_pervez's Avatar
Thanked: 34 Times
One question. Can we change the front grill of an old lancer to a new model's grill? I mean the latest model grill with the vertical teeth if I may call it so.
prince_pervez is offline   Reply With Quote
Old 16th July 2009, 15:20   #18
razor4077's Avatar
Thanked: 258 Times
This is off topic, but to answer your question, you can change the grille to the new shape, but you will have to change the bonnet as well. The older bonnet is shaped differently in front and won't fit with the new grille.
A cheaper option is to get a custom-made grille.
razor4077 is offline   Reply With Quote
Old 16th July 2009, 15:26   #19
Thanked: 34 Times
@razor4077, thanks a lot buddy. So I am looking at a 7 - 8K budget right ?
Old 16th July 2009, 16:07   #20
pramodkumar's Avatar
Thanked: 947 Times
Razor missed the head lights, so it will run even more expensive. The head lights are different, the indian lancer 99-2002 is based on Evo4 and 2003 - 2009 evo 5 (not counting cedia as lancer)
pramodkumar is online now   Reply With Quote
Old 16th July 2009, 16:08   #21
Thanked: 947 Times
Razor missed the head lights, so it will run even more expensive. The head lights are different, the indian lancer 99-2002 is based on Evo4 and 2003 - 2009 evo 5 (not counting cedia as lancer), the grill that you are looking at is evo 5 based
Pramod
Old 19th June 2011, 11:39   #22
redeye's Avatar
Default Re: Suspension change for Lancer
hey guys , need to change my Lancer's suspension front and rear. Need a good place where I can Buy and get them fitted in Bangalore.
redeye is offline   Reply With Quote
Old 5th November 2011, 04:52   #23
Thanked: 212 Times
Hi redeye, what did you finally get done on the suspension front, and from where ? My Lancer needs rear suspension work too, so thought to ask
lancer_rit is offline   Reply With Quote
Old 10th November 2011, 10:03   #24
redeye's Avatar
It Turns out that my suspensions were just fine. I took my car to Car Nation bannerghatta road and got them checked, there was a problem with the front lower arms got them both replaced , now the car has no noise and feels good on the roads again.
Old 10th November 2011, 12:42   #25
Thanked: 212 Times
Front lower arms are part of the front suspension :-) So, was Car Nation knowledgeable about Lancer front suspension and with topics like torque settings for the various bolts etc (to change the front arm, they would need to unbolt and bolt back the new arms) ?
And you used OEM or aftermarket parts ?
I downloaded the Mirage service manual from another thread in tbhp, but I am not sure if the torque ratings for various bolts in the suspension are exactly same for the Indian Lancer ?
Old 11th November 2011, 11:46   #26
redeye's Avatar
Sorry no idea about the torque settings for various bolts etc I didn't ask them regarding that. Yes they need to unbolt and bolt back the new arms :-). I used OEM parts.
redeye is offline   (1) Thanks Reply With Quote
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
is it time to change my front suspension?? zenopio Technical Stuff 8 4th March 2008 20:12
Gypsy suspension change Gypsy Modifications & Accessories 3 11th December 2007 19:27
Rear Suspension Change for the Ikon 1.6 danlalan Technical Stuff 5 4th February 2007 21:22
Suspension noise on Lancer? ancer Technical Stuff 19 15th November 2006 14:52
