Old 27th October 2008, 00:13   #1
Thanked: 7 Times
Default removal of swift hatchback interior plastic trim, anyone?
hello friends,
i did not knew where to post it, this section seemed most appropriate so i did, if not then mods please do the necessary, i would request fellow bhpians to mention the correct way in which one an remove the rear plastic trims of suzuki swift vxi petrol, i mean the hatch door interior trim cover, i noticed one screw and unscrewed it but yet it dosent come out, do i need to pull it out using some force of what because it vibrates because of my sub and i would like to do some damping there , so please advise thanks
makanaka is offline   Reply With Quote
Old 27th October 2008, 00:27   #2
srishiva's Avatar
Thanked: 929 Times
You need to pull it from the side closer to the B pillar and then lift it up little. There is only screw which you have already removed.
srishiva is offline   Reply With Quote
Old 27th October 2008, 01:52   #3
white_vdi's Avatar
Thanked: 18 Times
shiva is right. you have already removed the only screw, now just pull it out. i would say start from the bottom and go up. its easy and nothing will break so dont worry.
white_vdi is offline   Reply With Quote
Old 27th October 2008, 20:00   #4
Thanked: 7 Times
thanks friends , i am going to do a diy job on the sound damping in my boot, then on the doors, silence of the lambs kinda sound deadning lolz (just the notion)
Old 30th October 2008, 13:45   #5
menonrajesh's Avatar
Makanaka, it would be great to see the pics of the process. Will you?
menonrajesh is offline   Reply With Quote
Old 30th October 2008, 15:35   #6
Thanked: 13 Times
I did this few months ago, its probably on my DDiS thread. If not I will hunt for them and put them up.
Interior Mods in Innova by DC - Anyone done here? Mt.olympus Modifications & Accessories 1 12th August 2010 14:18
Anyone here into DIY - Redoing interior whatcanthisbe DIY - Do it yourself 11 16th April 2007 14:04
Does anyone have Palio 1.6GTX interior pannels? merve_extreme Shifting gears 0 13th April 2005 02:07
