Old 27th October 2008, 13:04   #1
arindambasu13's Avatar
Thanked: 167 Times
Default Issue with clutch on M800- please advise
Hey All,
My 800 (2006 model) was due for service at 20k kms. However, due to various reasons, I have not been able to get it serviced in time, and it is now running at 21.7 k kms. For the past few days, I have been noticing that the normally butter-smooth clutch is a little hard and has a distinct grinding feel to it when depressed during gear changes.
My question is- is this because of the fact that the car is overdue for service? Or do you think there is some other more serious problem? Otherwise the car is fine. I am normally very particular about services, and have maintained the car in pristine condition till date.
Please help! Need your advice on this.
arindambasu13 is offline   Reply With Quote
Old 27th October 2008, 14:10   #2
Clutch plate may have an issue and if not rectified it will spoil the flywheel which can be an expensive option,this is a regular wear & tear for all cars you can either use MGP clutch assembly or Bosch.
jayraj is offline   Reply With Quote
Old 27th October 2008, 16:32   #3
Thanked: 2,469 Times
Usually a M800 clutch lasts a minimum of 40 k kms if used as per specifications, You cant guarantee a lifetime of any moving parts BTW.
Get the clutch replaced asap since yours is almost a new car. I'am running the non asbestos valeo clutch and have covered almost 35k kms on it.It has also towed some heavy metal thrice over long distances and still running good.
There are imported clutch available which are good for M800 priced around Rs.3000.
Old 27th October 2008, 17:50   #4
Thanked: 167 Times
Hi Pavan and Jayraj,
First, thanks for your inputs.
Second, I want to stress that that grinding feeling is very minimal, and I noticed it only sinc till date the clutch has been very smooth. No problems with gear shifts though. So can i drive for a couple of days more?
Third, Maruti A.S.S. is a good place to take care of this problem? Or do I need to go someplace else in Bangalore?
Old 27th October 2008, 18:01   #5
sumeethaldankar's Avatar
Thanked: 1,154 Times
Originally Posted by arindambasu13 View Post
Hey All,
Grinding noise may be indicate problem with the clutch cable rather than the clutch itslef.If you are having problems while changing gears or if you
are experiencing jerks or drop in pickup etc then that might indicate a clutch problem.
Best is to give it to a MASS for a checkup.
sumeethaldankar is online now   Reply With Quote
M800 - clutch plate prob ariendj Technical Stuff 27 24th February 2009 07:16
Advise on Tata Safari Dicor clutch/No pick-up problem Rohit26 Technical Stuff 22 16th November 2008 00:27
AC issue in M800 zulfikar Technical Stuff 16 12th April 2006 18:54
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
