Old 27th October 2008, 15:15   #1
Radnam's Avatar
Default Idling issues in my Fiat Palio
I need help Urgently. Yesterday I had been for a drive to Nagao near Alibaug in my GTX. While returning back my car refused to remain on "IDLE". The engine just started dying out on idle. Driving on clear roads was no problem but the engine either died out or kept on with a heavy judder on idle. Also I had to press the accelerator hard to pick the car on first gear. I am confused, is it the Fuel Pump or the Injector.
I just pray its not a blown up injector.
Experts please Help!!!!
Note: The car was serviced just a week before. Petrol filter, sparks plugs changed, Oil Change done.
Radnam is offline   Reply With Quote
Old 27th October 2008, 17:46   #2
Cleanup the throttle and check the idle sensor and the air filter this would solve the issue.
jayraj is offline   Reply With Quote
Old 27th October 2008, 19:55   #3
gemithomas's Avatar
Thanked: 136 Times
First thing is to check if it repeats itself. Then try cleaning the throttle body and then changing the lambda sensor. Either of these should be rules out before you move into checking the fuel pump and injectors.
The 1.6 FIAT is quite famous for irregular idles due to throttle body and lambda/oxygen sensor issues.
Old 27th October 2008, 21:18   #4
jalsa777's Avatar
Thanked: 1,044 Times
check the idle screw on the throttle body
jalsa777 is offline   Reply With Quote
Old 27th October 2008, 21:43   #5
amit_mechengg's Avatar
Thanked: 1,539 Times
u need a throttle body cleaning. also check the vacuum pipe whether it is fitted correctly.
amit_mechengg is online now   Reply With Quote
Old 28th October 2008, 13:41   #6
Radnam's Avatar
Default Update
Thanks Guys,
I was not able to visit my mechanic personally but my brother took the car to him. He said one of the cylinders is "Missing Out". He doubts injector clog. He is not ready to touch the engine today. He will only look into it on Friday. (Removing Palio's injectors is a tideous task?)
I am just praying its not a blown up injector. BTW Palio's Injectors cost 3500/piece and above in the market? True?
Old 28th October 2008, 21:09   #7
gemithomas's Avatar
Thanked: 136 Times
Originally Posted by Radnam View Post
Thanks Guys,
I think you can check for a missing injector by removing your spark plugs one by one. If there is no change in engine behaviour when any one of the injector is removed, thats the injector that is malfunctioning.
Old 29th October 2008, 15:58   #8
Radnam's Avatar
Thanks! Gemi. I will have to wait till friday for my mechanic to check it. Any idea about how much the injectors cost? Does 1.2 and the 1.6 share the same type of injectors?
Old 4th November 2008, 16:28   #9
Radnam's Avatar
Default No Progress yet
Hi All,
Latest Update! I am still waiting. Mechanic didnt turn out on Friday. His Buddy tried some things as instructed to him over the phone. I was personally present there. Things we tried on Friday.
1. One of the plug wires was failing to pass current. Changed the Plug wires (Rs 1250).
2. Checked and cleaned all the injectors.
3. Found the Fuel injection tube had cracked from inside and was leaking. Changed, finding this one was a tiring task. (Rs 2300!)
4. Checked ignition coil. Was working fine.
Result, the judder is still there!. Infact the car is now completely dying out on idling.
Spoke to my mech over the phone as he was out of town. Said he will check ECU and the "Vaccum Pipe".
I am just finding myself helpless as I am not in town.
Old 5th November 2008, 15:14   #10
Radnam's Avatar
Default Update
I spoke to my mechanic over the phone today. He said some Idler Gear/ Valve in the Throttle Body is malfunctioning. I dont know what that means. Said he will try and borrow a throttle body from another 1.6 and check to confirm.
He said if the above mentioned part is the culprit, the whole throttle body needs to be changed. I dont know when and where this is going to end.
Can some body help with the throttle body prices?
Can I get a second hand/ repaired throttle body?
Old 5th November 2008, 16:58   #11
amitpunjani's Avatar
Thanked: 101 Times
Hi
The "Idler Gear/Valve" which your mechanic told is actually IAC ( Idle Air Control Valve). The valve only starts operating when the throttle body is closed for the air to pass through.
Honeslty i don't have this car, but it is certainly no advisible to replace it will second throttle body.
thanks
Amit
amitpunjani is offline   Reply With Quote
Old 6th November 2008, 16:54   #12
Radnam's Avatar
Default Update
Originally Posted by amitpunjani View Post
Hi
thanks
Amit
Hi Amit,
Thats what he said, "IAC"! You mean to say the whole throttle body needs a replacement if the Valve goes kaput?
Throttle body cost, any idea?
Mandar
Old 6th November 2008, 17:38   #13
planet_rocker's Avatar
Thanked: 365 Times
@rednam - please check out these threads:
http://www.team-bhp.com/forum/techni...ight=Palio+RPM (ECU repairs for palio)
http://www.team-bhp.com/forum/techni...ight=Palio+RPM (FIAT Adventure issues)
planet_rocker is offline   Reply With Quote
Old 6th November 2008, 17:44   #14
Thanked: 101 Times
Hi Amit,
Mandar
Hi Radnam
I am not sure, but in alot many cars this is separately attached. Perhaps Palio owners can comment better.
thanks
Old 6th November 2008, 18:01   #15
Radnam's Avatar
Thanks Planet Rocker!
The second thread is very helpfull and almost similar to problems I am facing.
Thanks again.
FIAT Palio 1.2 - Issues npraneethreddy Technical Stuff 63 13th September 2012 11:30
Fiat Palio ELX fuel efficiency issues csshyamsundar Technical Stuff 44 30th May 2012 11:03
2002 Honda Accord 4 cyl idling issues! aditya.86 Technical Stuff 10 21st June 2011 20:32
Indigo DICOR - Idling issues?? cnaganathan Technical Stuff 9 18th September 2009 11:53
