Old 29th October 2008, 18:30   #1
webjunk's Avatar
Thanked: 21 Times
Question Swift Diesel - Engine turns off by itself when stopping on 4th gear
My Swift Diesel VDI has done about 5500kms now. The issue started after the first free service.
When I try to stop my car at (Typically at signals), I apply brake with car still in 4th gear, and at a specific point when I know that engine might stall, I press the clutch fully and come to a stop. This is a gradual and involuntary function for me. (My mind is not really thinking of the sequence, but does it naturally) I change back to neutral when the vehicle comes to a stop. (Is there something wrong here in my driving style?)
Now the car (mostly randomly) switches off engine and the steering gets suddenly tighter when I'm about to stop. That's when I realize the engine has switched off. (in the city noise, with my stereo playing, I can't really feel if the engine is running or not - I'm happy about it anyways )
I think its some trouble somewhere in the car. But the service guys at Vipul Motors Noida have not been able to identify it. I can't replicate it when I want it. Does anyone here know or faced such an issue. Please let me know. I also hit a stone slab on highway because of this issue and got my suspension arm bent. (couldn't steer away from the stone slab in the middle of the road, when I braked and engine got switched off at that moment.)
Or is it my driving style causing it? (This is my first diesel vehicle)
webjunk is offline   Reply With Quote
Old 29th October 2008, 18:52   #2
phamilyman's Avatar
Thanked: 3,451 Times
The engine is so heavy and its inertia causes the same, changing gears is critical ji, imho.
Old 29th October 2008, 18:53   #3
Jaggu's Avatar
Thanked: 7,450 Times
My hunch you were driving a petrol car before this and your stopping sequence has to be modified a lil bit. Has happened to me couple of times in the initial few months.
Also with higher torque of diesel engines its not advisable to wait for the engine to stop before activating clutch, this puts unwanted stress on the mechanicals. Better method will be to downshift (again be gentle compared to petrol) and then apply clutch as and when the speeds drop to minimum.
Old 29th October 2008, 19:35   #4
ankit.jhamb's Avatar
had the similar problem with my dzire 1-2 times.but now i have changed my driving style.now i donot shift to neutral directly.
now donot face this problem.try following jaggu`s method.
ankit.jhamb is offline   Reply With Quote
Old 29th October 2008, 19:53   #5
DirtyDan's Avatar
Thanked: 745 Times
Go out on a quiet street sometime and turn OFF your stereo. Stopped, on the side of the road, in neutral, give your car a little shot of fuel on the accellerator and quickly take your foot off the pedal. You will notice that the engine stops revving immediately and goes to idle speed.
I say again, IMMEDIATELY. This is unlike petrol cars wherein the engine takes a second or two to come to idle. My point is, as soon as you get off the accellerator in fourth you are lugging out the engine and it is going to stall because it quickly goes to idle speed. It is your driving habits. Turn off your stereo and take a long drive sometime without it and listen to your car. A diesel makes many wonderful noises which you can come to appreciate, although I grant you it is an acquired taste.
DirtyDan is online now   Reply With Quote
Old 29th October 2008, 20:40   #6
tush's Avatar
It happened to me once when i slowed down to take a right turn from a circle at a four square. The engine suddenly turned off and i wasnt able to steer as the steering got tight. I remember that i had pressed the clutch all the way down and wasnt accelerating at all. This is when the engine turned off. I quickly turned the engine on and averted any accident. Thankfully it was during the night hours and there was no traffic. But after that it never happened again. May be it was the driving style i guess.
tush is offline   Reply With Quote
Old 29th October 2008, 20:44   #7
Thanked: 252 Times
Simply depress the clutch pedal a little earlier than you are currently doing! That should resolve this issue.
Old 29th October 2008, 20:46   #8
Thanked: 21 Times
Ok reading this thread has brought to my mind a stupid question. How should one stop when driving a petrol? I'm a novice driver.. I switch the gear to neutral while the car is still running and then slowly start applying the brakes to bring to a complete stop. Is this normal? Am I damaging my car?
LastActionHero is offline   Reply With Quote
Old 29th October 2008, 22:38   #9
webjunk's Avatar
Thanked: 21 Times
Never do that again. Its NOT normal. Its definitely an invitation to disaster. Never come to neutral while running. (And NEVER on down hill) When the vehicle is still in gears, with clutch still engaged, the engine itself will provide some amount of resistance. And that helps in braking the vehicle. And also to some extent, prevents wheels getting locked while hard braking. Always its good to apply brakes first and apply clutch a little later. (One needs to learn that sequence, timing and co-ordination)
Originally Posted by DirtyDan View Post
... quickly take your foot off the pedal. You will notice that the engine stops revving immediately and goes to idle speed.
.... My point is, as soon as you get off the accellerator in fourth you are lugging out the engine and it is going to stall because it quickly goes to idle speed.
I might agree with you Dan. I also felt, it was as if the fuel was sucked out of the engine and it dies. I will try to change my driving style and see what happens.
And to clarify to others, here down shifting may not happen because some times, there is not enough time or distance to do that at all in city conditions.
Last edited by Rehaan : 29th October 2008 at 22:51. Reason: Please use the MULTIQUOTE button instead of making multiple consecutive posts.
Old 29th October 2008, 22:53   #10
Rehaan's Avatar
Thanked: 22,581 Times
This has been discussed in plenty of detail in several other threads, lets continue this discussion in those threads only.
http://www.team-bhp.com/forum/techni...e-braking.html (Engine Braking)
http://www.team-bhp.com/forum/techni...ing-right.html (Shifting to Neutral or Pressing the Clutch when Braking - Is this right?)
cya
R
Old 3rd November 2008, 22:24   #11
Thanked: 21 Times
Thanks for the info. Will try to avoid my action from now on and follow the right sequence.
Old 9th July 2009, 16:17   #12
Default me too
webjunk - do you still feel the engine stalling problem? I have been facing it quite frequently in Dzire Zdi now in 7500 - 10000km range. Have got it checked at Maruti Service masters, delhi and they could not replicate it but admitted that they have seen the problem in some other cars. It could be due to faulty clutch.
saurabhb2000 is offline   Reply With Quote
Old 9th July 2009, 17:00   #13
webjunk's Avatar
Thanked: 21 Times
No Saurabh, I dont have that problem now. As DD stated, I just changed my driving style little bit and the problem is gone. Changing from petrol driven cars to diesel for the first time, I think I had to slightly re-adjust my style.
Most Service guys I've come across are really not equipped to answer any technical or theoretical questions. They are basically trained to repair (sometimes just replace) the parts. period.
Suresh.
Old 9th July 2009, 20:18   #14
mukeshgoel's Avatar
Thanked: 369 Times
Hi, I am also facing this problem since the time I bought my Swift VDi in March. Sometimes, it happened with me 2-3 times a day and sometimes not even once in a week.
While coming at halt (or almost halt) from speed, on a red light or a round about, I used to press complete clutch till the time the car stops or about to stop, in the process the engine turns off and a result steering power is gone.
Told this at the time of 5k Service but SA could not find anything wrong in the car. Now my car has been driven 7300 kms.
Was planning to put it on on forum for last few weeks. Now after reading this thread, now (at this moment) I realize that I need to change my driving style for this diesel car. I have been driving petrol cars for last 12 years.
While typing this message IIRC, I faced this problem maybe once in last 15 days, so automatically my driving still is improving I guess.
mukeshgoel is offline   Reply With Quote
Old 12th July 2009, 23:23   #15
Exclamation
Hi user your car must have some kind of unwanted impurities in your throttle part or the rpm controller u must check it and make it cleaned.
THEAGCUSTOMS is offline   Reply With Quote
Swift Dzire (Vxi) - 4th gear vibrations cbzire Technical Stuff 21 11th January 2017 13:16
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Radiator Fan never turns off! aargee Technical Stuff 11 13th November 2012 11:49
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
