Old 2nd November 2008, 18:30   #1
need_for_speed's Avatar
Question Suzuki 1300 Twin Cam Engine For Zen
I need information on the Suzuki 1300 Twin Cam 16V Engine.
I have purchased it for my Zen Carb. I want to know if it can be bolted with my existing carb manifold instead of the ECM or do i have to make any alterations?
Please Do furnish me any other deatails you know about this engine!
need_for_speed is offline   Reply With Quote
Old 2nd November 2008, 23:52   #2
Thanked: 54 Times
search around on the net for suzuki swift gti service manual, that should have complete details for the 1.3 DOHC engine.
do you have all the fuel injection bits of the engine (ECM, injectors, manifold, harness), if yes, it would be easier to run it with fuel injection itself.
In case you want to run it with the carbs, its recommended you make a custom manifold and run it with two carbs for better results
As for running it with the zen manifold and carb , in case the manifold bolts without much trouble, you shpuld be able to run the car with your stock or a rejetted/reworked mikuni carb. However you may not be able to reap the complete benifits of the swap .
techn0l0gist is offline   Reply With Quote
Old 3rd November 2008, 14:48   #3
Psycho's Avatar
Thanked: 95 Times
Originally Posted by need_for_speed View Post
You will need to fabricate a new manifold if you dont have the one that came with the car.
Old 3rd November 2008, 19:25   #4
i have all the ecm and wirings, but want to do it with the carbuerator. According to my Mechanic it will give more power. At first I want to run with one Carbuerator to see how the engine performs. After that planning in modifying it. Therefore just wanted to know if anyone has done any work on this engine before? and does the Zen Carb Manifold jus bolt on. I had valled VIPER and he said that it is Bolt On.
I just want to Confirm it with other BHPians. and could not find the Suzuki Swift Gti manual. Please Guide me
Old 3rd November 2008, 19:54   #5
Hey Guys sorry i had miunderstood VIPER.
Old 3rd November 2008, 20:25   #6
Thanked: 54 Times
a well tuned carb setup might be more powerfull than the stock EFI - however IMHO its not worth all the effort since you have all the EFI bits(i'm not sure why your mechanic said he can get more power with carbs though - unless he has some fancy ideas).
It might be a better idea to run with the EFI first (the engine is supposed to be around 100 bhp stock!) and then maybe try to do things to make it go even faster in case your not still satisfied with your little pocket rocket
Old 3rd November 2008, 20:49   #7
furioussphinx's Avatar
Guys, where and how easy is it to source in an EFI 16V engine? And how much would it cost me?
And how much would a normal Esteem carb and EFI cost?
furioussphinx is offline   Reply With Quote
Old 3rd November 2008, 21:47   #8
Mpower's Avatar
Thanked: 1,687 Times
Your mechanic is off by a country mile.
using a single carb means you will not have the equal length runners which is key to the powerband of any hi-performance engine.
If you ahve the complete engine, then forget carbs..they are history.
PS: can we have more details on the engine like the kms, price and source?
Old 3rd November 2008, 22:17   #9
Thanked: 53 Times
hey need_for_speed , if you have a EFI system on the engine and it is working than do not change the setup, it will be faster then a single carb system any day , the enigne was rated to 100bhp in factory tune. again getting a intake manifold made will be a problem. Multiple carb setup will work but tunning is a big issue there.
Why is your mechanic telling you this is a big mistry. EFI is more effiecient than the carb setup any day.
Furioussphinx, EFI 16V engines can be picked up at any scrapyards or mumbai chor bazaar the place for cheapest parts.[if you can bargain]
dinar is offline   Reply With Quote
Old 3rd November 2008, 22:40   #10
tadukuttan's Avatar
Thanked: 22 Times
need_for_speed, that sounds like your tuner_needs_money and you will be left with car_without_speed.
So, who is the tuner?
tadukuttan is offline   Reply With Quote
Old 3rd November 2008, 23:12   #11
prabhuav's Avatar
Thanked: 112 Times
@ tadu this is only a simple mechanic - not a big@$$ TUNER
prabhuav is offline   Reply With Quote
Old 3rd November 2008, 23:39   #12
tadukuttan's Avatar
Thanked: 22 Times
Ah okay. Probably has no clue on using the ECM?
Old 4th November 2008, 13:18   #13
Hey Guys the tuner is Satish from Chennai. The Tuner is good. He has just suggested for a test run with 1 carb because i havent yet even started the engine. Its run 18000 KMS and i got it for 35000, the whole thing
I am from chennai. I also need some good sport bumpers and side skirts and spoilers. Can anyone pls suggest.
Old 4th November 2008, 14:32   #14
Thanked: 53 Times
Is it a complete GTi engine r a esteem block with twin cam head and stuff?
Old 4th November 2008, 15:03   #15
esteem_lover's Avatar
Thanked: 451 Times
Good one tadu.
But there are some really good tuners who believe the carb can be tuned to out perform the mpfi cars.
2003 Maruti Zen Engine Swap : Twin Cam 1300cc GTi Power IndrojitSircar Technical Stuff 47 25th February 2015 09:51
Urgent Need of Parts for SUZUKI 1.3L Twin Cam need_for_speed Technical Stuff 0 4th April 2009 10:18
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
Rear engined, twin cam engine Maruti 800. Check out the video. mclaren1885 Modifications & Accessories 10 5th October 2007 21:20
Twin Cam Zen For Sale v1p3r Shifting gears 14 4th September 2007 08:44
