Old 14th January 2009, 13:04   #136
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Originally Posted by v12 View Post
My suggestions :
Get rid of all the stickers (38, Top Speed, Windshield Honda, blackened lights etc)
Try to locate the original 5 spoke aloys.
If you're going in for a body-kit go for something that is similar to the original kit offered by Honda.
Remove the logos and get them chromed and give the car a good polish.
Keep the car original.
Absolutely Spot On! i've been telling you this since day 1!
Tejas@perioimpl is offline   Reply With Quote
Old 14th January 2009, 13:10   #137
v12
v12's Avatar
Thanked: 4,080 Times
Thanks Tejas.
Harry, check out Manveet's gallery for the skirts.
v12 is offline   Reply With Quote
Old 14th January 2009, 13:16   #138
Fillmore's Avatar
Thanked: 141 Times
Originally Posted by Tejas
What are those two stickers on the top of the headlights? In my opinion you should remove them!
Originally Posted by harry2223 View Post
they are matt black tape as it is necesarry here to cover the upper half of headlight
Cover the upper HALF of the headlight ?
That's one big 'Half'
Fillmore is offline   Reply With Quote
Old 14th January 2009, 19:54   #139
ok friends i will do all this according to your suggestions.thanx for help. i am pretty confused about body kit whether to get it or not as my drive is mostly rural
harry2223 is offline   Reply With Quote
Old 21st March 2009, 16:12   #140
hi friends i upgraded wheels from 13 inch to 15inch with apollo acelere tyres 195/55 r15.
Old 21st March 2009, 17:12   #141
here are the picture i bought them second hand
Old 22nd March 2009, 01:06   #142
Thanked: 13 Times
Smile
Originally Posted by dipen View Post
i dont think it came with skirts
Hey Dipen, The 1.5 exi s did come with side skirts
hellsangelzooms is offline   Reply With Quote
Old 4th April 2009, 21:44   #143
Default Adjust ohc idle rpm
hi friends
i want to know that can i adjust ohc idle rpm as it is low when ac is on and does not a shoot up when ac is switched on. if yes can you please guide me how can i do it.plz reply... urgent
Old 11th April 2009, 22:38   #144
Thanked: 660 Times
how did the rpm became low. Did you tuned it at dealership recently, or did you serviced it recently.?/
Old 12th April 2009, 09:20   #145
i had to disconnect battery for charging after that idle rpm is ok but when ac is switched on rpm does not shoot up as it was earlier
Old 13th April 2009, 01:13   #146
Thanked: 660 Times
Just a simple question, is your AC working properly. (if you increase the rpm by the accelerator).?
Old 13th April 2009, 12:38   #147
Thanked: 103,537 Times
Check / clean your throttle body. Also take a look at the air con idle control valve, the FICD was always a problem with my 118NE.
Old 18th April 2009, 09:12   #148
ac is working properly. where is ac idle control valve located
Old 18th April 2009, 11:57   #149
Default ohc air conditioner problem
hi friends i have an ohc 1999 model. the problem is that the air conditioner is not that chilly the cooling is not much . i think this could be due to slower blower speed as temperature at vents is pretty low but cabin is not so cold. i got the ac serviced and gas topped up. tha e other thing is that the compressor cuts off after some time. it cuts off sooner at low blower speed .
Old 18th April 2009, 12:12   #150
Thanked: 253 Times
Looks like the suction filter (if there is one) is choked or the evaporator coil is clogged.
Hope all your controls are at correct settings.
Finally Finally Finally!!! sudeep.bansal Introduce yourself 7 26th June 2013 23:04
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
Finally I got a new car: it's Honda City V AT in Deep Sapphire Blue pratim Test-Drives & Initial Ownership Reports 88 8th August 2011 15:47
Finally, finally , finally..after 2applications. I am here!! Fordmanchau Introduce yourself 4 22nd July 2009 15:20
Finally got used Esteem looking for Mods bhogalrajnish Modifications & Accessories 23 4th December 2006 12:52
