Old 18th April 2009, 12:25   #151
Originally Posted by anupmathur View Post
Looks like the suction filter (if there is one) is choked or the evaporator coil is clogged.
Hope all your controls are at correct settings.
where is the suction filter located
harry2223 is offline   Reply With Quote
Old 18th April 2009, 13:19   #152
Thanked: 252 Times
Harry, I do not know whether the OHC has an air filter and so, of course, I do not know the location!
If the air flow is reduced the only reasons are a choked filter or evaporator. It is possible, though unlikely, that the blower fan is defective.
Old 18th April 2009, 13:29   #153
The gas pressure may also be over the limit during the last fill in. This also cuts off the compressor.
If the gas pressure is high, effective cooling does not take place resulting in the perception that the air speed is low or the cooling is not effective.
kingshukt is offline   Reply With Quote
Old 18th April 2009, 14:28   #154
ghpk's Avatar
Thanked: 192 Times
Originally Posted by harry2223 View Post
ac is working properly. where is ac idle control valve located
what car and model we are talking about ?
Old 18th April 2009, 18:14   #155
ohc 1.5 exi type 1 model 99
Old 18th April 2009, 18:36   #156
ankitahuja's Avatar
Thanked: 46 Times
Refer to this thread:
http://www.team-bhp.com/forum/techni...max-speed.html
Old 6th May 2009, 17:02   #157
thanx friends and it was a blown fuse. it is 7.5 amp fuse should i replace with same or can go for 10 amp so that it doesnot blow again
10A will possibly burn components of the circuit in question while saving your fuse if and when you do get a surge. do you want that?
silver_shadow is offline   Reply With Quote
Old 6th May 2009, 19:18   #158
Thanked: 15 Times
Infractions: 0/1 (5)
The only car of mine which often has fuse issues is Esteem and i replace them with the general ones available . Would it really matter this much ? You suggest i check on the fuses with the ones specified outside of the Fuse Box ? Other than that, i have fuse installed for Fog lamps installed on my various cars and for the aftermarket fancy horn lines too . Would you recommend any fuse rating for these 2 equipments too ?
delhi2009 is offline   Reply With Quote
Old 28th August 2009, 13:04   #159
honda3938's Avatar
hi friends i have a problem with old honda city the car steering start to vibrate above 110kmph. every thing is ok below this speed .What could be the reason ??
honda3938 is offline   Reply With Quote
Old 28th August 2009, 13:37   #160
ImmortalZ's Avatar
Thanked: 139 Times
Wheel balancing is a possible solution.
Old 28th August 2009, 16:20   #161
Tejas@perioimpl's Avatar
Thanked: 4,878 Times
As ImmortalZ said, first check balancing.
If it doesn't work, use another car's tyres and rims and check for vibrations again.
I had a similar problem. Disappeared when i got a complete suspension overhaul done. Could be one of the following factors either individual or working together:
Tie rod issue, axle issue, broken engine mounts.
Tejas@perioimpl is offline   Reply With Quote
Finally Finally Finally!!! sudeep.bansal Introduce yourself 7 26th June 2013 23:04
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
Finally I got a new car: it's Honda City V AT in Deep Sapphire Blue pratim Test-Drives & Initial Ownership Reports 88 8th August 2011 15:47
Finally, finally , finally..after 2applications. I am here!! Fordmanchau Introduce yourself 4 22nd July 2009 15:20
Finally got used Esteem looking for Mods bhogalrajnish Modifications & Accessories 23 4th December 2006 12:52
