Old 19th November 2008, 07:40   #46
nothing till now so i need more suggestions for adding some accessories
harry2223 is offline   Reply With Quote
Old 19th November 2008, 09:57   #47
the VTEC guy's Avatar
Thanked: 138 Times
harry, congratulations on your city. its a great deal at 1.65 just by looking at the pictures. the badge says its a 1.5exi-s these are also very rare. not sure whats the difference compared to standard 1.5exi but i think it came with side skirts. When I got my VTEC the used car dealer had sold a 1.5exi-s at the same time thats when I had seen it first time.
the VTEC guy is offline   Reply With Quote
Old 19th November 2008, 19:29   #48
another question friends can i fit type 2 tail lights without any mod to boot
Old 19th November 2008, 19:34   #49
Default honda city rpm query
hi friends i have one query that whats the default rpm reading during idling.mine is 1k rpm
Old 19th November 2008, 19:45   #50
vikram_d's Avatar
Thanked: 940 Times
1k according to me is a little high. Most of the petrol cars I have know idle between 700 - 900 rpm.
Old 19th November 2008, 19:57   #51
Thanked: 1,172 Times
around 800 mark for my NHC iDSI.
BTW, for cold starts (e.g. early winter morning), it starts at around 1500 and then gradually settles down to 800.
Also, the rpm jumps a little (by around 100) when you swtich on A/C while idling.
anandpadhye is offline   Reply With Quote
Old 20th November 2008, 11:02   #52
Tejas@perioimpl's Avatar
Thanked: 5,475 Times
NO. I've attached pictures below of type 1 & 2 lights and they are quite self explanatory.
I still repeat my earlier question: Why do you want to mod a beautiful car? It's good as it is.
Tejas@perioimpl is offline   Reply With Quote
Old 20th November 2008, 17:44   #53
i dont want any overdone mods but simple mods like some stickers or vinyl which will look sober and give it a unique look
Old 20th November 2008, 21:02   #54
GTO - Touring's Avatar
1000 is definitely on the higher side, you need to get it adjusted. My OHC idles at 700 - 800 rpms (once warmed up).
GTO - Touring is offline   Reply With Quote
Old 21st November 2008, 06:40   #55
Path_Finder's Avatar
1K is high as mentioned by everyone.
But the figure should be checked when engine is warm and A/C is off. The A/C can also make a difference of 200 rpm.
Also check that there is no error in meter. The scale will not be linear in lower readings and a small error can show up.
Path_Finder is offline   Reply With Quote
Old 21st November 2008, 09:59   #56
Swifty2008's Avatar
I have a Swift Petrol. My rpm goes upto 1K in cold starts. I believe, this is Ok as the engine is warming up. After I cover some distance, it comes down to 700.
Swifty2008 is offline   Reply With Quote
Old 21st November 2008, 10:02   #57
toiingg's Avatar
Thanked: 83 Times
My OHC idles at 1000 on cold starts, and between 700-850 once warmed up.
toiingg is offline   Reply With Quote
Old 21st November 2008, 10:50   #58
i've not observed my OHC's rpm in detail. I'll check in the evening and post again.
Old 21st November 2008, 11:12   #59
Ali G's Avatar
on cold morning starts it goes as high as 1500rpm, but settles to 850 when warms up.
should one refrain from pressing the clutch while the car is at 1500 rpm; since its more like hitting the gas and pressing the clutch at the same time. My question is should one wait till the rpm settles down(although it takes a good 3-4 minutes to warm up)
Ali G is offline   Reply With Quote
Old 21st November 2008, 15:27   #60
Swifty2008's Avatar
No need. I have not seen anybody waiting for the car to warm-up. Atleast I don't do it. I start and drive out immediately.
Finally Finally Finally!!! sudeep.bansal Introduce yourself 7 26th June 2013 23:04
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
Finally I got a new car: it's Honda City V AT in Deep Sapphire Blue pratim Test-Drives & Initial Ownership Reports 88 8th August 2011 15:47
Finally, finally , finally..after 2applications. I am here!! Fordmanchau Introduce yourself 4 22nd July 2009 15:20
Finally got used Esteem looking for Mods bhogalrajnish Modifications & Accessories 23 4th December 2006 12:52
