Old 16th December 2008, 05:23   #106
akshay4587's Avatar
Thanked: 1,686 Times
So they are vapours only.
so no need to worry.
Old 16th December 2008, 08:05   #107
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Yep, seems to be vapour, but i have never observed such a thing ever with my OHC since the last 7 years.
BTW, since the last couple of weeks a lot of threads have cropped up with issues relating to the OHC, what's happening?!
Tejas@perioimpl is offline   Reply With Quote
Old 16th December 2008, 08:12   #108
akshay4587's Avatar
This happens in winters usually in when temperature dips below 10 degrees.
since you are in mumbai so climate wont be that cold.
As for issues with OHC's-with the third generation here i guess they are ageing
Old 16th December 2008, 08:16   #109
I've been to a lot of colder (below 10) places with my OHC during my winter breaks earlier and hadn't noticed this there either!
As far as aging, my OHC can run rings around the NHC anyday! ANHC i still need to TD before commenting... but i'm confident my OHC will be upto the task!
Old 16th December 2008, 08:18   #110
akshay4587's Avatar
Originally Posted by yogisays0909 View Post
Similar problem with my carb esteem. loads of white smoke and it drinks oil like buttoms up (Increased after engine flush and oil change). need to add a litre after evry 500 kms.No loss of mileage or pickup by any chance even the collant level never goes down.
Runing MSD blaster ss 8207 , 8.5mm Super cond cables, bosch plugs.
Are the piston rings due for replacement ? If yes how much will it cost including the labour, and how many kms of low revving after the rebuilt.
Attaching a video for example which shows the white smoke after running from mumbai to pune at moderate speed.
This kind of smoke directly links to worn out piston/rings.
Old 16th December 2008, 08:51   #111
johnda's Avatar
Thanked: 11 Times
...BTW, since the last couple of weeks a lot of threads have cropped up with issues relating to the OHC, what's happening?!
I guess its the Decade Syndrome it's been 10 years since OHC was released here in India
johnda is offline   Reply With Quote
Old 16th December 2008, 10:52   #112
kutlee's Avatar
Thanked: 202 Times
i think this is moisture that you are seeing. defenitely since this disappears after a while. place your hands and see if your hands get moist just like you place on a steamer.
kutlee is offline   Reply With Quote
Old 22nd December 2008, 13:56   #113
kbalii's Avatar
Thanked: 21 Times
Closed mirrors, to me, are a warning of dangerous drivers!
Yes, I know many of the BHP-team preach and practice a look over the shoulder before lane changing, and ORVMs do not entirely remove the need for than anyway, there is still a blind spot, but I do believe that regular use of all RVMs is a part of good driving (Thad's Dad used to say: I want you to be able to tell me what's behind you anytime I ask; you should not need to look first, because you should e looking regularly)
The Left ORVM is particularly good for saving two-wheelers who do not know what that flashing light on the side of the car means.
So my message is, don't not use it because you are not used to it: get used to it!
I agree. You should use it or rather get used to it.
Sorry, What was I thinking?
kbalii is offline   Reply With Quote
Old 22nd December 2008, 22:41   #114
theEnd's Avatar
I use my OVRMs heavily and would love to get electrically adjustable ones fitted in my car (if theyre available as aftermarket accessories)
theEnd is offline   Reply With Quote
Old 24th December 2008, 17:54   #115
Default ohc steering wobbles
hi friends my car steering wobbles when i press brake pedal at high speed . no other issues it only pops while pressing brake pedal at high speed. i got the suspension checked and replaced one shock because left tyre had abnormal wear inside. but i didnt got tyres balanced and rotated can this be due to tyres or warped rotors as no issues are seen unless you press brake pedal
harry2223 is offline   Reply With Quote
Old 24th December 2008, 17:55   #116
vikram_d's Avatar
Thanked: 940 Times
It is definitely a case of warped brake rotors.
Old 24th December 2008, 22:48   #117
GTO - Touring's Avatar
Get your brake discs skimmed alongwith a pair of new pads.
GTO - Touring is offline   Reply With Quote
Old 5th January 2009, 21:19   #118
Default power mirror and blower not working
hi friends my old honda city power mirrors , rear defogger and blower ,heater have stopped working today. please help me .
Old 5th January 2009, 21:23   #119
laluks's Avatar
Thanked: 9,725 Times
May be some fuse blew off in the lines for these equipments. Check the fuse box.
laluks is offline   Reply With Quote
Old 5th January 2009, 23:03   #120
white_vdi's Avatar
Thanked: 18 Times
i also feel its some fuse gone kaput.
white_vdi is offline   Reply With Quote
Finally Finally Finally!!! sudeep.bansal Introduce yourself 7 26th June 2013 23:04
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
Finally I got a new car: it's Honda City V AT in Deep Sapphire Blue pratim Test-Drives & Initial Ownership Reports 88 8th August 2011 15:47
Finally, finally , finally..after 2applications. I am here!! Fordmanchau Introduce yourself 4 22nd July 2009 15:20
Finally got used Esteem looking for Mods bhogalrajnish Modifications & Accessories 23 4th December 2006 12:52
