| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #18 (permalink) |
| Distinguished - BHPian ![]() | The wear pattern when you swap them will be different. It's normal practice in workshops to swap the left and right pads when such a sound comes. More often than not the sound goes away if it's due to a small particle in the brake pads. An alternate is to request for a new set of pads under warranty.
__________________ Let's get "instigated"..... \ / ][ |) `/ [_] "!" |
| | #19 (permalink) |
| Senior - BHPian | True. But please correct me if i am wrong:- in a brand new car, there won't be such significant wear (should be hardly 2% IMO). Then how will it help?
__________________ This post may contain information that's unsuitable for overly sensitive persons with low self-esteem or no sense of humor. |
| | #20 (permalink) |
| Distinguished - BHPian ![]() | Not wear but wear pattern. So when put on one side it rubs one way and when swapped it will rub the other way. If theres a particle in the pads causing the sound it will get worn out.
| | #21 (permalink) | |
| Senior - BHPian | Quote:
BTW: Why is everyone concentrating on the pads only. Couldn't there be a manufacturing defect in the discs?
__________________ This post may contain information that's unsuitable for overly sensitive persons with low self-esteem or no sense of humor. | |
| | #23 (permalink) |
| Senior - BHPian | why not? if everyone is saying that a stone or something is between the pad and disc or rust on the pad which causes the noise, then even a small elevation on the disc should theoretically make the noise.
| | #24 (permalink) |
| Senior - BHPian | A small elevation would mean constant sound and it would have been there from day one which is not the case with this car. Also a small elevation on the disc would have made a similar but depressed mark on the pad and there would be no sound.
__________________ Been there. Done that. |
| | #25 (permalink) | |
Let's see what his final cure turns out to be...
| | #26 (permalink) |
| Distinguished - BHPian ![]() | Not only that, a small elevation on the rotors would mean that the car would shudder under braking. When the elevation passes under the pads you can feel the shudder from the pedal. Had a set of rotors replaced FOC the very next day on my Lancer when I got the rotors changed and the new set was shuddering like crazy. Found that one rotor had a fraction of a mm elevation on end causing the shuddering.
| | #29 (permalink) |
| Newbie Join Date: Nov 2008 Location: Bangalore
| Simply ask Toyota to replace the parts (whatever it is, brake pad or clips or disk, you really don;t care). Let me explain to you why I said so.... I brought an Altis on Oct 17th. On Oct 18th evening, I first got the same screeching sound on braking. Slowly it became really loud and I started feeling embarrassed. On Oct 19th morning, I took the vehicle to the service centre(though Sunday, fortunately the service station was open for half a day). They then did some cleanup and lubrication job. The sound was gone. Next day morning again the sound came back. Then I told the Sales guy that I want to talk to someone from Toyota. He then gave me the contact number of their Sales in-charge from Toyota (not the dealer). I took off on him saying that how can a new vehicle be like this? I told them that I want him to replace whatever part is faulty. Also, from Toyota Customer Relations, they called me up and took a detailed note of the problem. I again told them that I want the faulty parts to be replaced. They agreed to look into the matter. I also threatened that I will go to consumer court if the problem is not resolved immediately. Then the dealer guy again took the vehicle for repair and returned it to me after the servicing (without any replacement) and claiming that the problem won't reappear. I threatened the service in-charge that if it reappears then I will take it up with the consumer court. After this round of servicing, the problem did not repeat for a few days. In the meantime, Toyota customer relation called me up and said that they will be replaing the faulty parts in a few days. To my surprise, the problem again resurfaced within 2 days and by that time already the parts arrived at the dealer. The dealer then took the vehicle and replaced the parts (I assume it is the brake pads). It is now about 10 days and there is no more sound. In the meantime, I also took the vehicle on a long distance trip (about 400kms in total) and there was no sound. Hence, I guess that there may be some problem with the current batch of brake pads and the same needs replacement. |
| | #30 (permalink) |
| BHPian Join Date: Jun 2008 Location: Jaipur
| On the other forum as I mentioned earlier, the guy got his car checked and company replaced 3 of his shockers which they said was the reason behind this noise and also told that there is some issue with shockers of 2000 cars. Is that possible? |
| Thread Tools | |
Similar Threads | ||||
| Brake Noise Problem with Verna SX ABS | varma | Technical Stuff | 1 | 13th March 2009 16:22 |
| Toyota Corolla ALTIS AT | mrkanitkar | Test-Drives & Initial Ownership Reports | 16 | 3rd January 2009 12:24 |
| Brake fluid/Parking Brake Indicator light- Is this a problem? | santosh.s | Technical Stuff | 7 | 12th November 2008 00:05 |
| When to buy Corolla Altis | venka007 | What Car? | 31 | 22nd October 2008 16:24 |
| All new Corolla coming soon EDIT: Corolla Altis now Launched | extreme_torque | The Indian Car Scene | 295 | 20th September 2008 00:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
