Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 31st January 2009, 18:03   #61 (permalink)
R2D2's Avatar
Default Brake Noise Gone
Guys,
Took the car to DSKT this morning for the brake noise problem that I was experiencing.
They replaced only the front brake pads and the noise is gone. Was watching the technicians work on my car. As expected it has nothing to do with the suspension. The entire brake assembly plus the ABS and EBD system is made by Bosch.
Couldnt identify the maker of the gas filled mcpherson struts.
Also had the engine oil and filter replaced as I always do after the running in.
Cheers!
Old 31st January 2009, 18:14   #62 (permalink)
Gurkha's Avatar
I fail to see why these new cars have iffy brakes that don't last and sadly also develop issues, this is not the first Toyota I see with this issue, I see some Laura, Accent, Scorpio with issues under 20,000Km. If the pads on my ancient 10 year old Gurkha are still running at 117000km, why shouldn't these so called latest tech vehicles last at least till 50,000km minimum.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Gurkha is offline   Reply With Quote
Old 31st January 2009, 18:25   #63 (permalink)
Maybe to do with the fact that Asbestos is not being used anymore.
All the old cars had asbestos based brake pads.
Old 31st January 2009, 18:27   #64 (permalink)
Gurkha's Avatar
You have got a point there, however if carbon fiber is being used, it should outlast asbestos based pads handsomely. I guess its just cost cutting poor design and of course, good business to make poor customer replace pads at 20,000km, makes good revenue.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Old 31st January 2009, 18:35   #65 (permalink)
vid6639's Avatar
You have to also remember that these car's are capable of much higher speeds than a gurkha and will eat up pads more. Also these car's have brake boosters which I'm not sure the Gurkha has.
The reason was replacement was not premature wear but some particle in the pads causing the screech.
Carbon fiber would be way too expensive for pads.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 31st January 2009, 18:38   #66 (permalink)
Gurkha's Avatar
The Gurkha does 140kmph on a body far more heavier than the Altis so the physics are actually worse for the pads of the Gurkha and to my knowledge, I am yet to see any disc brake system on a 4 wheeler sans booster. The Gurkha comes with a booster since 87.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Old 31st January 2009, 18:47   #67 (permalink)
R2D2's Avatar
The brake pad replacement was due to a defective design or choice of materials. Nothing to do with wear & tear or effectiveness. It was only the noise that was irritating. My old Corolla (9G) didnt have a single prob with the brakes.
Rgds,
Old 31st January 2009, 18:54   #68 (permalink)
vid6639's Avatar
The M800 has discs up front with no boosters.
__________________
Old 31st January 2009, 19:00   #69 (permalink)
Gurkha's Avatar
I stand corrected but then M800 is a small hatch, to put put disc brakes on a vehicle of Gurkha's size would be a totally ineffective.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Old 31st January 2009, 19:01   #70 (permalink)
Gurkha's Avatar
Rgds,
Rhandle who is a forum member here would differ with you, his Corolla although generally trouble free has given him plenty of woes on regular basis regarding frequent and costly brake pad replacements. The Scorpio in my family has been the same story, first brake pads replaced at 22,000km and now by 48 its needing another one.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Old 31st January 2009, 19:19   #71 (permalink)
I also had a screechy brake pad on my Corolla AT at around 18K, and got them replaced. The noise started low at 15-16K. Thankfully, the replacement has now run for 18K without a hint of a noise. Cost me Rs. 5600 for all brake pads.
__________________
For one who sees Me in all beings and sees all beings in Me, I am never lost, nor is he ever lost to Me.
vasudeva is offline   Reply With Quote
Old 31st January 2009, 20:19   #72 (permalink)
R2D2's Avatar
Gurkha, I cannot really comment on why his Corolla has given problems. There are too many variables that could have caused it. I am speaking about my experience not just in the Corolla but other cars such as the OHC as well. In fact technicians at the dealers have remarked on how well my brake pads have stood the test of time.
IMHO, I'd trade in a some amount of brake pad life for better braking. I do not compromise on tyres and brakes. It can save lives.
Rgds,
Old 31st January 2009, 21:34   #73 (permalink)
Gurkha's Avatar
Rgds,
So would I, never faced this premature issue in my Accord V6 though even though it has been raced quite a few times, I do have carbon fiber pads from Mugen though.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Old 31st January 2009, 22:23   #74 (permalink)
R2D2's Avatar
This is interesting. Any idea if I can get CF pads for the Altis? Hope you dont mind me asking...what did they cost you? Did you replace the rotors as well?
Rgds,
Old 31st January 2009, 22:33   #75 (permalink)
Gurkha's Avatar
Rgds,
Yes I put cross drilled rotors but the callipers were left stock Nissin. You can get carbon fiber Corolla Altis pad from any of the mail orders doing TRD parts. Bear in mind, Carbon fiber needs getting used to in traffic, they heat late and loose heat quick, response times initially will scare the hell out of you, they don't do anything at first and then they grip and when they do, its almost instant lock ups.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Thread Tools
Brake Noise Problem with Verna SX ABS varma Technical Stuff 1 13th March 2009 16:22
Toyota Corolla ALTIS AT mrkanitkar Test-Drives & Initial Ownership Reports 16 3rd January 2009 12:24
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 7 12th November 2008 00:05
When to buy Corolla Altis venka007 What Car? 31 22nd October 2008 16:24
All new Corolla coming soon EDIT: Corolla Altis now Launched extreme_torque The Indian Car Scene 295 20th September 2008 00:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
