Old 9th November 2008, 23:20   #1
Spinnerr's Avatar
Thanked: 155 Times
Default Leaf spring suspension "modification" - Is it okay?
Hijacking!
But its related to Leaf Springs.. 'Search' didnt come up with a better thread. So here is a small query.
Recently I had my Bolero serviced, and the mechanic had used a spanner to put some space between the leaf and the clamp holding it in place. He said "otherwise the leaf would rub with these parts and you will hear a lot of squeak".
It kinda made sense, looked as if it was a preventive step, but now I am wondering, would that extra space be a problem when taking a tight curve with 5+ people on board, would the leafs shift, move around, cause permanent damage!
Another view:
Spinnerr is offline   Reply With Quote
Old 10th November 2008, 18:51   #2
Spinnerr's Avatar
Thanked: 155 Times
Now I am little concerned.
I have been looking at a couple of leaf spring setups (on the comp, ofcourse) and I see that none of the rebound clips are 'open ended' like the one I have on my Bolero.
Here is the real one
And when I checked Sabareesh's thread, in this particular post he had a pic of his Jeep's suspension. There again the rebound clips were closed, clamped down.
Now I have an open clip, that has been stretched out so as to not touch the leafs.
So now what? do I get it into its old form or shall i get them clamped down . Any inputs?
Old 10th November 2008, 21:59   #3
Shashank.A's Avatar
what was the initial setup like ? Was the clamp closed or was just tighter or closer ?
Shashank.A is offline   Reply With Quote
Old 10th November 2008, 23:01   #4
star_aqua's Avatar
Thanked: 89 Times
Get them clamped asap. With the current setup, the chances are the leafs will spread sidewards. though they cant move forward or backward due to center bolt. since all the leafs are not held together, this could cause serious damage when you are off the road due to articulation.
star_aqua is offline   Reply With Quote
Old 10th November 2008, 23:07   #5
Thanked: 54 Times
When the rebound clip is closed ,then the spring plates can take more load as the load is somewhat split btwn all the connected plates . The rebound rate is also higher
when the rebound clip is open , the suspension is a bit more soft and the load carrying capacity is also reduced .
The open clip is used for assembling the spring plates ,one on top of the another and to secure it to the axle . Even if there is a gap after assembly , it dosent matter any more as long as the U clamps are secure .
Old 11th November 2008, 11:03   #6
Spinnerr's Avatar
Thanked: 155 Times
Originally the clip was closer to the leaves, but not closed.
Originally Posted by greatmana2000 View Post
When the rebound clip is closed ,then the spring plates can take more load ......
When the rebound clip is open , the suspension is a bit more soft....
Now, this make sense. I think I get the the clamps back into their original shape before I take the next long trip, for city driving I feel the clamp is secure enough.
Thanks for the tip greatman!
Old 11th November 2008, 11:23   #7
Shashank.A's Avatar
Spinnerr, please note that greatman is talking about closed clamp and not closer clamp. The clamp in your car was originally open only, and the difference is gap between the clamp and leafs.
Old 11th November 2008, 11:40   #8
Spinnerr's Avatar
Thanked: 155 Times
.....it dosent matter any more as long as the U clamps are secure .
oh, is that so? Greatman had said, 'U' clamps, so I thought he was talking about the open ended ones.
Old 11th November 2008, 13:12   #9
RedMM340's Avatar
Thanked: 24 Times
Really bad idea spreading the clamps.
Bend them back to the original shape and apply some grease to prevent noise.
RedMM340 is offline   Reply With Quote
Old 11th November 2008, 13:39   #10
Thanked: 54 Times
Thank you for correcting .
U clamp = closed clamp in truckers speak .
Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspension? GTO Technical Stuff 600 4th July 2018 17:18
Spring spacer & Spring rate question Sankar Technical Stuff 15 23rd January 2011 20:21
Parabolic Leaf Spring Suspensions - are they good or bad? lalith_ka Technical Stuff 35 22nd March 2010 19:23
Softening ride by removal of leaf spring Mohnish Modifications & Accessories 11 22nd July 2008 19:23
