Old 13th November 2008, 13:29   #16
Rohit26's Avatar
I will again go to tata workshop for rechecking..
Also tell what should be the idle RPM for gear shift for 3.0 Ltr Dicor..
I always upshifted my gear around 1600 RPM..Was i right ?
Rohit26 is offline   Reply With Quote
Old 13th November 2008, 13:49   #17
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
@Rohit26
I have PMed you how i had solved my tata safari problem. Although it is not very similar to yours. let me know if it helps.
Tejas@perioimpl is offline   Reply With Quote
Old 13th November 2008, 15:59   #18
suman's Avatar
Thanked: 257 Times
Originally Posted by Rohit26 View Post
He inspected the car & ask for a test drive..He told me there are no issues with the car/clutch.Clutches malfunction have other symptoms attached.
Pardon my saying so but this sounds like a typical A-One diagnosis. Please visit another workshop.
1600 is very nice; I personally shift closer to 3000 rpm but to each his own
Old 13th November 2008, 16:03   #19
1600 rpm is too low for the 3.0 DiCOR. Try and take it to 2000 rpm at least in each gear. The manual recommends ~2300 rpm for good acceleration.
hrag is offline   Reply With Quote
Old 13th November 2008, 17:58   #20
simply_sunny001's Avatar
Thanked: 15 Times
Idle RPM for 3.0 dicor is 700 RPMs +/- 50
I usually shift at 2000 in normal circumstances which has been suggested by TASS and does well too.
1600 is LOW,how can you drive Safari so meekly?
have some fun and upshift at least after 2k,bro.
simply_sunny001 is offline   Reply With Quote
Old 13th November 2008, 18:06   #21
navpreet318's Avatar
Thanked: 894 Times
^ 2300 to 2500 rpm is good for decent driving without stressing the engine.
but for my fun driving i prefer 3000rpm and it sometimes even crosses it.
navpreet318 is offline   Reply With Quote
Old 13th November 2008, 19:39   #22
Rohit26's Avatar
Originally Posted by Tejas@perioimpl View Post
@Rohit26
I always idle engine for atleast 3 mins before any movement & again idling for 1 min before ignition off.So i think that may not be the cause...
Originally Posted by simply_sunny001 View Post
that mechanic is not competent,your clutch has gone but not completely,i repeat again.
You want to see it for yourself,then do this.
Go to a highway kind of stretch,take the beast to 5th gear
brake and downshift to 4th and press the pedal hard
and the same symptoms that you have mentioned earlier will be seen.
Ok
when i use "simply_sunny001" above trick symptoms comes back but it dissappears when i upshift near 2200 RPM normally ..
Old 16th November 2008, 00:27   #23
Thanked: 15 Times
Rohit
i used to go to Nawab Motors in Noida who were still OK and respected all warranty issues as my safari was bought from them.
Now they have closed,so only Sterling/Dynamic are left and no good reviews exist for them.
i would suggest you to go to Autolinks in Gurgaon and leave early so that all clutch assembly replacement work can be completed in like 5 hrs.(Please PM suman for Autolinks)
And bro
i have told very clearly that your clutch is not gone fully and if you dont have Warranty left then let it go till it really starts troubling you.
and you seem to be a very sedate Safari driver so you might end up with the same clutch assembly for another year.
If situation worsenes,then get the Clutch assembly changed.
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
Advise on Safari Dicor 2.2 Rust Treatment adc Technical Stuff 16 1st December 2008 11:59
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
