Old 12th November 2008, 09:51   #1
Default Indica V2 Diesel: Most dash board light blink like left/right turn indicators!
i have a peculiar problem. when turn on the ignition all lights in the dashboard start blinking (coil, engine check, etc...). i called up the "b u bhandari" (dealer) helpline in pune and they informed me that my batteries need a change. i have run 60,000 km in approx. 3 years.
do I really need to consider a battery change, or it could be something else thats gone buggy?
also, appreciate if you could suggest me a good pair of batteries for my Indica V2 diesel (if i really need to change the oem exide's now)
--bhuvan.
bhuvanmisra is offline   Reply With Quote
Old 12th November 2008, 10:24   #2
amit_mechengg's Avatar
Thanked: 1,556 Times
ask them to put a new battery for a while and check whether the above problem goes off.
yes 3 years is quite a time for exide OEM battery. for a replacement i would always prefer AMARON over exide.
Old 12th November 2008, 10:34   #3
Swifty2008's Avatar
Yes. 3yrs is a long time for an OEM battery. Replace with a new one only if the problem is rectified with the new one.
Swifty2008 is offline   Reply With Quote
Old 12th November 2008, 10:52   #4
rkavthekar's Avatar
Thanked: 7 Times
I guess 3 years is OK time to change the battery, especially considering the mileage of your car. I changed my OEM Exide battery after 4 years with around 55K running. That too I feel coz, accidently once I drained by battery completely with headlights kept on for full day. Had to jump start the car and re-charge rge battery at EXIDE shop. But, it went dead again in few weeks.
I did not have preference for Aamron or Exide or any other battery. Just went to nearest battery shop ( happened to be Exide ) and installed new battery. This again has done near to 40K in last 2.5 years and no issues yet.
takecare and drive safely
rkavthekar is offline   Reply With Quote
Old 12th November 2008, 11:28   #5
nishantgandhi's Avatar
Thanked: 151 Times
Pardon the n00b question - is battery life determined by number of years or mileage?
nishantgandhi is offline   Reply With Quote
Old 12th November 2008, 12:06   #6
vikram_d's Avatar
Thanked: 940 Times
Not really. But most of the batteries last between 2 - 4 years with an odd exception here of there.
Old 14th November 2008, 23:04   #7
Path_Finder's Avatar
Battery life is normally in number of charge/discharge cycles it has undergone but both the age and mileage will have an indirect bearing on the life.
Path_Finder is offline   Reply With Quote
Old 18th November 2008, 11:56   #8
thanks. i'll probably try the amaron ones and talk to the amaron pit stop (f. c. road) if he can actually help me with a trial (at my residence, where the car is parked!)
Use of turn indicators to change lanes in traffic and the highway. Does it matter? Dippy Street Experiences 42 25th May 2015 17:21
LED turn indicators flashing too fast - How to fix it? quadra Modifications & Accessories 15 21st April 2014 15:59
Performance Boosters for vehicle behind you - Your TURN INDICATORS rkbharat Street Experiences 7 17th October 2007 17:17
Dash board indicators lighting up - while Swift is in motion emkay456 Technical Stuff 3 13th March 2007 11:06
No right turn, but how about a U turn? adya33 Street Experiences 14 28th September 2006 20:10
