Old 12th November 2008, 18:09   #1
windsurfer's Avatar
Thanked: 25 Times
Question Palio sport 1.6 - Clutch noise
I hear a sound whenever i press or release the clutch. It started few months back. The service center (not TASC) advised me to change the clutch kit.
Though it is not a problem as such and the car has been running fine since 3 months but the noise sure is very irritating.
Any ideas what could be wrong?
windsurfer is offline   Reply With Quote
Old 12th November 2008, 18:11   #2
Thanked: 34 Times
What kind of sound is it?
deepakhon is offline   Reply With Quote
Old 12th November 2008, 18:13   #3
windsurfer's Avatar
Thanked: 25 Times
it sounds like tak, tak.
Old 12th November 2008, 19:45   #4
Thanked: 85 Times
I had a similar experience on my 1.6. Its apparently a spring issue...was changed free of cost during 3rd service
JishD is offline   Reply With Quote
Old 12th November 2008, 20:30   #5
Please check the clutch bearing , mostly that would be the problem .One of my friends also had a similar noise from his clutch . Changing the clutch bearing alone would not cost you much . If you are going in for a full clutch overhaul (which i suggest) and you are a performance enthusiast then look at getting a exedy clutch plate from ya nearest dealer .Your mini 1.6 rocket would love being able to put out those horses better . How many kilometers has your present clutch driven ?
aamir_subzero is offline   Reply With Quote
Old 13th November 2008, 11:29   #6
Thanked: 103,777 Times
Most probably, it is either the cable or the spring that is making the noise. Change it; hardly a couple of hundred bucks & 1 - 2 hours of work.
Old 13th November 2008, 11:51   #7
windsurfer's Avatar
Thanked: 25 Times
Thanks guys. I don't think I can change the clutch just now (financial issues). Hopefully as you suggested a spring replacement would work. fingers crossed. I have done about 25k. The clutch was replaced at 9k. So, clutch giving away seems a remote possibility.
Old 13th November 2008, 21:54   #8
Then its got to be an issue of the spring only . please do check up and get it fixed before it wears the clutch . keep us informed of whats happening 2 .!
Palio 1.6 GTX v/s Palio 1.6 Sport - Visible Differences moralfibre The Indian Car Scene 140 21st May 2014 17:21
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Palio 1.6 Sport Vs Palio MJD- pure economics zaks The Indian Car Scene 11 17th March 2008 14:22
help me decide-palio sport or adventure sport 1.6 for city driving premchetan Hatchbacks 46 9th February 2007 17:44
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
