Closed Thread
Old 5th April 2005, 23:43   #1
Unhappy Mondeo Problem...
Hey Guys..
Pardon me.... as I am a new member and have always loved cars but just starting to learn more about the technicalities nw besides my job.
My car has been running perfectly fine until today... . Was driving back today from Pune and on the way back to town and it started giving me real bad jerks through out the way..and finally stopped completely dead.
There has not been any accident with it EVER.. or any other damage. Is it a serious problem?
Solar1 is offline
Old 5th April 2005, 23:47   #2
amitoj's Avatar
Thanked: 1,698 Times
bad fuel is the first thing that comes to mind....
amitoj is offline
Old 5th April 2005, 23:49   #3
Thanked: 350 Times
maybe the fuel injectors got jammed , hence the jerks.
Mondeo's injectors and audio system are known to be problematic.
Also Mondeos are very very sensitive to the quality of fuel it is fed.
dipen is offline
Old 5th April 2005, 23:52   #4
hey.. no its been Speed all the way.. not changed the fuel once
Solar1 is offline
Old 5th April 2005, 23:53   #5
Shan2nu's Avatar
Thanked: 89 Times
What about the fuel pump? Get your car checked by the service station.
Shan2nu
Shan2nu is offline
Old 5th April 2005, 23:55   #6
amitoj's Avatar
Ummmm... even Speed can be adulterated...
amitoj is offline
Old 6th April 2005, 00:16   #7
RJK
RJK's Avatar
Thanked: 16 Times
Fuel pump is what came to my mind as well. Mondeo's are notoriously known for bad fuel pumps & they cost quite a bomb to replace I think.
RJK is offline
Old 6th April 2005, 05:19   #8
hey dude what comes to my mind is a bad fuel pump or chocked injector's or just adulterated fuel...could be any of them...well if the fuel pump has failed...the car will start with a lot of effort and the the minute u leave the gas pedal a little bit...the engine will cut off...as the fuel stops reaching the enigne...also the same could be because of the injector's...so a visit to the company garage is recomended...! cheer...!!
dragger is offline
Old 6th April 2005, 05:58   #9
jigarmuni's Avatar
well may be the fuel injectors.... try getting it cleaned...!
jigarmuni is offline
Old 6th April 2005, 08:12   #10
Rudra Sen's Avatar
Thanked: 4,295 Times
What did you do then?
Rudra Sen is offline
Old 6th April 2005, 09:58   #11
Thanked: 103,639 Times
1. Clogged fuel filter
2. Injectors
3. Failed pump.
All three due to bad fuel quality.
GTO is offline
Old 6th April 2005, 11:13   #12
iceman91's Avatar
Thanked: 22 Times
2. Injectors
3. Failed pump.
not necessarily the ford mondeo has a problem with its fuel pump...it has a very high failure rate.
iceman91 is offline
Old 6th April 2005, 11:18   #13
speedsatya's Avatar
Thanked: 712 Times
Hey Guys..
so how did u get back .and where is the car????????is it still on the road
speedsatya is offline
Old 6th April 2005, 11:34   #14
karthik247's Avatar
Thanked: 16 Times
one thing u should do u use good quality fuel like speed....
karthik247 is offline
Old 6th April 2005, 12:13   #15
one thing u should do is read the previous posts before replying. In post no.4, Solar1 has mentioned that he uses only Speed.
GTO is offline
Closed Thread
Ford Mondeo XR-5 Turbo & Ford Mondeo Reviewed Brosreview Test-Drives & Initial Ownership Reports 8 27th September 2008 03:02
Modded Red Ford Mondeo! + KS Motorsports Turbo/NOS Mondeo Gordon Modifications & Accessories 82 19th October 2006 21:34
new mondeo BikerSG The International Automotive Scene 4 23rd November 2004 21:39
FORD MONDEO petrol wanted........... R.P.M Shifting gears 1 26th May 2004 02:47
New Ford Mondeo. v12 The International Automotive Scene 3 7th April 2004 16:57
