Old 29th April 2009, 10:37   #31
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by Wolffe View Post
Amit-the oil stays in the top cap-its sealed.The horn did work for 10 mins-varied between soft and loud and then went kaput.I'm taking it to the horn repair guys today to have it checked.In my view the motor works fine-something wrong with the trumpet.
Read post number 2 on page 1.
On a different note, I clearly stated in my last post that you need to make "extensive changes" to make this horn work if you really need to.
There is no normal / simple method to repair the Nautilus. It's a sealed unit. If you try to open it, you are bound to break something or the other I believe.
Old 23rd May 2011, 21:59   #32
e-katz's Avatar
Thanked: 19 Times
Default Re: Stebel Nautilus Horns - gargling noise? no noise?
Reviving an old thread - anybody know if the stebel nautilus is available here in chennai?
e-katz is offline   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
