Old 14th November 2008, 10:33   #1
anky's Avatar
Thanked: 107 Times
Default Maruti 800 turnback lights
Hi I have a 1997 m800 and just recently the turnback lights(l&r turn light flash) and hazard switch have stopped working i have checked the fuses any help appreciated.
anky is online now   Reply With Quote
Old 14th November 2008, 11:15   #2
planet_rocker's Avatar
Thanked: 368 Times
check the combination switch (the lever thingy) on the RHS of the steering wheel.
planet_rocker is offline   Reply With Quote
Old 14th November 2008, 15:28   #3
Thanked: 103,618 Times
Yup, most probably the contacts have gone bad. Clean / WD40. If this doesn't help, it's your flasher assembly (small box under the dash)
Old 16th November 2008, 00:35   #4
Thanked: 660 Times
Put on the hazard switch. If all six indicator works the flasher, wiring are fine and ofcourse bulbs are.
Now check the fuses and switches.
DIY Install: LED tail-lights & indicators in the Maruti Swift a4anurag DIY - Do it yourself 39 14th October 2017 13:05
DIY Install: LED cabin lights for the Maruti Swift a4anurag DIY - Do it yourself 112 17th September 2016 13:36
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Service for Maruti 800 at Maruti Service Masters f1head Indian Car Dealerships 20 16th May 2010 18:48
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene 32 13th February 2007 12:57
