Old 25th May 2010, 20:30   #16
mithun's Avatar
Thanked: 59 Times
Originally Posted by wildsdi5530 View Post
Is there any way to check the EPS by oneself?
You can check whether the EPS is responding or not yourselves. Other than that you cannot do anything !
Old 26th May 2010, 07:09   #17
Thanked: 360 Times
How Mithun? are there any tests? or just whether the steering is hard compared to other cars?
wildsdi5530 is offline   Reply With Quote
Old 26th May 2010, 20:16   #18
Thanked: 660 Times
Steering will be extremely hard or frighteningly light.
Or you can go to a service center and hook up a scan tool to check the sensors.
Old 2nd June 2010, 10:11   #19
Thanked: 360 Times
Found an answer on the forum itself:
Originally Posted by vid6639 View Post
Simple way to check if the power steering is working. With ignition off and on is the power required to turn the steering the same?
If the car is off steering will be heavy as the power steering is switched off. When engine is running the EPS turns on and the steering will be light. If this is not happening then your PS fuse is blown or some problem with EPS. If the steering is light with engine on but still not as light as before get the suspension and rack checked.
Old 26th September 2015, 23:02   #20
ZinFluent's Avatar
Thanked: 12 Times
Default Re: Hard Steering wheel of Swift VXi
Reviving an old topic as i am facing a similar problem with my 2008 Swift VXi.
Couple of weeks back, i got the routine wheel alignment and balancing done and for few days after, everything seemed normal however since last couple of days i noticed the steering has become too stiff and hard. Its gone bad to that extent that even after driving 5-10kms at a stretch, i experience pain in my right arm and wrist.
Could this be die to alignment gone wrong or something else to be checked? Any pointers would be helpful.
Thanks in advance!
ZinFluent is offline   Reply With Quote
Old 27th September 2015, 00:08   #21
aswin ajith's Avatar
Thanked: 69 Times
Thanks in advance!
Please get your power steering fluid level checked. It could have gone low.
aswin ajith is offline   Reply With Quote
Old 27th September 2015, 10:15   #22
humyum's Avatar
Thanked: 2,502 Times
Thanks in advance!
Post the alignment readings you must have got after you got the alignment done. It must be too much toe in dialed which is making your steering suddenly hard.
humyum is online now   Reply With Quote
Old 28th September 2015, 21:29   #23
ZinFluent's Avatar
Thanked: 12 Times
Is there any specific reading that i should post? Sorry about the silly question but i can see various measurements listed under front axle like castor, KPI, camber, individual toe, total toe setback and included angle.
Invader 4x4 : Hard steering and steering box leaking DirtyDan 4x4 Technical 26 26th April 2013 13:30
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
