Old 14th November 2008, 23:43   #1
gaurav_diavolo's Avatar
Thanked: 54 Times
Default IKON HEADLAMPS! Axed my own feet!
Hi guys,
Well, I had broken my headlamp because of the car cleaner's stupidity. Now here i was in a spares store searching for a headlamp for my Ikon. I was told that a Lumex headlamp (set of 2) would cost me 3400 and same imported from China would cost 2800. I saw both of them, their being identical purchased the Chinese one.
Now, the fitting was perfect, quality terrific....but to my surprise 90/100 bulbs are not providing sufficient lighting even in city, leave highway alone. I bought new philips bulbs with the headlamps too (so gave away old 55/60 something bulbs to my cousin for his Ikon, so can't test the lights again.). Guys, is this because of pathetic rather miserable illumination from Chinese lamps or did I buy some low power 90/100 bulbs of Philips. I paid 180 bucks for this bulb.
Can anyone in that case suggest me the best possible 90/100 bulb set (got the cutout installed for this upgradation), or have I ruined it all because of the Chinese lights. In Lumex I had 55/60 bulbs which were giving better lighting then what is now (is it that I had some better quality bulbs before...no clue). Totally clueless guys, please help. My highway trips are very unsafe with these lights.
Thank you all! - Gaurav
gaurav_diavolo is offline   Reply With Quote
Old 15th November 2008, 00:42   #2
Path_Finder's Avatar
My first suspicion is on the Chinese HL assembly. Looks may be same, but the reflector may not be of the same quality. If you have the earlier broken unit, try checking this out.
Bulb part – can’t really comment from your description. Best it to buy from a reliable source.
Path_Finder is offline   Reply With Quote
Old 15th November 2008, 00:47   #3
Thanked: 1,642 Times
Gaurav
I know it is easy to lecture after the event, but was Rs.600 really worth taking that chance? If its chinese it should be half-price to take a chance with it - if the difference is not that much, it really isnt worth trying.
Steeroid is offline   Reply With Quote
Old 15th November 2008, 01:38   #4
Akshay1234's Avatar
Thanked: 7,242 Times
did you also get relays and upgrade your wiring or just put in 100/90w bulbs?
Old 15th November 2008, 08:21   #5
toiingg's Avatar
Thanked: 85 Times
Your lights are not focussed properly. Please get that checked. There is a thread on this forum regarding that, go thru it.
toiingg is offline   Reply With Quote
Old 15th November 2008, 09:44   #6
Shashank.A's Avatar
When you say Chinese, do you mean Lumax China or is there any brand name of that ?
1. Check the focus of lights.
2. Ensure that holders are proper and wiring is done properly with relay and all.
3. Change the bulbs, I am using Philips Rally 90/100, and they are simply lovely. Cost around Rs.300 for a pair.
If all this does not work, then you have axed your own feet
Shashank.A is offline   Reply With Quote
Old 15th November 2008, 11:53   #7
No issues man. just try and get your headlight focussed properly , you could do it at home itself al you need is the tool. also ikon has 3 ways of fitting the bulb. three positions in which you could clamp on the bulb .play around with that a little ,set the beam to what you need and am sure you will feel much better . please do buy better quality bulb, a 90/100 bulb should cost you anywhere between 300-500 bucks.trust me its worth it .
aamir_subzero is offline   Reply With Quote
Old 15th November 2008, 12:00   #8
The_Warrior's Avatar
If you have not installed the relay, then please do it ASAP or your Battery is going to drain out much faster and after the installation of the relay if the lighting does not improve then buddy you have been duped.... if it is chines then most probably it is the reflectors in the head lamp which are at fault...
The_Warrior is offline   Reply With Quote
Old 15th November 2008, 13:38   #9
gd1418's Avatar
Thanked: 656 Times
Gaurav, I ditto what Santosh said... In hindi here they say - "mehenga ek baar roye aur sastaa baar-baar roye"
Originally Posted by Steeroid View Post
Gaurav
Old 15th November 2008, 13:59   #10
Shashank.A's Avatar
Mehenga Roye Ek baar, Sasta Roye sau Baar
Old 15th November 2008, 17:44   #11
gd1418's Avatar
Thanked: 656 Times
Ooops..sorry for the misquote. Thanks Shashank for posting the correct saying.
Old 15th November 2008, 21:34   #12
Arpit's Avatar
Default Headlamp Relay
Hey Gaurav, as Akshay rightly pointed out, did you get the 90/100 lamps fitted with a Relay or did you just replace it with the Stock Bulbs.
Arpit is offline   Reply With Quote
Old 16th November 2008, 02:35   #13
Thanked: 54 Times
Guys, the relay was fitted from before and the lights are well focused. Its just that the lights are not even half sufficient. Are there different types of 90/100 wattage bulbs....can someone suggest me the best one. Only the best will do I suppose......and yes, i saw everything else in the Chinese lights but u see difficult to check the reflection in the shop
And since both were same, I immediately bought!
Old 16th November 2008, 06:15   #14
kuttapan's Avatar
Thanked: 12 Times
@Gaurav - In all probability, the reflectors of the Chinese lights are not good at focussing the beam. Don't think the bulb is the issue, but you can confirm by switching bulbs from a friends car.
kuttapan is offline   Reply With Quote
Old 16th November 2008, 08:31   #15
Awaiting Email Confirmation
Thanked: 319 Times
Default Keep off chinese parts
As far as possible do not use chinese parts for critical applications in any product including toys for children.
As far as computers is concerned try gettting a Taiwanese made product and use Chinese stuff as a last resort. Easier said than done as Chinese products have flooded the market.
drpullockaran is offline   Reply With Quote
Skoda Yeti Style variant introduced in India; Elegance axed Aditya The Indian Car Scene 16 17th December 2015 18:51
Ashok Leyland Stile axed as company plans to stick to CVs Aditya The Indian Car Scene 27 18th May 2015 11:43
Time to own my very own italian beauty - Fiat Linea Petrol E+ rajagopal_j Test-Drives & Initial Ownership Reports 50 13th January 2010 12:51
Porsche Panamera, Cayenne to be axed in wake of VW takeover aaggoswami The International Automotive Scene 4 2nd September 2009 13:04
