Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 16th November 2008, 17:54   #1 (permalink)
adc
adc's Avatar
Default Advise on Safari Dicor 2.2 Rust Treatment
It was this lazy late Sunday morning before going for the bath, with nothing much to do, just thought let me check out the undercarraige - after all this 1 year of extensive drives and particularly after the punishing HP tour.
And did I do myself a favour - you bet I did.
I had this kind of idea:
xxxxxxxxxxxx
Q. My car has several layers of paint when it was applied in the factory; that should offer ample protection, shouldn’t it?
Your car would have good protection against corrosion. However, paint could not resist abrasion, and because of poor road conditions, unprotected paint would suffer from stone chips, scraping against humps or rocks, pitting from gravel, etc. Eventually, a lot of paint would peel or scrape off to expose bare metal to corrosion.
Tata Motors Customer Care :: Anti-rust Treatments
xxxxxxxxxxxxx
And now the pics.
It is not that bad as it looks, just the coating of the paint has peeled off and the rust is beginning to form at those places - but definitely something has to be done immediately. The main undercarraige is perfectly okay, plus found out that it will be okay for a long time as it also lined up with waterroofing material stuff i.e. those sheet materials that we use for roof waterproofing.
It is the other paraphernalia that is affected, particularly the sidesteps rods and the engine skid plate and also the points on which the Safari was jacked up for puncture. The paint had peeled off due to abrasion from the jack and rust has set in.
So my question is -->> Do I go for the antirust treatment which will cost around Rs 5000-6000 [http://customercare.tatamotors.com/s.../antiRust.asp] OR just buy some antirust paint and apply myself at those places. As said, the main undercarraige is fantastically protected with water-roofing grade material and will be rust proof for years - much worried about the side areas.
__________________
Bullet Electra
Safari LX 2.2 VTT -TMT [The Magnificient Tourer]
adc is offline   Reply With Quote
Old 16th November 2008, 18:53   #2 (permalink)
Use the 3M anti rust treatment serviec which they do at T.A.S.S
__________________
"I cannot be fair with everyone in Life" - dadu, 2001
dadu is online now   Reply With Quote
Old 16th November 2008, 20:53   #3 (permalink)
adc
adc's Avatar
Yes most probably that is what has to done now, anyone out here having done the Safari anti rust treatment through TASS. Any feedback? Still would like to know about any options, e.g. """something like much cheaper local garage type process"""
__________________
Bullet Electra
Old 16th November 2008, 21:35   #4 (permalink)
dkamath's Avatar
The dealer had provided the "Wuerth" undercarriage treatment as part of the freebies, while buying the car. Not sure what parts/links were applied with this coat of paint, though. Also recollect that the fuel tank is not covered (probably due to the reaction of the fuel with the chemical).
dkamath is offline   Reply With Quote
Old 16th November 2008, 21:42   #5 (permalink)
Shakensoul's Avatar
If you want to try a DIY job which is going to be cheap and effective, you can try a black/transparent epoxy paint coating, for e.g.
<<<<<< MRF SPECIALITY COATINGS >>>>>>
Or you can buy a bucket of the epoxy paint and hire a local painter to get it done.
Shakensoul is offline   Reply With Quote
Old 16th November 2008, 22:22   #6 (permalink)
adc
adc's Avatar
This point should be of interest to you then
Q. My brand new car has been rust proofed already with another brand, when it came out of the dealership. How does it compare to Tata Approved Anti Rust treatment?
A lot of car dealers offer this package service to brand new cars. There are brand new cars which only have undercoating on areas visible to the eyes, such as the surface near the wheels.
There are undercoating that are dry on the outside, but soft inside (like wax). This type does not have good abrasion resistance, or good sound deadening properties.
Everyone once in a while should see how the undercarraige is holding up, may be every 4 months like.
Thanks for the link and the tip.
Will take a decision in a week.
Anyone out here who has done the 3M rust treatment at TASS?
__________________
Bullet Electra
Old 17th November 2008, 17:29   #7 (permalink)
Just curious to know if the water is hard there or driven near the sea ???
__________________
Old 17th November 2008, 17:43   #8 (permalink)
Hashim's Avatar
You can fix this on your own. First get it thoroughly washed from below then using cloth (and wearing surgical gloves) apply thick layers of undiluted rubber paint. Apply one layer then let it dry, then second layer. Of course can hire anyone to do this for you but such kind of work is best done by self
__________________
Maruti 1000 | Yamaha Gladiator
Hashim is offline   Reply With Quote
Old 18th November 2008, 09:57   #9 (permalink)
adc
adc's Avatar
Hard water should leave stains, does it accelerate rust conditions? Mostly washed in hard water condition.
Thanks much
__________________
Bullet Electra
Old 18th November 2008, 10:03   #10 (permalink)
Any specific brand of rubber paint to be used. How much it cost
__________________
Sx4 - 2008
Getz - 2007
Santro - Sold
HH Passion - 2001
aka_iitd is offline   Reply With Quote
Old 18th November 2008, 10:12   #11 (permalink)
Hashim's Avatar
I have used Jackson (JK is the company name) in my esteem and found it good, no chipping or flakes etc and really feels like a reall rubber after drying. It cost Rs.75 per litre.
__________________
Old 18th November 2008, 10:37   #12 (permalink)
Thanks much
So my suspicion was right, thats what accelerating the rust. I could make that out from the rusted rod in the first picture. The darker parts is where the water stayed and evaporated, rusting the metal.
For hard water, I would suggest as less washes as possible and even the body wash should be done by using a damp cloth and not freeflowing water.
The rubber treatment looks good, use a metal emery paper first to remove/ loosen the rusted particles and then use as directed by the manufacturer. Do post pictures
Ramp it up and use a spraygun for the spread below.(get it done from a body painter)
__________________
Old 22nd November 2008, 07:52   #13 (permalink)
Hi adc.
I would strongly recommend to get the job done at the service center. The 3M coat is good though expensive. But they do give 4year warranty and available at the center all the time. Also get intermidiate checkups whenever you get the Safari serviced (This is part of the service provided by the 3M guys). I have always beleived in getting the underbody treatment done on a brand new vehicle as it inhibits the starting of the rust. That is very improtant because once the rusting starts it gets expensive to get a good job done. In your case the rust will first have to be scraped off completely otherwise the paint will not adhere to the actual metal and the paint will blister. Also I think this material is better if sprayed rather than applied as suggested by someone. DIY only of you have a good spraygun/compressor. Infact as this paint is very viscous the spray pressure has to be quite high. This helps not only in the paint sticking well to the surface but also forces it into small gaps and unreachable spaces.
Its worth paying the guy a bit more and requesting him not to compramise on the quantity of paint he uses especially, in your case where the rusting has already set in.
Ravi Kashyap is offline   Reply With Quote
Old 26th November 2008, 18:14   #14 (permalink)
adc
adc's Avatar
Originally Posted by Ravi Kashyap View Post
Hi adc.
Given the Safari today afternoon at TASS for full body 3M anti-rust treatment at TASS. And the good news is that it is cheaper now for the since the last 2 days, from Rs 4500 to Rs 3560 now. With a 5-year warranty and at this price for a professional anti-rust treatment including the doors and the sills, it is definitely worth it - absolutely all should get this done.
Also the modified cam gear retrofit was for only few Safari 2.2s that came out at the very first lot and not for all.
__________________
Bullet Electra
Old 26th November 2008, 18:41   #15 (permalink)
greenhorn's Avatar
make sure its 3M and not by some local agency. thats what happened to me!
__________________
'07 Indica DLG - Almost a DLX
greenhorn is online now   Reply With Quote
Thread Tools
Underbody treatment / Anti rust coating for the car lottoman Modifications & Accessories 139 17th November 2009 21:12
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 18:31
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
Advise on Tata Safari Dicor clutch/No pick-up problem Rohit26 Technical Stuff 22 16th November 2008 00:27
Advise Swift or Indigo TDI / Dicor ) pankaj_aheer Hatchbacks 34 20th March 2008 13:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
