Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 18th November 2008, 17:00   #1 (permalink)
s.prashanth's Avatar
Default Baleno Suspension Noise
I drive a 3 year old 52k run Baleno. Off late during hard braking when the front end dips there is a kind of knocking sound from the front of the car. I had the car inspected at the dealership and the service advisor identified the noise.
They delivered the car back after replacing the suspension bushes and stabaliser bar bushes and ends. The car drove ok for about 2 days but the noise is back again.
The noise is not constant. It is just kind of knocking under braking. The best example would be, if you have owned a two wheeler and if the front cups and cones are worn out or loose they would make clanking noise when you would go over bad roads. What i have is the same but it makes that noise when I brake hard making the front end to dip.
I know the steering damper noise in the Baleno and this is not.
If any of you have exxperienced it or no someone who can take care of this problem, please point me in the right direction.
s.prashanth is offline   Reply With Quote
Old 18th November 2008, 20:13   #2 (permalink)
You have to tell the service station to give you a refund, since obviously that was not the problem. Can you tell us what exactly they did and how much they charged you?
__________________
Baleno Vxi 05
Ritz Zxi 09
filcord is offline   Reply With Quote
Old 19th November 2008, 12:06   #3 (permalink)
sushrutha's Avatar
Prashanth,
Please check your car's balancing rod as well as tie rod ends.
another possible sound can also be from brake calipers (if not greased well)
__________________
Honda City
Hyundai Santro
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 6th February 2009, 08:47   #4 (permalink)
shuvc's Avatar
Last month the rear suspensions of my Baleno were serviced i.e. Dismantled, cleaned, lubricated. Since then, the rear left has developed a 'boomy' sound when going over humps/rough roads. It sounds like the noise made inside a large empty closed drum.
I'll be taking it back to the workshop soon and hence would like to understand before that, what could be the possible reasons?
The car has run approx 44K kms in 3yrs.
__________________
PIGZILNKILJBSCOMB
shuvc is online now   Reply With Quote
Old 6th February 2009, 16:04   #5 (permalink)
shuvc's Avatar
Got it checked at the workshop today. The spring had slipped off it's anchoring or something like that. I guess they goofed up when refitting last time. Took a TD, seems to have been sorted out.
__________________
PIGZILNKILJBSCOMB
Thread Tools
Strange Noise from LHS front suspension Swift viana Technical Stuff 19 31st August 2009 12:55
baleno making kr..kr..kr..kr noise gigy Technical Stuff 19 6th July 2007 20:33
OHC Rear Suspension Noise After Upgrade viper Modifications & Accessories 11 4th July 2007 12:24
Suspension noise on Lancer? ancer Technical Stuff 19 15th November 2006 14:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
