Old 19th November 2008, 17:52   #1
rg_chn's Avatar
Exclamation Accent - Starting trouble
Guys, i've got a hyundai accent, 6 yrs old now, its in good shape except for one problem. everytime i start the car, it takes quite a bit of time to start!
i've been having this problem for around 4 to 5 months now. HELP!! its actually quite irritating guys. and thr's also a rattling sound from the left front wheel (cant hear it when im driving on very good roads)
rg_chn is offline   Reply With Quote
Old 19th November 2008, 18:41   #2
supremeBaleno's Avatar
Thanked: 1,705 Times
Takes quite a bit of time to start ? Do you mean the engine does not crank easily ?
How old is the battery on your Accent ?
Old 19th November 2008, 19:15   #3
hellstar's Avatar
Thanked: 17 Times
Is your car a CRDI ? and how many KMS it was covered in the past 6 years?
hellstar is offline   Reply With Quote
Old 20th November 2008, 09:19   #4
rg_chn's Avatar
its petrol dude..done around 60k kms..battery should be around 2 yrs old now..
Old 20th November 2008, 09:22   #5
rg_chn's Avatar
yeah it doesnt crank easily..but the second time i try startin it, it starts up instantly
Old 20th November 2008, 10:15   #6
hellstar's Avatar
Thanked: 17 Times
have you tried cleaning your plugs ?
two years i guess its kinnda ok for a petrol car , but for the diesel it might have problems. Between are you running any amplified ICE setup in your car now ?
Old 20th November 2008, 11:04   #7
rg_chn's Avatar
yeah, cleaned them recently..its got an amp, a sub, root horns, 100/130w headlights..
Old 20th November 2008, 19:38   #8
hellstar's Avatar
Thanked: 17 Times
by any chance are you switching on these ICE equipment while cranking or else looks like a battery issue to me , but better if your battery is an Exide take it to the Exide service centre and they will tell you about the battery health but before that do check the electrolyte level in the battery. A.S.S typically forget about this aspect.
I would suspect the starter motor to be weak if the battery is not the culprit here.
Old 20th November 2008, 23:10   #9
rg_chn's Avatar
yeah dude, i never tend to switch off the ICE.. its always on..so whenevr i switch on my car, it goes on too..is it sumthin i shouldn be doin? thr's one more thing i've noticed, when i switch on my car, and a song starts playing, only the front speakers go on, and only after 3 to 4 secs, the whole system( rear speakers, amp and sub) go on..
Old 21st November 2008, 09:49   #10
hellstar's Avatar
Thanked: 17 Times
i usually turn on the ICE after i have started the engine , i guess other wise the amplifier and the other ICE components will have a current being drawn thereby reducing the juice available to the starter motor. Even worse this might also end up in damaging you ICE equipment. I would suggest otherwise.
Dude get ur battery and starter motor check first befores investigating any further :-)
esteem engine starting trouble leaves me baffled!!! adityapd Technical Stuff 47 10th July 2008 12:17
Starting trouble in my one year Old Petra 1.6 ELX Subodh Kumar Technical Stuff 0 11th July 2007 13:59
Starting trouble Fiero F2? ramki067 Motorbikes 0 23rd April 2007 12:10
Starting trouble and Musical Car COUGAR Technical Stuff 3 4th January 2007 05:48
Dark liquid dripping ... from exhaust and starting trouble .. new ZEN gchandra Technical Stuff 3 21st October 2005 09:17
