Old 23rd November 2008, 11:46   #1
live2drive's Avatar
Thanked: 25 Times
Exclamation Verna crdi: black smoke from exhaust
Verna owners, urgent help needed.
Mine is a Verna crdi 2007 model.
The car is absolutely stock with no performance mods.
Until recently, when i try to redline the car or need quick acceleration, what i see in my ORVM is a cloud of black smoke!!
The exhaust oggles out heavy black smoke.
I took this problem to Sunrise Hyundai..
The guy there cleaned the injectors and sprayed some decarboniser to remove any carbon.
For a week or so i did not see any signs of black smoke or so.
But last night tried to rip the car, and what i see in the rear view mirror is : greyish smoke.. Pls note it wasnt the black smoke which was observed earlier.
Has anyone ever had this kind of issue with verna?
P.S. : The car is performing fine: no drop in FE, pickup is good..
Awaiting replies.
Abhinav.
live2drive is offline   Reply With Quote
Old 23rd November 2008, 14:51   #2
live2drive's Avatar
Thanked: 25 Times
Guys plz help me out..
Verna owners where are you all??
Old 23rd November 2008, 15:36   #3
ph03n!x's Avatar
Thanked: 120 Times
What kinda fuel do you use - Normal Diesel or the "Super" avatar?
ph03n!x is offline   Reply With Quote
Old 23rd November 2008, 15:43   #4
pugram's Avatar
Thanked: 36 Times
I think this is normal if you are trying to accelerate hard at lower gears. I have seen this happen in many diesel cars, mostly while overtaking on the highway or at signal's. Try driving normally and observe if the same happens.
pugram is offline   Reply With Quote
Old 23rd November 2008, 15:58   #5
kapilsharma80's Avatar
Thanked: 28 Times
if the car is pumping a cloud of smoke then you need to look into the following:
1. change the petrol / diesel bunk
2. clog / blocked injectors
3. Change the diesel filter
kapilsharma80 is offline   Reply With Quote
Old 23rd November 2008, 16:11   #6
white_vdi's Avatar
Thanked: 18 Times
i have been driving diesel cars for more than 3 years now and think there is nothing to worry.
a) there is accumulation of unburnt carbon in the exhaust in diesel cars. so when you rip her that deposit is what you see in the RVM. if you rev her high regularly this wont happen.
b) other factor might be the quality of diesel you are filling her with. low quality fuel results in higher emission. try a different bunk.
smoke during high acceleration is common in diesel cars so relax.
(seniors i hope i am right)
white_vdi is offline   Reply With Quote
Old 23rd November 2008, 16:14   #7
star_aqua's Avatar
Thanked: 89 Times
Awaiting replies.
Abhinav.
Hi Abhinav, black smoke is due to the inadequate supply of air during quick acceleration and if the engine is loaded. this is common in diesel engines. to overcome this we have turbocharger provided. again the turbocharger will not kick in until the engine goes to at least 2000rpm. during this you will observe black smoke. this is also called as turbo lag. again to overcome this we have VGT(variable geometric turbine) which works from low rpm and maintains good A/F ratio. so please check with the turbo and its operating range.
star_aqua is offline   Reply With Quote
Old 23rd November 2008, 16:15   #8
greenhorn's Avatar
Thanked: 1,518 Times
are you using turbojet?
greenhorn is online now   Reply With Quote
Old 23rd November 2008, 16:17   #9
raj_5004's Avatar
Thanked: 2,064 Times
@ live2drive: see buddy, i dont think the problem is as acute as it sounds. the diesel available in india is not the best. what i mean is it does not burn completely in the combustion chamber which in turn leaves a lot of unburnt hydrocarbons/soot in the exhaust valves and tail pipe. so when you rev hard, the high speed exhaust gases forces this soot outside and hence the black smoke.
however grey smoke or white smoke is a result of lubricant/oil mixing with diesel in the combustion chamber. when this oil burns, it comes out as white smoke. it can be due to worn out piston rings which is not effectively sealing the combustion chamber with the lubricating oil.
Old 23rd November 2008, 17:51   #10
cooldude1988765's Avatar
Thanked: 108 Times
@ raj when you burn engine oil youget blue smoke not white/grey smoke.
Black Smoke
This is due to a air to fuel ratio imbalance, either the fuel system is delivering too much fuel into the engine or there is not enough clean air (oxygen ) a few things to look for :
  • Faulty injectors
  • Faulty injector pump
  • Dirty air cleaner
  • Turbocharger or intercooler faulty
  • Problems within cylinder head, valves clogged up due to faulty EGR (exhaust gas recycling unit)
White Smoke
Normally means that the fuel injected into the cylinder is not burning correctly. The smoke will burn your eyes.
  • Engine/pump timing out
  • Fuel starvation to the pump causing the pumps timing not to operate correctly
  • Low engine compression
  • Water/petrol in the fuel
Blue Smoke
The engine is burning engine oil
  • Worn cylinders or piston rings
  • Faulty valves or valve stem seals
  • Engine over full with engine oil
  • Faulty injector pump/lift pump allowing engine oil to be mixed with the diesel
cooldude1988765 is offline   Reply With Quote
Old 23rd November 2008, 18:41   #11
raj_5004's Avatar
ohhhhhhh, thanks for the info cooldude....
the post i wrote was what we were told by our engineering books!
but i feel you are right.
Old 23rd November 2008, 18:54   #12
S_budhiraj's Avatar
Check whether u are using the normal diesel or Premium one. It happens normally with the Premium diesel, used to happen with my Innova, I got the injectors cleaned and started using normal fuel it works fine know.
I use normal fuel for all my diesel cars, Toyota and Chevvy even recommend u not to use the premium oils as the engines are not tuned for the same. Not sure about the Hyudai though.
S_budhiraj is offline   Reply With Quote
Old 23rd November 2008, 19:01   #13
hellstar's Avatar
Thanked: 17 Times
@line2drive - theres is no reason for you to worry about engine issues unless you are experincing substiantial loss of power ( such as forcing yo to do more gear changes than you regular pattern ) or hearing unusal noises from the engine or turbo.
If you are on premium diesel i would suggest that you switch back to normal diesel and fill diesel preferably for company owned / run outlets. I have had experinces with increased black smoke on filling premium fuel . Also try to stcik to one fuel pump which is a good one , this is of extreme importnace since the engine is a very sensitive engine it reacts sharply to adulterated or low quality fuel.
I have had multiple occasions when i have had to stop the car and clear the diesel filter of water/contaminants within covering 100 kms of filling fuel from highway side pumps. And also note that all diesel cars would spew back smoke when the engine is revved under full load.
hellstar is offline   Reply With Quote
Old 23rd November 2008, 21:19   #14
Thanked: 253 Times
Raj, I would certainly like to know which 'Engineering book' this was!!
This would happen only for a very short duration till sufficient air is available to enable proper combustion. In modern cars that means till the time turbo-boost becomes available.
anupmathur is online now   Reply With Quote
Old 23rd November 2008, 21:23   #15
live2drive's Avatar
Thanked: 25 Times
Guys i am using Normal Diesel.
And i fill up at BP outlet which is company owned and company operated..
white smoke from exhaust...its Turbo baleno neo_trace Technical Stuff 41 28th March 2015 11:39
Smoke from Car's Exhaust-Why? akshay4587 Technical Stuff 9 23rd November 2010 23:02
black smoke from exhaust 2fast4u Technical Stuff 32 10th August 2010 13:48
Dark Greyish Smoke bellows from exhaust pipe Rahulk76 Technical Stuff 7 13th March 2006 01:06
