Old 24th November 2008, 10:32   #1
luky_13's Avatar
Thanked: 104 Times
Default Swift - Brakes Playing Orchestra
I own a SWIFT VXI which has clocked 45,000 KMS in Bangalore. Lately the front discs having started making a noise when braking hard, they sound like a scottish bagpipe playing with maximum bass.
Have the disc pads worn out ? Anyone has an idea what is the life of Swift Brake pads and how much does a replacement cost ?
Thanks.
luky_13 is offline   Reply With Quote
Old 24th November 2008, 11:52   #2
mclaren1885's Avatar
Thanked: 12 Times
Infractions: 0/1 (10)
Not sure if the petrols and diesels have different brake pads but I got mine replaced on my Vdi for 2.5k today. Don't know what these guys are smoking, even the direct import brake pads from Japan for the baleno cost just 1.2k. Btw my car has done 25k kms.
Old 24th November 2008, 13:19   #3
Rehaan's Avatar
Thanked: 5,082 Times
Originally Posted by luky_13 View Post
... Lately the front discs having started making a noise when braking hard, they sound like a scottish bagpipe playing with maximum bass.....
So its not a screeching sound?
Do you feel any vibration in the steering when this happens?
cya
R
Old 24th November 2008, 13:30   #4
luky_13's Avatar
Thanked: 104 Times
cya
R
No its not a screeching sound and the steering does'nt vibrate either.
Old 24th November 2008, 20:43   #5
Dude, you mean to say your brake pads got worn out at just 25K?
Iswear is offline   Reply With Quote
Old 25th November 2008, 20:02   #6
philippose's Avatar
I have got a problem with my swift's brakes and i don't know if this is the right thread to tell this. Then again here goes. I took a new swift 2 weeks back and had no problems with the brakes. But now or a day or two whenever i apply the brakes i feel it is not sufficient enough to stop. I don't get any confidence and i feel the stopping distance have also increased. PLEASE HELP
philippose is offline   Reply With Quote
Old 25th November 2008, 22:10   #7
Rehaan's Avatar
Hmm. In that case its hard for me to make a guess without more information. Maybe someone else might be able to help.
Originally Posted by philippose View Post
...But now or a day or two whenever i apply the brakes i feel it is not sufficient enough to stop. I don't get any confidence and i feel the stopping distance have also increased. PLEASE HELP
Has the brake pedal got noticably harder to press? If so it could be a problem with your brake booster.
cya
R
Old 25th November 2008, 22:53   #8
akshay1234's Avatar
Thanked: 1,629 Times
are you sure its not from the rear drums?
akshay1234 is online now   Reply With Quote
Old 25th November 2008, 23:01   #9
philippose's Avatar
@ Rehaan : The brakes ain't hard to press. It has the same feel but i feel i got to apply more pressure to the brakes than before to make it stop :(
Old 25th November 2008, 23:17   #10
Thanked: 12 Times
Yes, given that it has been through a lot of fast driving in ghats and town I am not surprised. I change the pads on my baleno once in every 10k kms. But then, thats because the baleno sees the track quite often.
Rehaan, I think the problem is due to the skinny tires. Thats all. Upgrading rubber will surely help the braking.
Old 26th November 2008, 00:09   #11
SirAlec's Avatar
Thanked: 357 Times
the first question first! Is your Vxi with ABS option??
Old 26th November 2008, 08:54   #12
philippose's Avatar
@mclaren1885 : the tyres aint an issue here as i am running on 205/60 R14 Potenza.
Old 26th November 2008, 09:37   #13
mtnrajdeep's Avatar
Thanked: 37 Times
I have a VDi with ABS and nowadays the rear brakes make a whistling sound whenever I brake slightly hard. Braking slowly and not putting much pressure on the brakes does not produce this sound!
anyone has an idea on what the reason could be?
mtnrajdeep is offline   Reply With Quote
Old 26th November 2008, 09:39   #14
luky_13's Avatar
Thanked: 104 Times
Non ABS, standard VXI
Old 26th November 2008, 09:47   #15
Swifty2008's Avatar
Probably you should get your brake pads cleaned, brake liners and ABS checked up.
Swifty2008 is offline   Reply With Quote
Swift Service - Brakes and Water Pump Drive Belt Question carboy Technical Stuff 13 14th February 2011 13:01
Grinding noise coming from the front brakes of Swift Vxi when rolling back vivekchugh Technical Stuff 9 18th February 2010 10:58
Maruti Swift Brakes. I regret NOT buying ZXI + ABS no_boundaries Technical Stuff 41 30th December 2009 19:39
Wild rumour about Swift brakes. Baseless though. lin-jo The Indian Car Scene 72 5th March 2009 09:30
Disc Brakes for Swift Back wheel pshyamsundar Modifications & Accessories 39 3rd February 2009 12:32
