Old 25th November 2008, 12:45   #16
Thanked: 50 Times
Having a pictorial guide is a great idea.
Appreciate the initiative, and will wait for things to come
sriturl is offline   Reply With Quote
Old 25th November 2008, 13:05   #17
live2drive's Avatar
Thanked: 25 Times
Originally Posted by im_srini View Post
I'm not sure, but I'm guessing the common home vacuum-cleaner could help here - most of them have a 'blower' attachment that usually goes into where the air's exhaled from the machine.
P.S. - Even otherwise, can't one of the brush attachments be used to clean the filter ?
Never ever use a brush for cleaning the filter coz it will widen the pores of the filter and eventually destroy its functionality, and the filter won't be a filter anymore.
live2drive is offline   Reply With Quote
Old 25th November 2008, 14:42   #18
white_vdi's Avatar
Thanked: 18 Times
Default A pictorial guide to cleaning air filter at home
This is for a swift diesel.
@ greenhorn: your indica will also have the air filter in the starting only. next to the battery only i guess.
open the hood
air filter is placed next to the battery
unscrew the filter box
open the filter compartment and pull it out
clean the filter and put it back
now tighten the screw back.
you have a relatively clean air filter.
white_vdi is offline   (2) Thanks Reply With Quote
Old 25th November 2008, 15:48   #19
live2drive's Avatar
Thanked: 25 Times
Great job white_vdi.. I did that yesterday but cud'nt take the pics..
Old 25th November 2008, 15:58   #20
K a s h's Avatar
Thanked: 31 Times
Originally Posted by greenhorn View Post
Yup I was talking about OE filters. I've seen the K&N guide for aftermarket filters K&N Air Filter Cleaning Instructions
Slightly OT, I tried a lot to get the K&N cleaning kit in Bangalore 2 months ago. Tried in JC Road and Hot tracks. Everyone said that it was not available in the market anymore. Finally I had to settle down to Green cotton filter kit. Now my K&N looks ugly with green streaks on violet background.
Did any Bangalore guys buy the K&N cleaning kit recently? let me know the place and cost.
K a s h is offline   Reply With Quote
Old 25th November 2008, 16:08   #21
greenhorn's Avatar
Thanked: 1,519 Times
you missed the part where you actually clean the filter , i mean, is there any sort of technique, precautions etc to be etc
something along the lines of rishibravo's post here http://www.team-bhp.com/forum/modifi...tml#post545232 (Cleaning a K&N conical filter)
greenhorn is online now   Reply With Quote
Old 25th November 2008, 16:17   #22
srikant's Avatar
Thanked: 9 Times
Hey dude that was pretty fast and cheers to you for that. But how did you clean that filter out? pressurised air? or hitting against the walls or floor?
srikant is offline   Reply With Quote
Old 25th November 2008, 16:25   #23
white_vdi's Avatar
Thanked: 18 Times
my car is due for service in another 1000kms so just banged it against a wall. ALOT of dirt and foreign particles came out. you can use the vacuum cleaner that we have at home. just blow air inside out. nothing major.
white_vdi is offline   Reply With Quote
Old 26th November 2008, 22:02   #24
RedMM340's Avatar
Thanked: 24 Times
Originally Posted by rb2399 View Post
The new TATA Safari (2.2) filter from MAHLE costs 600 Rs. I don't think it's cheap !!!
Well I do think that is REALLY cheap compared to repairing a damaged engine. What I really don't understand is how one can afford a car worth 10 lakhs like a Safari, but has a problem purchasing a lousy Rs.600 filter?
Cleaning an OEM filter is about the worst way to try and save money that I can imagine. Don't do it. You run the risk of serious engine damage due to a leaking filter.
RedMM340 is offline   (1) Thanks Reply With Quote
Old 27th November 2008, 01:48   #25
Thanked: 33 Times
Reusing the same filter for years at a stretch is certainly not a good idea, but I dont think there should be any harm in blowing the dust out once 2 months or so.(Provided care is taken to not to damage the filter).
Mohit
amohit is offline   Reply With Quote
Old 27th November 2008, 02:00   #26
AbhiJ's Avatar
Thanked: 537 Times
OE or paper filter elements are not designed to be cleanable. Blowing compressed air may damage the filter element and allow dust to enter the intake causing engine damage over time.
I change air filters in my Viva CRDi every 5000 kms. But at every 2500 kms, I normally follow this procedure...
Take out OE filter...
"Thoko" it gently against a wall or something, for a minute or so making the loose dust falls out...
Reinstall....
Is it a good way/bad way?
AbhiJ is offline   Reply With Quote
Old 27th November 2008, 09:35   #27
Thanked: 245 Times
For safari 2.2l, clean every 7,500kms, replace every 30,000 Kms (dusty conditions), 45,000 Kms (Normal conditions) OR when the Red band appears in the dust indicator.
Old 27th November 2008, 10:14   #28
jkdas's Avatar
Thanked: 1,436 Times
Thought most diesels (hatches) get their air filter replaced every 10k or so.
Old 27th November 2008, 10:18   #29
akshay4587's Avatar
Thanked: 1,686 Times
this thread made me open up and clean my accent's filter
how do we know that filter is at the end of its usable life?
Old 27th November 2008, 12:22   #30
zerocritical's Avatar
Here is how I do an OE filter clean:
Remove OE filter, deposit it in dustbin.
Install new filter.
I agree with you. A better option will be to get a K & N stock replacement. Though priced a bit higher, but its worth it. Cleaning required only after 20-30k kms and never need a replacement. (Unless you drive your vehicle for more than 1 million Miles - thats 10 lakh Miles!!!)
Last time i enquired about a month back it was available at Indranagar. I forgot the shop name. Its in the adjacent lane to that Bus depot. He the dealer and supplier for Bangalore.
zerocritical is offline   Reply With Quote
DIY: Volkswagen Vento TDi - Air Filter Cleaning thoma DIY - Do it yourself 7 19th August 2017 21:18
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
Cleaning the Air Filter of Maruti Esteem VXI BS II Limited Edition 2003 reubensm Technical Stuff 1 12th June 2010 04:32
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 03:43
