Old 26th November 2008, 18:15   #31
me_sid's Avatar
Thanked: 186 Times
Dude Ym. One simple question WHY?. It nice to hear the sound , rush of adrenaline, but end of the day your car has not completed the " run-in" as in yet. Red lining at this juncture can be a difficult thing to digest by your engine. Moreover as Rahul has said ECU is an adaptive learner it adjusts to your driving style continuously. end of the day you might have FE issues. And that SCPA thingy was adorable.
me_sid is offline   Reply With Quote
Old 27th November 2008, 00:49   #32
Thanked: 31 Times
Don't worry about the run in too much. Have fun with your car. Hey there is no such thing as a dumb question. Everyone lives and learns. :-)
From what I've read about Corolla's and Altis the engines are not meant for high revving like the Civic engine. Well even a lot of abuse of the Civic engine would bust it.
And let me see... I hit the rev limiter around 4 times yesterday night.. No sweat... (grins and goes happily to sleep)
csentil is offline   Reply With Quote
Old 27th November 2008, 09:31   #33
supremeBaleno's Avatar
Thanked: 1,709 Times
Originally Posted by Shashank.A
you should not be worried about hitting the rev-limiter, that is precisely the reason it is there, it won't go beyond the point where it can be 'hard' on engine...
Precisely said. The revv-limiter is there so that we don't push the engine into the rpm range which can be bad for the engine (usually marked in red in the tacho).
So, while hitting the revv-limiter is not bad, what leaves a bad taste is the after-effect of it - fuel cut-off to the engine etc. So, learn to upshift just before it hits the revv-limiter. Ofcourse, don't concentrate so much on the tacho that you lose sight of the road.
supremeBaleno is online now   Reply With Quote
Old 27th November 2008, 09:42   #34
deadguy25's Avatar
Thanked: 44 Times
Is this the case with old cars too. I have never experienced it in my Zen (99 model)?
deadguy25 is offline   Reply With Quote
Old 27th November 2008, 09:47   #35
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Cars with carbs dont face this problem, basically at such high revvs the carbs lean out completely resulting in loss of power.
Old 27th November 2008, 09:57   #36
deadguy25's Avatar
Thanked: 44 Times
Okie, thank you. When it results in Loss of power, no matter how hard we throttle, there would not be effective accelaration right?
Old 27th November 2008, 10:00   #37
Thanked: 35 Times
Yup. Every engine has a powerband, as long as you are in that band you will be producing the best power. Below/above this band, engine is not upto its optimum performance.
Old 27th November 2008, 10:02   #38
deadguy25's Avatar
Thanked: 44 Times
Ohh okie. Thank you for clearing it for me.
Old 27th November 2008, 10:22   #39
Thanked: 64 Times
Originally Posted by HotChillyPepper View Post
Add to all, Your ECU is logging in what you are doing with your engine. You will be caught in case you need to approch Toyota service during warrenty period.
Caught with what ? Is it illegal to hit the rev limiter ?
hondadude is offline   Reply With Quote
Old 27th November 2008, 10:27   #40
Thanked: 35 Times
come to think of it is. Once you hit rev limiter you are doing insane speeds. Then you are over the allowed speed limit, if there is an interceptor they will catch you and fine you for overspeeding. So yes, it is illegal.
Obviously, I am just kidding. Hondadude, hitting limiter is not legal, read my previous post, I have explained it clearly.
Old 27th November 2008, 10:51   #41
Ricky_63's Avatar
Thanked: 394 Times
Originally Posted by manikjeet View Post
they did on the first generation of cielo glx
Never happened to my car - which was from the initial lot of Cielos.
Old 27th November 2008, 11:31   #42
Originally Posted by Shashank.A View Post
Its same for other cars that I have tried on. OHC and Alto.
Secondly, I do not feel that you should be worried about hitting the rev-limiter, that is precisely the reason it is there, it won't go beyond the point where it can be 'hard' on engine...
I have tried it on the new city as well - when the car hits the limiter, there are minor jerks but what i felt in the altis was completely diff : not jerks, but the engine cutting off completely for half a sec or so
yamracing is offline   Reply With Quote
Old 27th November 2008, 12:30   #43
Ym-enjn's Avatar
Thanked: 55 Times
As far as I remember it was more like ignition cut then fuel cut. It was like if you have ever tried to put off your ignition by turning off the key of car while accelerating (not suggesting to try with your car, and never even think of taking out the key while car is moving).
No one from Diesel camp complaining same.. Is there no limiter in diesel cars like Skoda, especially vRs.
Ym-enjn is offline   Reply With Quote
Old 27th November 2008, 12:33   #44
Akshay1234's Avatar
Thanked: 7,242 Times
the vrs isnt a diesel. and diesel cars too have limiters.
Old 27th November 2008, 12:35   #45
Thanked: 35 Times
All cars with ECU's have limiters. Be it petrol or diesel.
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Over revving MPFI Zen Engine( revv limiter doesnt cut at 6000 rpm!!) speedsatya Technical Stuff 4 30th October 2010 15:21
Palio 1.1 SLX: Fuel cut-off indicator prashkul Technical Stuff 13 14th May 2010 12:55
Ractive Tachometer 3.5'' does not cross 3000 RPM on Max Revv bugboy180 Modifications & Accessories 21 23rd January 2009 00:11
Ideal RPM for Max Fuel Efficiency saurabhkum Technical Stuff 8 16th August 2007 01:23
