Old 25th November 2008, 12:52   #1
Default Palio GTX injector blocked
Team!
Need urgent info, my GTX's injectors seems to be blocked I get the check injector light on frequently and the vehicle also looses power. I gave it to Autofin to get the injectors cleaned, they are claiming the injectors have a sensor and it cant be cleaned and I have to get the injectors changed. Also they say the injectors come in a set of 4, I have to change them as a set with the rail and I can't get the blocked injector alone changed. Is this true or are they taking me for a ride? Any other dealers in hyderabad where I can get a second opinion?
Thanks,
Solly
solly is offline   Reply With Quote
Old 25th November 2008, 16:04   #2
CtrlAltDel's Avatar
Thanked: 24 Times
the other dealers are Malik Cars (Banjara Hills and Himayatnagar) and Concorde (Khairtabad)
CtrlAltDel is offline   Reply With Quote
Old 25th November 2008, 16:26   #3
windsurfer's Avatar
Thanked: 25 Times
I would also advice you to check with Solar Automobiles, Begumpet before you decide to replace them.
windsurfer is online now   Reply With Quote
Old 26th November 2008, 01:21   #4
Thanked: 660 Times
How did they cleaned. Do they have injector cleaning/testing machine. I don't know about any sensors but its just have filters and solenoid valves.
I guess you can buy just one. Just find the part number and buy. They are either Denso, Bosch, delphi. these are major OEM supplier of indian manufacturer.
Old 26th November 2008, 13:42   #5
Guys thanks for the replies. Autofin don't have an Injector cleaning machine, I asked them not to open the injectors. Navin from T'bhp who had a similar problem in his S10 suggested checking the Lambda sensor. I checked it and it was not working properly.. have ordered the part, costing around 2800 Rs, hopeful will get it in a weeks time. I'm able to use the car in the mean time.. Hoping this will solve the problem...
Old 26th November 2008, 13:44   #6
Yes Navin too asked me to check them out.. will do that soon
Old 26th November 2008, 21:41   #7
RedMM340's Avatar
Thanked: 24 Times
Please do not assume that your injectors are blocked.
The symptoms you describe may have nothing to do with the injectors at all. It might be your ignition coil. I have written about a troubleshooting procedure for the ignition coil before, so do a search.
Injectors can be cleaned. I had the dealer do a Liqui Moly injector clean that was very effective. If your repair shop is advising you to buy a new set of injectors rather than have them cleaned, they are trying to send you to the cleaners!
Originally Posted by solly View Post
Team!
Thanks,
Solly
RedMM340 is offline   Reply With Quote
Old 27th November 2008, 12:19   #8
Thanked: 16 Times
Don't know about the S10 put in our 1.2, I got the injector cleaned for I guess Rs.1200/- or something + taxes. This was done from Dynamic motors, Delhi.
anupamsinha is offline   Reply With Quote
Old 27th November 2008, 13:52   #9
Ya will check out the ignition coil, Got your procedure for the same..
Any body knows where I can get a Liqui Moly Injector cleaning done in hyderabad??
Old 1st December 2008, 15:52   #10
Hi how many Lambda sensor does a 2001 Dec GTX have??
Thanks,
Solly
Old 1st December 2008, 16:03   #11
lohithrao's Avatar
Thanked: 163 Times
Thanks,
Solly
solly you better ask the mechs to check the car for errors on the examiner, this sat i had the same issue and when checked on examiner got to know it was due to the ignition coil, i got it cleaned now its fine.
the ignition coil is 2180 in bangalore.
lohithrao is offline   Reply With Quote
Old 1st December 2008, 18:59   #12
RedMM340's Avatar
Thanked: 24 Times
Thanks,
Solly
My '02 GTX has only 1 lambda sensor and it is mounted on top of the exhaust manifold.
I would also recommend the injector clean prior to replacing the coil. Replace oil, spark plugs after the injector clean.
Keep in mind that when my ignition coil went bad, it was an intermittent issue. For a month, I had sudden but brief power loss with the injector light come on. It may be that one of the connectors on your coil had corrosion, which caused spark delivery problems. But if the coil has an issue, it will continue to give you problems.
Old 1st December 2008, 19:42   #13
lohithrao's Avatar
Thanked: 163 Times
true, i am thinking of getting it replaced soon.
Old 2nd December 2008, 00:57   #14
Thanked: 29 Times
Dear Solly,
I am a S10 owner frm Hyd and facing the very problem mentioned by you recently. I give it to Solar automobiles regularly (they've shifted to kukatpally frm Begumpet) and it was they who finally managed to solve the problem (took an awfully long time though).
My mech did check most of the things already mentioned, right from the ignition coil test to the lambda sensor check....it was after trying n testin a random of things did the issue get actually resolved....though they still feel it was a combo of niggling problems....
Now tht they have enuff experience with my car, wud suggest you to have a word with them....
Do call me for any further assistance (Naveen-99855 37773)
Flash777 is offline   Reply With Quote
Old 31st July 2009, 19:24   #15
Guys
Changed the ignition coil, ignition wires and labda sensor.. it solved the problem.. Thanks for ur suggestions.. Sorry for the later post!!
Solly
Palio 1.6 GTX v/s Palio 1.6 Sport - Visible Differences moralfibre The Indian Car Scene 140 21st May 2014 17:21
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
The GTX arriveth. Palio 1.6 GTX thedragula Long-Term Ownership Reviews 36 12th June 2011 12:40
2002 palio 1.6 GTX (or) 2006 Baleno (or) New palio stile 1.6 sports (or) Ford fusion Mr_Bean Hatchbacks 31 16th December 2010 17:12
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
