Old 26th November 2008, 16:15   #1
gaurav.28ch
Posts: n/a
Default Weak clutch on Esteem - Car speed not matching engine RPM
I have 20001, MPFI Esteem, 65k-Odo, clutch yet to replaced. Seems to be a weak clutch issue as my car speed is slightly out of sync with engine RPM. At higher RPM's car speed seems to be 5-10 kmph less than it should be. My question is what do I need to replace out of these 3 - Cluth plates, pressure plates and release bearing.
My undrstanding is release bearing comes into play to interrupt power transfer from engine to wheels. So this doesn't need replacement. Is that right?
Also clutch is hard as well which it should be for 65k.
Old 26th November 2008, 16:50   #2
esteem_lover's Avatar
Thanked: 447 Times
It is time for a clutch overhaul. change the bearing, plates, cover assembly and the spring.
Old 26th November 2008, 17:47   #3
Shashank.A's Avatar
Overhaul, including the three parts and labour would cost you under Rs.3000. Go for a Ceekay assembly.
Shashank.A is offline   Reply With Quote
Does the Maruti Swift have a weak clutch tsk1979 Technical Stuff 306 15th March 2015 22:43
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Ikon 1.6 with weak clutch takes us to Darjeeling and a few forests of North Bengal. 1100D Travelogues 99 16th August 2009 10:43
