Old 28th November 2008, 12:55   #1
SunnyBoi's Avatar
Thanked: 2,832 Times
Default Which Indian Car has a Copper Radiator?
Need one for an experiment, Do post here if you know any. Approximate price/Price from shops will also help (excluding the likes of import cars such as audi/merc/etc)
TIA,
Sunny.
SunnyBoi is offline   Reply With Quote
Old 28th November 2008, 13:00   #2
@ri
@ri's Avatar
Dont know about the price but you could get your hand on some Industrial Radiators not just automotive ones which could fit your requirement.
@ri is offline   Reply With Quote
Old 29th November 2008, 11:23   #3
Thanked: 103,780 Times
IIRC, my Jeep is running a copper radiator from Lawrence Radiators. Get in touch with them for your experiment. I'd say they are amongst the best in the business.
Old 29th November 2008, 11:40   #4
alpha1's Avatar
Thanked: 1,035 Times
How is copper radiator going to help?
Copper is only a good conductor.
In order to get good heat dissipation via radiation - you need to paint the radiator black (which anyway is defaul color of all radiators).
Old 29th November 2008, 13:03   #5
nitrous's Avatar
Thanked: 285 Times
My Sumo runs on copper radiators. Most trucks/LCVs use copper too.
Old 29th November 2008, 13:10   #6
Rudra Sen's Avatar
Thanked: 4,296 Times
My Amby has for a long time.
Old 29th November 2008, 13:17   #7
Amey's Avatar
Thanked: 189 Times
What experiment Sunny Boy ?
Amey is offline   Reply With Quote
Old 29th November 2008, 13:32   #8
Thanked: 149 Times
Sunny, just visit any scrap yard, most radiators avaialble with them would be copper. If required / suspicious, scrap some paint from top / bottom tank using a coin / key to check if the material is really copper.
Old 1st December 2008, 10:34   #9
SunnyBoi's Avatar
Thanks a lot for the link. although its blocked at office, will try it out from a friend's place.
i have a size restraint of ummm...2feet x 2feet. Will check these rads as well
Heh, you know it well, dont you? :P
Most of the radiators are aluminium. Infact all I found in the guj was Al rads.
Ahh thanks. One more car to look out to
I'll be using only copper parts in my loop. Addition of Aluminium will bring in heavy corrosion.
as I said before, I have lil size constraints. If I get some from the industrial background with the proper size, I'll go for it !
Old 1st December 2008, 15:03   #10
Thanked: 149 Times
Corrosion or contamination? tripsi mfg? :-P
Old 1st December 2008, 15:15   #11
is this for a bike? :o
silver_shadow is offline   Reply With Quote
Old 1st December 2008, 15:44   #12
asejwal's Avatar
Thanked: 15 Times
Default Tata Sierra!
Hi, I think the TATA Sierra I POSSESS has a copper radiator...
asejwal is offline   Reply With Quote
Old 1st December 2008, 17:49   #13
SunnyBoi's Avatar
Corrosion. Did not get the second part of your question
Hah no
Which Indian Car has mid-engine RWD? GTO The Indian Car Scene 32 5th January 2011 14:59
Maruti 800 Type-I copper radiator vinfriend Technical Stuff 1 3rd June 2009 12:42
What Color in swift VDi?Metallic Sunlight Copper or Pearl Metallic Arctic White. Poll SumitBahl Hatchbacks 54 4th May 2009 14:26
Swift "Sunlight metallic copper" color car painting gururaj Modifications & Accessories 16 26th November 2007 10:31
Grade of Copper in Power Wires ? 929RON In-Car Entertainment 32 30th August 2006 09:35
