Old 28th November 2008, 18:09   #1
Ajaybiz's Avatar
Thanked: 140 Times
Default Issue with VDI acceleration.
Guys i am facing issue with my year old Swift VDI its nothing but whenever i rev her past 3500 RPM in 4the gear she pulls well but after putting in 5 th gear i feels like car is not getting sufficient fuel supply and she slows down the speed drastically, but after 4-5 seconds again she comes back to life after playing around with accelrator padel(keep on pulling and pushing), what could be the issue?It was there before 3rd service and even after servicing still its present, didnt complained to servicing guys as this part i want to get it done in my presence.
M i doing too much with her or its ok with Diesel motors?
For day to day drive means not pushing her beyond 3000 RPM she is quite ok.
Ajaybiz is offline   Reply With Quote
Old 28th November 2008, 23:05   #2
gemithomas's Avatar
Thanked: 136 Times
Are you getting this only in 5th gear?
Do you really pull and push the accelerator pedal? Is it kind of stuck? or did you just mean pumping the accelerator pedal.
Where will the rpm be once you change the gear. Is going way below 2K mark?
The best thing to do is to ask the dealer/ service centre to give you a test drive and check the same.
Old 29th November 2008, 04:06   #3
kuttapan's Avatar
Thanked: 12 Times
it's defnitely not Ok. Get it checked at the A.S.S, though where are they going to drive to check issue at 3000 r.p.m in 5th gear? Thats well over 120k.
kuttapan is offline   Reply With Quote
Old 29th November 2008, 20:36   #4
Ajaybiz's Avatar
Thanked: 140 Times
Yes I mean to say pumping but not like we use to do for older 4 wheelers breaks pumping for stopping them, thanks guys let me check with them, hope someone will be having trade mill kind of stuff to take her on 4k RPM at 4th gear.
And before shifting gear yes in all gears the RPM comes down to as low as 2000-2500 RPM.
Old 30th November 2008, 00:41   #5
Thanked: 658 Times
acceleration is smooth or you are feeling some jerk (jatka).
Old 30th November 2008, 10:13   #6
Thanked: 11 Times
Iv had this once or twice... always thought it was due to a chocked filter.
Old 1st December 2008, 10:23   #7
Ajaybiz's Avatar
Thanked: 140 Times
Acceleration through the gears are all smooth no issue at all if i am not crossing 3500 RPM in 4th cog.
Old 1st December 2008, 13:10   #8
Jaggu's Avatar
Thanked: 7,473 Times
Check the accelerator sensor and air filter, also for any leaks in turbo plumbing. Take it to A.S.S and get it attended.
Old 1st December 2008, 13:38   #9
jusgetgoing's Avatar
Thanked: 35 Times
I face the same issue in the 5th gear. This happens sporadically and has started recently. Rev is around 2500rpm. Somewhere after 80 km/h, the car refuses to respond to flooring the pedal. Car has done 19000km so far. I have to check with the service guys. 4th service is due.
jusgetgoing is offline   Reply With Quote
Old 1st December 2008, 14:03   #10
Ajaybiz's Avatar
Thanked: 140 Times
Yes Jaggu makes sense specially the accelrator sencor and Turbu plumbing part, will get it checked this saturday.
Old 3rd December 2008, 20:55   #11
white_vdi's Avatar
Thanked: 17 Times
Angry me too felt the same
guys even i felt something similar today. here is what happened
was getting back home from college and the temperature needle was at its normal position. was revving her. shifted from 3rd to 4th with rpm around 2500 in 4th and there was no throttle response . she was stuck at 2500rpm. i pumped the gas pedal twice but no acceleration. moved down to 3rd and she was back. this happened twice and after that she was as normal as ever.
do i also check the accelerator sensor, air filter and the turbo plumbing?
happened twice but was fine after that. air filter was cleaned 4 days back only. my car has done 8500kms and 3rd service is coming up. please help!!
@ ajay : is your car running fine now? you visiting your service station this saturday?
white_vdi is offline   Reply With Quote
Old 3rd December 2008, 21:07   #12
Jaggu's Avatar
while engine in switched off state, press the acc pedal completely down, repeat this couple of times, if its minor terminal issue it will be fine.
Old 3rd December 2008, 22:33   #13
white_vdi's Avatar
Thanked: 17 Times
thanks jaggu!!
will get back with an update again.
Old 4th December 2008, 00:02   #14
kuttapan's Avatar
Thanked: 12 Times
Pedal sensor is my guess as well, but why it occurs only in the higher gears, is something I am unable to fathom. Does it mean that the default map the ECU chooses, in the absence of any input from the pedal sensor, is not sufficient to pull the car in higher gears?
When I had the pedal sensor issue, it would occur randomly and the main indication for me was that my car refused to climb the ramp out of my parking place.
Old 4th December 2008, 00:25   #15
white_vdi's Avatar
Thanked: 17 Times
thanks for your input kuttapan
how was your issue resolved?
Fiat Linea (1.3 MJD EP) Acceleration Issue!!! akhilesh51 Technical Stuff 43 10th September 2017 00:34
BMW 525i E60 (N2N) 2009 acceleration issue FlyinLow Technical Stuff 9 18th July 2012 20:15
Acceleration issue in my Bajaj Pulsar 180 UG3 sagarpadaki Motorbikes 31 19th March 2012 14:17
Bajaj Avenger 180cc: Unresolving issue with acceleration (Not a carburetor problem) Mansha Motorbikes 36 20th August 2010 12:02
