Old 30th November 2008, 12:04   #1
ramkya1's Avatar
Thanked: 364 Times
Default Culprit Identified - Tyre Sanitized
I could identify (hopefully) the culprit who was attacking my RR Tyre and sanitized it yesterday.
The Rear Right (RR) has been bleeding air for the last 4 months now, I keep 32ps on all 4's of the Scorp CRDe, Tubeless. After the last puncture on the RR, the level goes down in 5-6 days, other 3 are stable for 12-15 days, indicating another puncture or bleeding air on the RR.
Yesterday, checked out with the non-regular puncture shop and he said:
1. The RR valve is that of a bike, not a Tubeless one!!!! The one residing has a spring, usually found on Tubed tyres and bikes which jump more and hence need the spring. He showed me one without a spring, screwed it in said that's the one for the TL, charged me Rs.15/- Picture of the old one here:
I wonder if this is true, why the spring and what's the difference in the TL valve and the spring loaded one.
Thanks in advance for your inputs.
--Ramky
Last edited by ramkya1 : 30th November 2008 at 12:10. Reason: Changed to culprit, lets use caution while using such terms
ramkya1 is offline   Reply With Quote
Old 30th November 2008, 13:04   #2
gd1418's Avatar
Thanked: 656 Times
Ramky, both the valves look similar and with spring. What's the difference? I couldn't spot any. [mumbling] I think I must pay a visit to my eye-doctor.
Old 30th November 2008, 13:22   #3
Thanked: 3,629 Times
GD, Hold your visit to your Opthalmologist The photos ramkya posted are both of the same valve.
The spring is for the pin that gets pushed down while pumping in air. The pin operates a one way valve to let air in (or out when pushed). The spring is there to hold the one way valve positively closed and to spring it back to closed position once pressure is lifted off the pin. So how does the valve without the spring close itself, without the aid of the spring especially if the air pressure inside the tyre is low to keep it closed? Wouldn't that lead to a faster leak?
Old 30th November 2008, 14:25   #4
ramkya1's Avatar
Thanked: 364 Times
Arrow
GD, like Sankar said, both the picture are of the same valve. I just saw that the new one does not have the spring, the guy just showed it to me and screwed in.
Shankar's question has me stumped; will now go back and chek to see how it's really different without the spring, will take some photos and upload it so we will know the difference, structure wise.
=Ramky
Old 30th November 2008, 16:01   #5
The air leak may be due to the worn out of rubber (a kind of sealing one) at the bottom(red one) of the valve. If there is some damage to this or the other rubber then air will leak even if the spring is there or not. Spring may help only in a case where the bottom rubber is damaged very little, by lifting it up with little bit more force(force from air inside the tyre + force from the the spring).
shivapsreddy is offline   Reply With Quote
700 accident spots identified on National Highways; ranked by number of fatalities sbalagru6 Street Experiences 8 7th June 2016 16:23
Picture of thief buying a car on fake demand draft (Rajasthan). EDIT: Culprit found? ksgehlot The Indian Car Scene 81 3rd April 2016 13:04
Is Bull bar the culprit? Daewood Street Experiences 47 7th March 2015 14:53
Victim of hit & run, I ended up with a crushed leg. Culprit = Red Skoda desideep Street Experiences 11 25th February 2015 00:47
Un-identified Moped EDIT - Its an Innocenti Lambretta 48 Moped IndrojitSircar Vintage Cars & Classics in India 18 15th April 2012 21:47
